Front Drum Brakes E Bodies #171731
12/20/08 04:16 PM
12/20/08 04:16 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Did the front drums on the Cudas/Challengers have the hub built into the drum or was there a separate hub on the knuckle? I was helping my friend do the brakes on his 68 Camaro and the front drums slide on and off a hub. Thought that was a little ahead of theirs times.
Grandma always said I had "hands of gold"!
Re: Front Drum Brakes E Bodies [Re: CHRGR69] #171732
12/20/08 04:23 PM
12/20/08 04:23 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Most front drums have the lug studs swaged which holds the drum to the hub. I think GM did this too but many times the drums are replaced and the studs aren't swaged because it requires special tooling.
The pic below shows the stud before and after swaging.
Re: Front Drum Brakes E Bodies [Re: CHRGR69] #171733
12/20/08 04:48 PM
12/20/08 04:48 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
I guess what I'm asking is does the drum mount to a spindle with bearings or slide onto a lugged hub?
Re: Front Drum Brakes E Bodies [Re: CHRGR69] #171734
12/20/08 05:15 PM
12/20/08 05:15 PM
yes
