How many folks keep there diesel truck plugged in full #1717988
12/30/14 06:58 PM
12/30/14 06:58 PM
Cincinnati, Ohio
Challenger 1 Offline OP
Cincinnati, Ohio
Time??
What's the longest that you have had it plugged in for?
Re: How many folks keep there diesel truck plugged in full [Re: Challenger 1] #1717989
12/30/14 07:52 PM
12/30/14 07:52 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
never plug either of mine in (have to cycle the key once in a while)Dont see why you couldnt leave them plugged in 24/7, its a low wattage heater so no boiling should occur.
If you did plug one in the only reson I can see for unplugging it would be save on the electric bill and to prevent pulling the socket out of the wall when you drive away which for me is teh biggest reason not to plug one in,
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: How many folks keep there diesel truck plugged in full [Re: W.I.N. Racing] #1717990
12/30/14 10:56 PM
12/30/14 10:56 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I always plugged mine overnight when it got real cold out. I always leave my vehicles plugged at work even when not that cold, no reason not to.
Re: How many folks keep there diesel truck plugged in full [Re: Challenger 1] #1717991
12/30/14 11:12 PM
12/30/14 11:12 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I never plug my Dodge-Cummins in, that's what the GRID heater is for. My work Cummins and Volvo get plugged in if it gets down to zero Fahrenheit and the old Ford and GM diesels needed plugging in below about 10 fahrenheit it seems.
I've started a Dodge Cummins at -40 not plugged in overnight.
Sheldon
Re: How many folks keep there diesel truck plugged in full [Re: RUNCHARGER] #1717992
12/30/14 11:28 PM
12/30/14 11:28 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Sheldon
As he says...A Cummins will start at almost absurd low temperatures without the block heater plugged in. I use mine occasionally, but it's more for the convenience of having a luke warm block so the windows defrost quicker. We get the "foggy" cold on the coast and the vehicle is usually covered with thick frost on a -10 morning. And diesels take frigging forever to warm up....
Re: How many folks keep there diesel truck plugged in full [Re: superwrench] #1717993
12/31/14 12:31 AM
12/31/14 12:31 AM
Manitoba, Canada
Manitoba, Canada
-25c or below and my 24v wouldn't start if not plugged. She'd just suck the batteries dry. I liked having it plugged anyway, would warm up and get some heat flowing way quicker.
Re: How many folks keep there diesel truck plugged in full [Re: DaytonaTurbo] #1717994
12/31/14 02:16 AM
12/31/14 02:16 AM
RUNCHARGER Offline
RUNCHARGER  Offline
They do take forever to warm up even with a covered rad and on high idle. That's why I recommend a gas pickup for just about anybody these days. My nephew has a Webasto on his 05 and that's the answer for sure but not cheap.
Sheldon
Re: How many folks keep there diesel truck plugged in full [Re: RUNCHARGER] #1717995
12/31/14 01:59 PM
12/31/14 01:59 PM
Plymouth, MI
Blusmbl Online content
Blusmbl  Online Content
Plymouth, MI
All of the newer diesels can start unassisted at -40 pretty easily. The block heater helps with engine wear though- it takes much longer than you'd expect to build oil pressure at those temps. If you plug it in, even if it's just for an hour or two before you'd want to start the truck, the oil will flow much easier and the crank speed will be faster.
Re: How many folks keep there diesel truck plugged in full [Re: superwrench] #1717996
12/31/14 02:54 PM
12/31/14 02:54 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I used to until the plug melted down one day. I do not need a garage fire just to keep the diesel warm. My '03 starts very easily in the coldest weather we have had without plugging it in.
Re: How many folks keep there diesel truck plugged in full [Re: Dragula] #1717997
12/31/14 03:06 PM
12/31/14 03:06 PM
Guitar Jones Offline
I plug mine in before I go to bed if it's going to get to 40 degrees or colder overnight. Not for the truck but for me, nearly instant heat. BRRR.
Re: How many folks keep there diesel truck plugged in full [Re: Guitar Jones] #1717998
12/31/14 05:54 PM
12/31/14 05:54 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
My first winter with a diesel. And it's been mild. Just got the cord for the heater, haven't needed it yet, but I'm looking forward to having heat in the truck right away instead of having to drive 15 minutes before the temp needle even moves.
**Photobucket sucks**
Re: How many folks keep there diesel truck plugged in full [Re: 70Cuda383] #1717999
12/31/14 10:38 PM
12/31/14 10:38 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
My 92 left me stranded on the road a couple of times because I couldn't plug it in at a motel. My 04 never needed to be plugged in. At work we plug the Internationals in (MaxxForce junk) 24/7 and only unplug them when we are ready to drive them.
JB Rhinehart, Realist
A-Body's RULE!
Re: How many folks keep there diesel truck plugged in full [Re: Rhinodart] #1718000
01/01/15 05:40 PM
01/01/15 05:40 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I leave mine plugged in all winter. It was -5F here earlier this week.
Re: How many folks keep there diesel truck plugged in full [Re: camastomcat] #1718001
01/02/15 01:19 AM
01/02/15 01:19 AM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
I keep mine plugged in too.
Re: How many folks keep there diesel truck plugged in full [Re: Michael] #1718002
01/02/15 06:08 PM
01/02/15 06:08 PM
Canada
Lugnutz Offline
Lugnutz  Offline
Canada
I try not to drive mine in the winter so they sit unplugged unless I need to drive one, then I plug in night before.
Both 12V one is a 1st gen the other is a 2nd gen.
Rhino, hard to believe your 1st gen wouldn't start. I've left mine sit all day while hunting in -30 and come back to and it fires up. Shakes and rattles for a bit but then smooth's itself right out. It just has to spin a quarter turn and they fire....
Re: How many folks keep there diesel truck plugged in full [Re: Lugnutz] #1718003
01/02/15 08:57 PM
01/02/15 08:57 PM
Manitoba, Canada
Manitoba, Canada
Yeah but a first gen with only a single battery, if that starts to get marginal at all you're in trouble!
Re: How many folks keep there diesel truck plugged in full [Re: DaytonaTurbo] #1718004
01/03/15 12:23 AM
01/03/15 12:23 AM
Canada
Lugnutz Offline
Lugnutz  Offline
Canada
I don't let it get marginal. I do live here and am familiar with our temps and weather...
Re: How many folks keep there diesel truck plugged in full [Re: DaytonaTurbo] #1718005
01/03/15 12:23 AM
01/03/15 12:23 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
My 94 12 valve sat in a parking lot for a full day in -36c, started up no hesitation. My newer 2006, same deal, but I plug them in when home.. I think a lot had to do with the fuel grade and quality, if its really winter blended fuel it won't gel up.
Re: How many folks keep there diesel truck plugged in full [Re: Uberpube] #1718006
01/03/15 03:18 AM
01/03/15 03:18 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I plug my '95 in when the temperature gets below freezing. If I don't plug it in, it starts, but it takes forever to warm up enough to idle smoothly.
Re: How many folks keep there diesel truck plugged in full [Re: DaytonaTurbo] #1718007
01/03/15 03:38 PM
01/03/15 03:38 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Yep, mine even had a new battery in it! It could have been a fuel issues also, had to have it towed into a heated garage the to thaw out the first time it happened.
A-Body's RULE!
