Page 1 of 3 1 2 3
New Borgeson Box install. #1720485
01/02/15 11:48 PM
01/02/15 11:48 PM
Kings Beach, CA
tahoechallenge Online content OP
tahoechallenge  Online Content OP
Kings Beach, CA
I received the new Borgeson steering box last week and I am starting to install it in my 70, 340 powered Challenger. I purchased it through Summit before Christmas. I figured it would take a while to get it, but to my surprise it only took a week. It is replacing a stage 3 box, that was leaking. I plan on reusing my fast ratio arms for now.
I removed the old box this evening. I sat the new and old side by side to compare. (I remember pictures of the original Borg box showed that the input shaft was tilted towards the engine, and the original was straight. Guys who were installing it were shimming the box so that it would line up better with the steering coupler.) With both boxes clamped to the work bench the new one seems like it is tilted, while the old one the is straight. This time however, it looks like it is tilted towards the inner fender and not the engine. I'll see how it looks when I bolt it in. Another difference is that the output shaft hangs down a little further. I think the pitman arm will sit a 1/4" lower than the original box.
I plan on bolting it in tomorrow. I still have to make the steering coupler adapter, and figure out the hoses.
Re: New Borgeson Box install. [Re: tahoechallenge] #1720486
01/03/15 02:35 AM
01/03/15 02:35 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Anxious to see your take on the Borg vs. FF.
Mopar to the bone!!!
Re: New Borgeson Box install. [Re: tahoechallenge] #1720487
01/03/15 04:48 AM
01/03/15 04:48 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I sat the new and old side by side to compare... With both boxes clamped to the work bench the new one seems like it is tilted, while the old one the is straight. This time however, it looks like it is tilted towards the inner fender and not the engine... Another difference is that the output shaft hangs down a little further. I think the pitman arm will sit a 1/4" lower than the original box.
Pictures please!
10 to 1 steering ratio??? [Re: 72Swinger] #1720488
01/03/15 05:27 AM
01/03/15 05:27 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
If you use the Fast ratio gear, the 14 to one ratio tightens up to about than 10 to 1. No new car today has a ratio that tight. I hope you are aware of that. It might not be fun if the car feels twitchy.
Re: 10 to 1 steering ratio??? [Re: Kern Dog] #1720489
01/04/15 12:12 AM
01/04/15 12:12 AM
Kings Beach, CA
Kings Beach, CA
Here are a few pictures comparing the new box to the original.
"If you use the Fast ratio gear, the 14 to one ratio tightens up to about than 10 to 1"
This could be a problem. I will just wait and see.
Re: 10 to 1 steering ratio??? [Re: tahoechallenge] #1720490
01/04/15 12:18 AM
01/04/15 12:18 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
I also did this on my car, I even did the firm feel roller bearing idler arm kit upgrade as well. It's 1.7 turns lock to lock with the 350mm wheel which is the exact same as what the high end pro touring camaro guys like big red have. They seem to like it
Re: 10 to 1 steering ratio??? [Re: dangina] #1720491
01/04/15 01:38 AM
01/04/15 01:38 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
It would be cool if a set of arms were available that were in between stock and fast ratio to end up at 12-1 with a Borg.
Re: New Borgeson Box install. [Re: tahoechallenge] #1720492
01/04/15 02:46 AM
01/04/15 02:46 AM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
I know this may be me, but why does this area looked grooved? Is it just the coating or is it physically grooved? It almost looks like someone take large steps in their machining process.
Re: New Borgeson Box install. [Re: MuuMuu101] #1720493
01/04/15 03:20 AM
01/04/15 03:20 AM
Kings Beach, CA
Kings Beach, CA
Those are machine marks. It started off looking like this:
Borgeson then chucked it in a lathe, cut it down, and welded the ears on it for the mopar application.
Re: New Borgeson Box install. [Re: tahoechallenge] #1720494
01/04/15 03:44 AM
01/04/15 03:44 AM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
I don't think you could chuck that on a lather as it looks like one giant cast piece. It almost looks like they fixed it on a CNC mill and took the largest passes they can get away with. No offense, but it kind of shows how Borgeson doesn't give a darn for this product. The box looks terrible, visually. If I were Borgeson or the machinist, I sure as wouldn't want to put my name behind that kind of quality. Even if my product was 100% functional (which this part isn't since it has alignment and pitman arm issues) I wouldn't be happy with that kind of work.
