Re: Crank Won't Turn
[Re: 420SIX]
#1720689
01/03/15 01:10 PM
01/03/15 01:10 PM
Posts: 12,141 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Try turning the crank clockwise, then Counter-clockwise back and forth, again and again. If you start to get some movement and then it improves each time, you will probably get it to turn over.
Back and forth is your friend. Do not keep trying to go just one direction.
Master, again and still
[Re: 420SIX]
#1720690
01/03/15 03:48 PM
01/03/15 03:48 PM
Posts: 245 Western PA
OldMoparMan
Western PA
You say it was under roof which in my thinking it was exposed to the weather. Was it ever spun over during that time to keep oil all over the parts. If not you should pull your valve covers and see if the rockers have surface rust. I was trying to get a 400 Pontiac to turn over a little while back that has been in a barn not started since the mid 80's with no luck. It's rockers are covered with rust as are the cylinder walls so I'm thinking the whole interior is in that condition. Used both Seafoam and Marvel. By the way I was using a 4 foot cheater on the breaker bar and loosened the crank bolt without as much as budge of the crank.
[Re: Wedgeman]
#1720694
01/03/15 11:44 PM
01/03/15 11:44 PM
Posts: 4,798 Castlegar, BC, Canada
That AMC Guy
My solution has always been a combination of diesel, ATF and WD40. It has never failed me yet. Even unstuck a 318 that sat with no carb for 10+ year. Engine almost ran afterwards too!
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
