fuel pump #1717418
12/29/14 03:43 PM
12/29/14 03:43 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
2004 CTD,where is the fuel pump.it has a lift pump and I always thought that ment the fuel pump was external.but I cant seem to locate it. THANKS,AJ
Re: fuel pump [Re: bonefish] #1717419
12/29/14 06:05 PM
12/29/14 06:05 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Sorry, but your fuel (lift) pump is in the tank. I had a 2002 and its pump was on the side of the motor behind the fuel filter housing. Mopar's answer to the problem (weak, failing lift pumps causing failure of the VP44 injection pump)was to put it in the tank. This makes sense, in that they could install an assembly in one piece on the production line, but if yours fails then you have to drop the tank, fish it out and install a new OEM unit. A better solution is to mount a pump (like a FASS DDRP) on the frame rail behind a debris shield so that it could be serviced without dropping the tank. A lot cheaper, too. That is what I did to my 2002 and it is still going.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: fuel pump [Re: bonefish] #1717420
12/29/14 09:00 PM
12/29/14 09:00 PM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
If its an early 2004 it may have an external pump attached to the back of the fuel filter canister. A lot of them were "upgraded" to the in-tank pump as they failed.
Re: fuel pump [Re: bonefish] #1717421
12/30/14 12:24 AM
12/30/14 12:24 AM
central Florida
VL21 Offline
VL21  Offline
central Florida
And it is easier to move the bed than drop a tank.
Especially when it has fuel in it.
It takes gasoline to interest me.
Re: fuel pump [Re: VL21] #1717422
12/30/14 11:33 AM
12/30/14 11:33 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
Ok I think ive got the terminoligy down.what they call the lift pump is actually the fuel pump.mine is external,because ive already had it replaced once.Now 5 thou.mi. later its acting up again.its a Autozone unit.is there a more QUALITY unit that can be purchased?
Re: fuel pump [Re: bonefish] #1717423
12/30/14 08:18 PM
12/30/14 08:18 PM
Byron, NY
W.I.N. Racing Online content
W.I.N. Racing  Online Content
Byron, NY
Look here
www.bluechipdiesel.com
The lift pump is the low pressure pump that supplies the fuel from the tank to the High pressure pump. The high pressure pump is what supplies the injectors.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: fuel pump [Re: W.I.N. Racing] #1717424
12/31/14 12:31 AM
12/31/14 12:31 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
Look here
that's a good web site,they seem to know their stuff.
Re: fuel pump [Re: bonefish] #1717425
12/31/14 01:19 AM
12/31/14 01:19 AM
Byron, NY
Byron, NY
Just recently purchased a Pressure pump from them, great service and product.
'60 Willys CJ5
Re: fuel pump [Re: W.I.N. Racing] #1717426
12/31/14 03:29 AM
12/31/14 03:29 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
Genos is also another option for a transfer pump.
http://www.genosgarage.com/Fuel-System/departments/92/
Re: fuel pump [Re: Tom_440] #1717427
12/31/14 10:55 AM
12/31/14 10:55 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
these are some great web sites.im a DIY kinda guy and my truck is getting some age to it.i guess my next big investment should be a scan tool.
