70 challenger RT battery #1715846
12/26/14 01:13 PM
12/26/14 01:13 PM
Nebraska, USA
David68charger Offline OP
Nebraska, USA
What is the correct color top battery for my 70 Challenger RT 383 magnum?
David
Re: 70 challenger RT battery [Re: David68charger] #1715847
12/26/14 02:30 PM
12/26/14 02:30 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
It depends on how it was optioned. If you have a broadcast sheet for it, what code is in the battery box on line 7?
Re: 70 challenger RT battery [Re: David68charger] #1715848
12/26/14 06:29 PM
12/26/14 06:29 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
As mentioned above by Alaskan TA, you need the broadcast sheet code to be sure. It depends if the car had the standard equipment Group 24 battery, or the optional Group 27.
I believe the chart in the link below is correct.
http://www.mymopar.com/index.php?pid=83
Re: 70 challenger RT battery [Re: moparfan53] #1715849
12/27/14 12:56 AM
12/27/14 12:56 AM
Nebraska, USA
Nebraska, USA
Thanks. Take care. It looks like yellow.
