Mopar block repair question #1720426
01/02/15 09:22 PM
01/02/15 09:22 PM
griff70440 Offline OP
Hi Guys,
I found a aftermarket block that had a hair 3" line crack repaired. The crank was in the timing chain area from #1 cam journal down toward the oil pump. the crack wasn't all the way through the block.
I can pick it up cheap... What do you guys think?
It will end up being the home for a 572 race motor.
Mike
Re: Mopar block repair question [Re: griff70440] #1720427
01/02/15 09:36 PM
01/02/15 09:36 PM
birdtracker Offline
birdtracker  Offline
aluminum or steel? Birdtracker
Re: Mopar block repair question [Re: birdtracker] #1720428
01/02/15 09:42 PM
01/02/15 09:42 PM
Steel
Re: Mopar block repair question [Re: griff70440] #1720429
01/02/15 10:57 PM
01/02/15 10:57 PM
birdtracker Offline
birdtracker  Offline
if a cam goes in it and turns freely, on my budget I would give it a shot. Do you think a gear drive caused it or ??????? Who did the repair? Birdtracker
Re: Mopar block repair question [Re: griff70440] #1720430
01/03/15 12:31 AM
01/03/15 12:31 AM
How was it repaired, welded, brazed or stitch lock repair? Also which block, Mopar, World, Indy or Koleno ?
Re: Mopar block repair question [Re: Cab_Burge] #1720431
01/03/15 10:56 PM
01/03/15 10:56 PM
thanks for the replies.
the block is a Mopar block. It looks like it was welded. I took the
to my motor guy today. He thinks the damage was done from a gear drive. The good news is,he thinks the block is very useable.
thanks and Happy New year!
Re: Mopar block repair question [Re: griff70440] #1720432
01/04/15 03:44 AM
01/04/15 03:44 AM
birdtracker Offline
birdtracker  Offline
Rock on! I know the gear drives are suppose to have side clearance. They recommend a piece of newspaper.If it didn't have any I could see it cracking the block. Birdtracker
Re: Mopar block repair question [Re: birdtracker] #1720433
01/04/15 08:51 PM
01/04/15 08:51 PM
I`ll keep you guys posted as the motor starts to go together.
