Page 1 of 3 1 2 3
super stock leaf springs #1718022
12/30/14 07:35 PM
12/30/14 07:35 PM
new brunswick , canada
bigblocka Offline OP
just bought a set of 002/003 springs and was told that i need 1" longer shackle kit.
any info on this and any other tips on set up would be appreciated.
Re: super stock leaf springs [Re: bigblocka] #1718023
12/30/14 07:38 PM
12/30/14 07:38 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
The front segment on the SS springs is shorter than on the stockers. You need a longer front spring hanger unless it's an A body.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: super stock leaf springs [Re: Steve1118] #1718024
12/30/14 07:46 PM
12/30/14 07:46 PM
sorry, it is a 72 demon small block 340.
so with it being a a-body i can use the standard length shackles?
Re: super stock leaf springs [Re: bigblocka] #1718025
12/30/14 07:54 PM
12/30/14 07:54 PM
Cab_Burge Online work
Cab_Burge  Online Work
Yes you can The 1962 and 1963 B and A bodys had a 20 inch front segment on all leaf springs, Mopar decided to lengthen the B bodys in 1964 to 22 front segments, why only the Engineers know Those springs work awesome for drag racing
Re: super stock leaf springs [Re: Cab_Burge] #1718026
12/30/14 08:06 PM
12/30/14 08:06 PM
any other tips on set up. ie shocks,clamps etc
Re: super stock leaf springs [Re: bigblocka] #1718027
12/30/14 08:15 PM
12/30/14 08:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Get some good adjustable shocks.. and most likely you
will be un-clamping the rear segments.. depending on the
shocks and power
Re: super stock leaf springs [Re: bigblocka] #1718028
12/30/14 09:28 PM
12/30/14 09:28 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Yes. If you are going from stock springs to Super Stock springs check your pinion angle before racing or driving the car at a high speed. 30+ years ago I fought one heck of a vibration because they threw mine off. The proper shims can be purchased. Back then we didn't have internet forums to help figure these issues out.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: super stock leaf springs [Re: pittsburghracer] #1718029
12/30/14 09:38 PM
12/30/14 09:38 PM
what is the recommended pinion angle?
pinion snubber or no?
Re: super stock leaf springs [Re: bigblocka] #1718030
12/30/14 09:50 PM
12/30/14 09:50 PM
PA.
"Little"John
"Little"John
PA.
I just posted that because it does need checked and possibly adjusted. Mine did and the vibration was terrible. Some of these turn into ugly arguments so I will post a link and you can see what may be needed.
http://www.moparts.org/Tech/Archive/axle/8.html
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: super stock leaf springs [Re: pittsburghracer] #1718031
12/30/14 09:53 PM
12/30/14 09:53 PM
PA.
"Little"John
"Little"John
PA.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: super stock leaf springs [Re: pittsburghracer] #1718032
12/30/14 10:11 PM
12/30/14 10:11 PM
thanks for the info.
Re: super stock leaf springs [Re: Cab_Burge] #1718033
12/31/14 03:50 AM
12/31/14 03:50 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Not sure, i'll have to check, but my 64 savoy were 21 inch front segments.
Re: super stock leaf springs [Re: Cab_Burge] #1718034
12/31/14 02:14 PM
12/31/14 02:14 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Cab its 21 in early 64 65s.My 65 has a 21 inch frt segment.22 didnt come out till 66.Rocky
Chrysler Firepower
Re: super stock leaf springs [Re: bigblocka] #1718035
12/31/14 05:27 PM
12/31/14 05:27 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
The rear bushing on your SS spring require a (7/8 o.d. x 1/2 i.d.) bushing. A-body shackles bolts are .50" shank compared to the B/E which are .5625" or 9/16" shank bolt and use a 1.0" o.d. bushing.
If you are going to use a longer shackle, make sure they accomodate the smaller 7/8" bushing (Moog K7309 or Rabestos 576-3026) found on the SS springs.
Just curious, why or where a longer shackle is required?
Re: super stock leaf springs [Re: cruzin] #1718036
12/31/14 05:29 PM
12/31/14 05:29 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Think he was referring to front spring hanger...
Re: super stock leaf springs [Re: GY3] #1718037
12/31/14 05:58 PM
12/31/14 05:58 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
My bad... Shackle / hanger, same thing?
Re: super stock leaf springs [Re: cruzin] #1718038
12/31/14 06:02 PM
12/31/14 06:02 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
You say tomato, I say banana....
Re: super stock leaf springs [Re: GY3] #1718039
01/01/15 02:47 AM
01/01/15 02:47 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Tires will hit harder with longer shackles.
Besides front spring eye height and the number/location of spring clamps, different shackle lengths are another tuning aid for leaf springs.
Re: super stock leaf springs [Re: B5 Bee] #1718040
01/01/15 02:26 PM
01/01/15 02:26 PM
so this would be a trial and error on different length shackle?
Re: super stock leaf springs [Re: bigblocka] #1718041
01/01/15 03:58 PM
01/01/15 03:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
There`s going to be LOTS of trial and error especially if your making decent power.............60`s tech in 2015...........
Page 1 of 3 1 2 3
