Crank Won't Turn #1720688
01/03/15 12:42 PM
01/03/15 12:42 PM
Buckle of corn belt ,c. lll.
420SIX Offline OP
420SIX  Offline OP
Motor spun free 15 years ago. Sitting under roof since then. Filled cylinders w/Marvel Mystery Oil a month ago....still won't move. Not sure how big of a cheater bar to put on the crank bolt ??
Re: Crank Won't Turn [Re: 420SIX] #1720689
01/03/15 01:10 PM
01/03/15 01:10 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Try turning the crank clockwise, then Counter-clockwise back and forth, again and again. If you start to get some movement and then it improves each time, you will probably get it to turn over.
Back and forth is your friend. Do not keep trying to go just one direction.
Master, again and still
Re: Crank Won't Turn [Re: 420SIX] #1720690
01/03/15 03:48 PM
01/03/15 03:48 PM
Western PA
O
OldMoparMan Offline
OldMoparMan  Offline
O
Western PA
You say it was under roof which in my thinking it was exposed to the weather. Was it ever spun over during that time to keep oil all over the parts. If not you should pull your valve covers and see if the rockers have surface rust.
I was trying to get a 400 Pontiac to turn over a little while back that has been in a barn not started since the mid 80's with no luck. It's rockers are covered with rust as are the cylinder walls so I'm thinking the whole interior is in that condition.
Used both Seafoam and Marvel.
By the way I was using a 4 foot cheater on the breaker bar and loosened the crank bolt without as much as budge of the crank.
Living with ALS help support the search for a cure
Thanks http://web.alsa.org/site/TR/Walks/WesternPennsylvania?team_id=347781&pg=team&fr_id=12069
Re: Crank Won't Turn [Re: 420SIX] #1720691
01/03/15 04:06 PM
01/03/15 04:06 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If you can get to the back of the engine,take a 3 ft piece of bar stock,drill and bolt to crank flange,you'll do far better that on the bolt.
Re: Crank Won't Turn [Re: 420SIX] #1720692
01/03/15 07:50 PM
01/03/15 07:50 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
If a piston is at TDC or BDC and rusted it will be your greatest opponent. The crank itself is at it's least point of leverage.
I'd pull the pan and see. Soak with a penetrating solvent as mentioned. Personally, I'd just pull the heads and assess the ridge at the top of the bores. If it's enough to catch a fingernail on.......the pistons aren't worth saving. Unbolt the rod/piston and knock them out the top one at a time. At some point the crank will then turn.
Re: Crank Won't Turn [Re: Dean_Kuzluzski] #1720693
01/03/15 09:53 PM
01/03/15 09:53 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Another tick is to fill cylinders with diesel fuel and let it sit overnight....
Just throwing ideas............
Re: Crank Won't Turn [Re: Wedgeman] #1720694
01/03/15 11:44 PM
01/03/15 11:44 PM
Castlegar, BC, Canada
That AMC Guy Offline
My solution has always been a combination of diesel, ATF and WD40. It has never failed me yet. Even unstuck a 318 that sat with no carb for 10+ year. Engine almost ran afterwards too!
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: Crank Won't Turn [Re: That AMC Guy] #1720695
01/04/15 01:05 AM
01/04/15 01:05 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
SILLY QUESTION
if a motor is stuck that bad, what does one expect to achieve by "breaking it loose" Another 100K miles ??? Not likely
get it running
then what ?/ figure out it needs rebuilding anyway
Re: Crank Won't Turn [Re: TJP] #1720696
01/04/15 01:12 AM
01/04/15 01:12 AM
420SIX Offline OP
420SIX  Offline OP
It is in a 442 convertible I have for sale that needs total resto.
I would at least like to assure any potential buyers the motor doesn't have a rod through the center of the block
