Re: fuel pump
[Re: bonefish]
#1717419
12/29/14 06:05 PM
12/29/14 06:05 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Sorry, but your fuel (lift) pump is in the tank. I had a 2002 and its pump was on the side of the motor behind the fuel filter housing. Mopar's answer to the problem (weak, failing lift pumps causing failure of the VP44 injection pump)was to put it in the tank. This makes sense, in that they could install an assembly in one piece on the production line, but if yours fails then you have to drop the tank, fish it out and install a new OEM unit. A better solution is to mount a pump (like a FASS DDRP) on the frame rail behind a debris shield so that it could be serviced without dropping the tank. A lot cheaper, too. That is what I did to my 2002 and it is still going.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
Re: fuel pump
[Re: bonefish]
#1717421
12/30/14 12:24 AM
12/30/14 12:24 AM
Posts: 1,357 central Florida
VL21
central Florida
And it is easier to move the bed than drop a tank. Especially when it has fuel in it.
It takes gasoline to interest me.
Re: fuel pump
[Re: bonefish]
#1717423
12/30/14 08:18 PM
12/30/14 08:18 PM
Posts: 2,102 Byron, NY
W.I.N. Racing
Byron, NY
Look here www.bluechipdiesel.comThe lift pump is the low pressure pump that supplies the fuel from the tank to the High pressure pump. The high pressure pump is what supplies the injectors.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: fuel pump
[Re: W.I.N. Racing]
#1717424
12/31/14 12:31 AM
12/31/14 12:31 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
that's a good web site,they seem to know their stuff.
Re: fuel pump
[Re: bonefish]
#1717425
12/31/14 01:19 AM
12/31/14 01:19 AM
W.I.N. Racing
Byron, NY
Just recently purchased a Pressure pump from them, great service and product.
