1970 T-Mast Jack Finish #1719327
01/01/15 03:09 PM
01/01/15 03:09 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
1970 E-Body
I know the color of the mechanism, base and hook are grey (Plasti-kote Federal Gray is suppose to be a good match)
The real question is the t-mast finish, mine appears to be painted silver, silver lacquer would be my guess. Considering the age and condition I'm unable to determine if what I'm seeing is original or if someone dusted it with paint many years ago, though I suspect original untouched. I haven't been able to find much to confirm my findings so looking for input.
Re: 1970 T-Mast Jack Finish [Re: AAR#2] #1719328
01/01/15 05:09 PM
01/01/15 05:09 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Krylon 1401 bright silver,as close to as original you'll ever find.
Re: 1970 T-Mast Jack Finish [Re: 62maxwgn] #1719329
01/01/15 05:25 PM
01/01/15 05:25 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
So the t-masts were simply painted silver?
1401 bright silver is a metallic paint, are you saying this is close to original paint or are you trying to mimic some sort of plating?
The finish on mine was pretty dull but condition and age make it tough to say if it would have ever carried a shine or not. Considering I had no reaction in acid, it's safe to say no zinc coating was present.
Just trying to be sure on this prior to refinishing
Re: 1970 T-Mast Jack Finish [Re: AAR#2] #1719330
01/01/15 08:34 PM
01/01/15 08:34 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
You can't really notice the metallic on cast steel.I have the original untouched jack in my Superbird,I just recently did a 69 b-body jack and they are almost identical.
Re: 1970 T-Mast Jack Finish [Re: 62maxwgn] #1719331
01/02/15 12:14 AM
01/02/15 12:14 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Appreciate the input, would love to see that Superbird jack, heck, would love to see that Superbird.
Re: 1970 T-Mast Jack Finish [Re: AAR#2] #1719332
01/02/15 12:21 AM
01/02/15 12:21 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
From the low mile T/A, AAR jacks were painted the same.
Re: 1970 T-Mast Jack Finish [Re: AAR#2] #1719333
01/02/15 01:02 AM
01/02/15 01:02 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Car now,jack later !
Re: 1970 T-Mast Jack Finish [Re: 62maxwgn] #1719334
01/02/15 01:04 AM
01/02/15 01:04 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Another
Re: 1970 T-Mast Jack Finish [Re: 62maxwgn] #1719335
01/02/15 01:06 AM
01/02/15 01:06 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Last one.
Re: 1970 T-Mast Jack Finish [Re: AAR#2] #1719336
01/02/15 01:07 AM
01/02/15 01:07 AM
MD
floyd Offline
floyd  Offline
MD
I've used Mopar Rallye wheel paint with good results.
Re: 1970 T-Mast Jack Finish [Re: floyd] #1719337
01/02/15 01:23 PM
01/02/15 01:23 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Funny you should say that, while the finish on mine was pretty beat up it appeared exactly like the outstanding quality photo in Barry's picture (thanks for posting Barry), and I thought it looked a lot like the lacquer rallye wheel paint.
Thanks to all for helping!
Re: 1970 T-Mast Jack Finish [Re: AAR#2] #1719338
01/02/15 02:29 PM
01/02/15 02:29 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Would you like to guess what has been on these wheels for the last 23 yrs ?
Re: 1970 T-Mast Jack Finish [Re: AAR#2] #1719339
01/02/15 04:45 PM
01/02/15 04:45 PM
MetroWest, MA.
BeeOrange Offline
BeeOrange  Offline
MetroWest, MA.
I have used Mopar Rallye Wheel Paint a few times witrh excellent results.
70 Super Bee FK5 383 4-Speed
68 GTX RR1 426 Auto
70 Cuda FC7 440 Auto
Psalm 37:5: Commit your way to the Lord; trust also in Him and He will do it
Re: 1970 T-Mast Jack Finish [Re: BeeOrange] #1719340
01/04/15 04:08 PM
01/04/15 04:08 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
After further thought and a debate with a friend, we noticed the paint on the mast was pretty tough stuff, not easily scratched or chipped, didn't blister with aircraft stripper and showed no sign of being affected with a brief dip in acid, though it obviously wore on the edges over time with use. This made us think it may be a high solid zinc based paint, often referred to as cold galvanized. This may explain why it seems to hold up pretty well over the years even when used. There are many brands on the market, some paint brush and some aerosol, most seem to be a silvery grey.
Has anyone tried using this? Results?
I'm planning to give this a try as I think it will hold up better than typical paint
Re: 1970 T-Mast Jack Finish [Re: AAR#2] #1719341
01/04/15 05:38 PM
01/04/15 05:38 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
I always thought the mast was plated by the manufacturer, not painted. Is that why the paint remover and acid will not touch the finish on the jack mast?
If it were painted, a couple times using the jack would take any paint right off down to metal, then the jack would rust in the leaky trunk in Seattles 8 month long rainy season, making the jack useless.
Re: 1970 T-Mast Jack Finish [Re: NANKET] #1719342
01/04/15 06:39 PM
01/04/15 06:39 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
I always thought the mast was plated by the manufacturer, not painted. Is that why the paint remover and acid will not touch the finish on the jack mast? . . .
Normally zinc plating will be removed when placed in a diluted muriatic acid bath (begins to fizz), mine did not when subjected to the bath. The only thing that seemed to affect it was lacquer thinner, pulling the silver finish but looked gray on the rag.
I agree paint may mimic the finish, but wouldn't hold up the way most jacks seem to, even when I run across them in junk yards. This is why I was thinking heavy zinc solid paint, though I must admit I'm unsure if the zinc is somehow protected from the acid in a paint base.
Heavy zinc paint is often used to protect fencing and farm equipment exposed to the elements, and does it with very good results.
As long as I can find a color that appears to match relatively well, I believe it would be a much more durable finish than the silver paint I was originally planning to apply.
Re: 1970 T-Mast Jack Finish [Re: AAR#2] #1719343
01/04/15 06:48 PM
01/04/15 06:48 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
My jack stem is di-chromate('71 Ply B-body)...
Doing well after being re-plated 20 years ago...
If you want longevity, talk to a plater...
Re: 1970 T-Mast Jack Finish [Re: RSNOMO] #1719344
01/04/15 07:36 PM
01/04/15 07:36 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
If your jack is dichromate its likely a tube jack and not a T-jack. I love plating and would prefer it, but if it isn't correct, I'll stay away.
Re: 1970 T-Mast Jack Finish [Re: AAR#2] #1719345
01/05/15 12:15 PM
01/05/15 12:15 PM
SE Pa.
LimeliteAero Offline
SE Pa.
AAR#2
Ive been following along and would appreciate knowing what you decide to do.
I agree its seemingly something other than simply paint on the mast.