Re: New Borgeson Box install. [Re: MuuMuu101] #1720495
01/04/15 04:49 AM
01/04/15 04:49 AM
Kings Beach, CA
Kings Beach, CA
I agree with that. As far as the look goes; when it is installed in the car it looks a lot better. The angle to the steering coupler seemed good when I installed it today. Time will tell, but I think it will be a good upgrade.
Re: New Borgeson Box install. [Re: tahoechallenge] #1720496
01/04/15 07:42 PM
01/04/15 07:42 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I keep watching these Borgeson threads as the box in my car is up next for replacement. I'm curious if this thing's improvement over a FF box warrants dealing with the headaches I've been reading about.
Anxiously awaiting your results...
Re: New Borgeson Box install. [Re: MarkZ] #1720497
01/04/15 10:40 PM
01/04/15 10:40 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
I'm hoping that the new box does not have headaches:-)
Damon
Re: New Borgeson Box install. [Re: mopardamo] #1720498
01/05/15 06:49 PM
01/05/15 06:49 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Let me explain that this time the box is deliberately angled toward the steering column. This box is narrower than the first iteration, so it would be impossible to put the pitman and sector in the same spot as OE. They chose to put the pitman in the OE spot and turn the box slightly to the driver side to compensate. There are those who will criticize, but the fact remains it will work fine and is a $100 cheaper than the last version with 100% new parts inside. On the exterior, the pressure fitting is larger which I'm in the process of making. Any questions call or PM me.
Re: New Borgeson Box install. [Re: BergmanAutoCraft] #1720499
01/05/15 10:36 PM
01/05/15 10:36 PM
dangina Offline
dangina  Offline
will they compensate those who bought the old box or exchange their old box for a new version?do they have any problems with the nut not fully engaging like on the old ones?
Re: New Borgeson Box install. [Re: tahoechallenge] #1720500
01/06/15 01:14 AM
01/06/15 01:14 AM
Kings Beach, CA
Kings Beach, CA
I was able to bolt the box in without any problems. The coupler alignment came out fine. The offset towards the inner fender shouldn't case any problems. The sector shaft is in almost in the exact space as the original. I am still waiting on fittings. The box uses 16x1.5 inverted flare fittings. I should have that figured out tomorrow.
The only problem so far is reusing my sector support bearing. The nut one the new box is 22x1.5; so the original one won't work. I'll come up with something .
Re: New Borgeson Box install. [Re: tahoechallenge] #1720501
01/06/15 02:37 AM
01/06/15 02:37 AM
Santa Fe Springs, CA
Dan@Hotchkis Offline
Sure does free up a lot of real estate! Doesn't look much bigger than a manual box.
Re: New Borgeson Box install. [Re: Dan@Hotchkis] #1720502
01/06/15 11:35 AM
01/06/15 11:35 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Wish there was some kind of process a customer of Borgeson could use to upgrade their old box for the new one. Im glad they're making an effort to improve on products, but customers doing R&D for them should be worth something to them.
Re: New Borgeson Box install. [Re: tahoechallenge] #1720503
01/06/15 02:59 PM
01/06/15 02:59 PM
Long Island, NY USA
Long Island, NY USA
The only problem so far is reusing my sector support bearing. The nut one the new box is 20x1.5; so the original one won't work. I'll come up with something .
I make the fittings. I had to make a new pressure fitting. Shipping on the 14th.
Re: New Borgeson Box install. [Re: BergmanAutoCraft] #1720504
01/06/15 08:22 PM
01/06/15 08:22 PM
Wildwood, FL
1fastabody Offline
1fastabody  Offline
Wildwood, FL
Bergman, Is there any advantage to the "New" Box over the old version? I have the old version that I have not installed yet and would like to know if there is any benefit to make a switch to the new one? Thanks
Page 1 of 3 1 2 3
