electrical question Older Ramcharger #1721010
01/03/15 10:19 PM
01/03/15 10:19 PM
Finally a HUSKER again
Moparnut426 Offline OP
With the headlights on, left turn indicator stays on , turn left blinker on, it flashes normally, put slight pressure on it without actually turning the turn signal on it will go out. I dont have another turn signal switch to try, but would you guys think thats the issue, or could I have a diferent issue??
Thanks guys
Re: electrical question Older Ramcharger [Re: Moparnut426] #1721011
01/03/15 11:02 PM
01/03/15 11:02 PM
headlights on/stalk in nuetral= left turn indicator stays on. Move stalk down (headlights still on)= TS indicator flashes normally. Correct so far?. Clarify the "slight pressure", is that moving the stalk from down to slightly up from that down position but not enough to "snap" into neutral?
Re: electrical question Older Ramcharger [Re: RapidRobert] #1721012
01/03/15 11:12 PM
01/03/15 11:12 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Try tightening up the dash screws. It sounds more like a ground issue than a switch problem.
Re: electrical question Older Ramcharger [Re: RapidRobert] #1721013
01/03/15 11:26 PM
01/03/15 11:26 PM
Well, close,
Headlights on, dash indicator for left turn stays on, put slight pressure on stalk to the down position and the green indicator goes out. The tail lights never show a left turn on until i actually turn them on. Right side is ok, only does this on the left indicator.
What, grounds? where are they located? I had this truck from a total empty shell to a "new" truck and this is the only issue electrically
I have several body to chassis grounds I mad of 10 gauge wire, have several engine to chassis grounds also, those, 2 of them are 4 gauge.
Kasey
Re: electrical question Older Ramcharger [Re: Moparnut426] #1721014
01/03/15 11:29 PM
01/03/15 11:29 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The instrument cluster grounds through the screws that hold it to the dash. If they get loose then you can end up with weird dash light problems because they feed back through circuits they shouldn't.
Re: electrical question Older Ramcharger [Re: stumpy] #1721015
01/03/15 11:32 PM
01/03/15 11:32 PM
Great!! So could I fix that issue with a small ground wire from chassis to the cluster housing?
Kasey
Re: electrical question Older Ramcharger [Re: Moparnut426] #1721016
01/03/15 11:36 PM
01/03/15 11:36 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I would start by tightening the screws. The system has been working for years without an extra ground wire needed. Another possibility could be the turn signal bulb, front or rear, being shorted or a corroded socket. This also can cause a feedback. Just because the lights work doesn't mean there can't be a problem with them.
Re: electrical question Older Ramcharger [Re: stumpy] #1721017
01/03/15 11:42 PM
01/03/15 11:42 PM
Thanks Stumpy
Re: electrical question Older Ramcharger [Re: Moparnut426] #1721018
01/04/15 12:13 AM
01/04/15 12:13 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The 5 or 6 I had all had ground problesm with the rear lights.They were almosy always the cause of ground problems.the housings need a good ground.Rocky
Chrysler Firepower
Re: electrical question Older Ramcharger [Re: Moparnut426] #1721019
01/04/15 12:13 AM
01/04/15 12:13 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I figured I'd let you have a try at the easy stuff before you dug into the column.
Re: electrical question Older Ramcharger [Re: stumpy] #1721020
01/04/15 12:21 AM
01/04/15 12:21 AM
I just rebuilt the column in a 70 Charger R/T yesterday, Turn signal switch, and upper bearing. I dont mind them, I am not a fan of say a 06 and newer charger they really suck!
Re: electrical question Older Ramcharger [Re: Moparnut426] #1721021
01/04/15 01:01 AM
01/04/15 01:01 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
If the turn signal ind is on with the headlites on its usually feedback from a bad ground for the park lite bulb so it finds a ground back through the turn signal element of the bulb back up the turnsignal circuit to the dash ind which is on the front turn signal circuit. Since the park lite and turn signal bulb touch together in the bulb and share the same ground its almost always a bad ground from the front bulb or socket. Ron
Re: electrical question Older Ramcharger [Re: 383man] #1721022
01/04/15 03:14 AM
01/04/15 03:14 AM
Thanks This is GREAT info!
Re: electrical question Older Ramcharger [Re: Moparnut426] #1721023
01/04/15 01:46 PM
01/04/15 01:46 PM
I would pull the front/rear 1157 dual filament bulb drivers side metal sockets out of their housings & with (2) jumper wires with alligator clips on each end ground both of em to a nearby known good ground & see if that clears it up (& see if only the top (thin/less bright) filament lights up with the running lights on) & if so then plug em back one at a time to find which one lost it's ground. If no go there (they're OK) plug em back in & I would seperate the dangling under the column brake/ts harness & check continuities with (1) the stalk in neutral/lights off (2) stalk in neutral/lights on (3) stalk slightly down as you described/lights off (4) stalk slightly down/lights on & see what you get & make a note of the colors/yes or no continuity/what position. What year Ramcharger? Do you have a shop manual for it?
Re: electrical question Older Ramcharger [Re: RapidRobert] #1721024
01/04/15 11:35 PM
01/04/15 11:35 PM
morrisville, pa
skajm Offline
skajm  Offline
morrisville, pa
Check the ground from wiring harness to radiator support to battery.
Re: electrical question Older Ramcharger [Re: RapidRobert] #1721025
01/05/15 03:03 AM
01/05/15 03:03 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Robert I tried to send you a PM but it said it is full and it wont send. Ron
Re: electrical question Older Ramcharger [Re: RapidRobert] #1721026
01/05/15 01:53 PM
01/05/15 01:53 PM
88 ramcharger. I have tried to make every attempt while restoring this truck to make good chassis/body grounds, but I will do as described and see whats up. On a 88 ramcharger is there supposed to be a lil pigtail eyelet to eyelet ground that is to ground the steering column to the dash frame?
Re: electrical question Older Ramcharger [Re: Moparnut426] #1721027
01/06/15 12:07 AM
01/06/15 12:07 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
If you pull the front park/turn signal bulb out on the affected side does the blinker ind go out ? Ron
Re: electrical question Older Ramcharger [Re: 383man] #1721028
01/06/15 03:24 PM
01/06/15 03:24 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
its beyond all hope-----time to sell it to a less picky guy........
Re: electrical question Older Ramcharger [Re: savoy64] #1721029
01/06/15 06:30 PM
01/06/15 06:30 PM
The reason I was asking about a shop manual is cuz the gas gauge is nonop on my 85 ramcharger & I figured yours would be close enough to be the same in that area if you had something available. Yesterday I looked at the col as I headed out & the plastic cover was in place so I could not see if it has that short black pigtail with the eyelets you asked about underneath (above) the cover & I was in a rush. Actually grounding the col with a jumper wire would take care of that for testing purposes & be easy to do as that is all the pigtail does. On my situation I sure dont wanna drop that tank unless I have to & the open might be further upstream electrically so I have to confirm first
