Where to buy rivets for frame? #1721283
01/04/15 11:13 AM
01/04/15 11:13 AM
NH
torredcuda Offline OP
NH
I need to swap a crossmember from my parts truck to my `76 clubcab and would like to use rivets instead of bolts, anyone have a source to buy from as I can`t seem to find much available? I did find these guys - http://www.bigflatsrivet.com/steel_rivets.php
Re: Where to buy rivets for frame? [Re: torredcuda] #1721284
01/04/15 02:38 PM
01/04/15 02:38 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
How do you plan on installing them? It takes a good amount of pressure to flare them and make them fit tightly.
Re: Where to buy rivets for frame? [Re: torredcuda] #1721285
01/04/15 03:02 PM
01/04/15 03:02 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Don't waste your time. Its just about impossible to duplicate the factory installed rivet's. Just find a grade 8 fine thread that fits the hole or drill larger to fit the bolt. Use grade 8 fine thread, flat washers and stover nuts.
Re: Where to buy rivets for frame? [Re: NITROUSN] #1721286
01/04/15 06:45 PM
01/04/15 06:45 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I use the shouldered bolts used to bolt the rear bumper brackets to the frame
Re: Where to buy rivets for frame? [Re: BulletBob] #1721287
01/04/15 09:09 PM
01/04/15 09:09 PM
NH
NH
I have good air hammer and I use to work on Grumman trucks so I have the right bits. I plan on welding it in also so the rivets are more for the correct look.
Re: Where to buy rivets for frame? [Re: torredcuda] #1721288
01/04/15 10:20 PM
01/04/15 10:20 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Won't the welds take away from the "correct look" you're after?
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Where to buy rivets for frame? [Re: DusterDave] #1721289
01/05/15 03:26 AM
01/05/15 03:26 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
The local tractor supply chain sells rivets for farm equipment. Not sure how big they have though, it's only place I can think of.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Where to buy rivets for frame? [Re: torredcuda] #1721290
01/05/15 06:32 AM
01/05/15 06:32 AM
places
79powerwagon Offline
places
You should be able to find what you need from the usual suspects (McMaster-Carr, Grainger, etc.)
Re: Where to buy rivets for frame? [Re: DusterDave] #1721291
01/05/15 11:19 AM
01/05/15 11:19 AM
NH
NH
Welds will be on top and inside the frame so unless you stick your head up there you won`t see them, from the outside it`ll look factory.
I`ll try Tractor supply as there is one right in town.
Re: Where to buy rivets for frame? [Re: torredcuda] #1721292
01/05/15 10:06 PM
01/05/15 10:06 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
most truck spring shops also correctly replace those frame rivets by putting red hot rivets into the hole then mushrooming the end just like at the factory....
Re: Where to buy rivets for frame? [Re: savoy64] #1721293
01/06/15 04:38 PM
01/06/15 04:38 PM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
Another option, we did this on some street rod stuff. Take a grade 8 bolt and grind it down to look like a carriage bolt top. Zip it in with an impact and it'll be good.
Re: Where to buy rivets for frame? [Re: wyldebill] #1721294
01/06/15 09:32 PM
01/06/15 09:32 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
I actually used carriage bolts. Filed the holes square and there you go!
Re: Where to buy rivets for frame? [Re: redraptor] #1721295
01/07/15 04:38 PM
01/07/15 04:38 PM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
Most of the carriage bolts we come across are of a lower quality than grade 8
Re: Where to buy rivets for frame? [Re: wyldebill] #1721296
01/07/15 09:21 PM
01/07/15 09:21 PM
dogdays Offline
dogdays  Offline
Boy, it sounds like a lot of work. I had a similar situation 30 years ago with the rear spring hangers on a 2-ton grain truck. We swapped in a different rear end out of a different truck and wanted to use the different truck's springs, which were longer. I settled on bolting the spring hangers in with Grade 8 bolts, torqued to spec (80% of yield) and never had a bit of trouble. I don't believe the rivets do any more than a decent bolt. They're not supposed to be in shear, they are stretched to provide clamping force. The rivet is stretched to provide clamping force by nature of it being installed hot and then shrinking while cooling down.
You'll do what feels best to you, but from a technical point of view I don't think you'll gain anything mechanically over a properly torqued Grade 8 bolt. And unless the rivet goes in red hot or hotter, you won't get as much force as the bolt provides.
R.
Re: Where to buy rivets for frame? [Re: wyldebill] #1721297
01/07/15 09:47 PM
01/07/15 09:47 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
True. So are those rivets.
Re: Where to buy rivets for frame? [Re: redraptor] #1721298
01/07/15 10:46 PM
01/07/15 10:46 PM
NH
NH
"Three major tests are used to ensure that rivets comply with the requirements of IFI
114, shear strength, tensile strength and mandrel break load.
• Other tests such as blind head formation (usually in conjunction"
I think rivets need to work in shear by where they are used?
