reaction time practice??? #1715337
12/25/14 02:45 AM
12/25/14 02:45 AM
birdtracker Offline OP
So my son bought me a Porta -Tree for Christmas. So what was your biggest tip that helped you out with your reaction times? And yes mine are all over the place. thanks. Birdtracker
Re: reaction time practice??? [Re: birdtracker] #1715338
12/25/14 02:58 AM
12/25/14 02:58 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
practice 10 goes at a time. after a while you'll see your average get lower n lower
if you practice too much you'll loose any edge you've gained
Re: reaction time practice??? [Re: rebel] #1715339
12/25/14 03:01 AM
12/25/14 03:01 AM
thanks Rebel. I plan on staying at it until spring. Birdtracker
Re: reaction time practice??? [Re: birdtracker] #1715340
12/25/14 03:08 AM
12/25/14 03:08 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Top bulb or bottom bulb racer?
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: reaction time practice??? [Re: birdtracker] #1715341
12/25/14 03:18 AM
12/25/14 03:18 AM
NC
barracuda man Offline
NC
Get as much seat time as u can.do the same thing every round.Your burnout/stage/ect.adjust air pressure if needed and race the finish line always.
Re: reaction time practice??? [Re: birdtracker] #1715342
12/25/14 05:40 AM
12/25/14 05:40 AM
Locomotion Offline
Locomotion  Offline
Practice, practice, practice. Get into a routine so you don't even have to think about what you are doing while staging, bringing the rpm's up, etc. YOU get consistent regardless of the actual RT's. Then make changes to the car to adjust the RT's as needed, not yourself. (i.e.: tire diameter, air pressure, staging rpm's, etc.) A person is normally not able to change his/her reactions consistently. Do it mechanically.
Lot's of variable in your car will affect how much you can mechanically adjust/change - converter, condition of the brakes, carb set up (ESPECIALLY if footbraking), traction, firmness/slop in the chassis/suspension, etc.
Rollout does vary from track-to-track and can from lane-to-lane. Your reactions can vary from day-to-day or even within a day. How much sleep did you get? What's on your mind? Did you drink a lot of caffeinated/sugared coffee, Mountain Dew, etc.? Are you hungry?
Your results may vary. Each person is different just like each vehicle can be different. Some people and some vehicles just aren't easily adapted to cut good, consistent reaction times. But try to get YOUR consistency down first. Narrow down your "range", then work on getting that range closer to .000 on the "green" side.
Re: reaction time practice??? [Re: Locomotion] #1715343
12/25/14 08:32 AM
12/25/14 08:32 AM
Q
Quicktree Offline
Quicktree  Offline
Q
take
take this guys advice he's pretty dang good. almost as good the tree
Re: reaction time practice??? [Re: Quicktree] #1715344
12/25/14 10:45 AM
12/25/14 10:45 AM
gregsdart Offline
gregsdart  Offline
Practicing in the car, going through your entire sequence from burnout to launch is important to keeping your mind focused for the race. If you can wire the switch in the car to run the practice tree then you have it all. A mindset of not letting anything other than your bulb into your thinking is key. Any odd thoughts and the reaction time is toast.
Re: reaction time practice??? [Re: Quicktree] #1715345
12/25/14 10:58 AM
12/25/14 10:58 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Frank Hawely said years ago to be thinking about lifting your thumb off that trans brake button the whole time, that way that part is already done in your mind. lol
Get in your car in the garage and do the run mentally many times in your head to where like Locomotion said it becomes a routine. Because in drag racing you don't get much seat time compared to like round track racing.
I found staying to myself and thinking about the run before in the staging lanes helped me. That and I also ate cold fresh red grapes before every run, it definitely helped me, red grapes.
Re: reaction time practice??? [Re: Challenger 1] #1715346
12/25/14 11:15 AM
12/25/14 11:15 AM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
If your a bottom bulb racer, get the led bulbs. I'm a top bulb racer, so I only had to replace the top one on both sides. The rest all the way down the tree have insulators in the sockets so they won't light up. Before I went to the led's I was seeing spots after a couple hits.
Re: reaction time practice??? [Re: Quicktree] #1715347
12/25/14 11:16 AM
12/25/14 11:16 AM
Az
Crizila Offline
Crizila  Offline
Az
take
-and practice during your down time.
Fastest 300
Re: reaction time practice??? [Re: Crizila] #1715348
12/25/14 01:18 PM
12/25/14 01:18 PM
thats a serious racer! Birdtracker
Re: reaction time practice??? [Re: birdtracker] #1715349
12/25/14 08:36 PM
12/25/14 08:36 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I need vitamin B supplements or I'm in trouble. Being a top-bulb racer I installed a switch in my daily driver, now every traffic light is a practice tree. You need your reaction to the tree to be an involuntary one, that's what practice does for you. Once you find yourself reacting to lights even if you get distracted or your mind wanders you know you're getting there.
Re: reaction time practice??? [Re: Crizila] #1715350
12/25/14 09:49 PM
12/25/14 09:49 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
take
That's the unit I have. (with a foot pedal) I noticed I have to see the yellow and think(click) before I go bang(hit the pedal).
Yeah, it's got a smallblock.
Re: reaction time practice??? [Re: Quicktree] #1715351
12/26/14 03:58 PM
12/26/14 03:58 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Practice!!! You need to shoot for a small window and work form there. What I am referring to is trying to get your reaction times to fall in a small grouping, say a few thousands on a regular basis. That is what you are shooting for with a practice tree.
Re: reaction time practice??? [Re: Al_Alguire] #1715352
12/26/14 06:17 PM
12/26/14 06:17 PM
Az
Crizila Offline
Crizila  Offline
Az
- and then adjusting the car so that small grouping falls under .030. Very difficult without electronics and a moving target DA. You often have to go 5 rounds to get to the finals - and they all better be under .030 or it won't make any difference how close you are to your dial.
Fastest 300
Re: reaction time practice??? [Re: Crizila] #1715353
12/26/14 08:34 PM
12/26/14 08:34 PM
Ohio
Chad Bittle Offline
Chad Bittle  Offline
Ohio
For me....consistency. From the time I pull into the waterbox until I turn the stage bulb on. Everything the same, every time.
Re: reaction time practice??? [Re: Chad Bittle] #1715354
12/26/14 09:30 PM
12/26/14 09:30 PM
Az
Crizila Offline
Crizila  Offline
Az
That's a gimme there. There is still a lot of distractions that pop up that are out of your control. Pic - waiting for a clean up in "isle 2" and some guy comes over to my car and introduces himself while I am in the "holding pattern". Ran dead nuts on my dial ( 10.67 ) and had a shatty reaction time - and lost.
Fastest 300
Re: reaction time practice??? [Re: Crizila] #1715355
12/31/14 06:16 PM
12/31/14 06:16 PM
Up a holler, down a crick
booger Offline
booger  Offline
I've been working on this over the holidays since I'm off work.
The stats show I'm not doing too good, but I'll use the excuse that I'm trying hard to find/fix bugs, not to cut a good light.
I'm in process of adding top-bulb play capability, and it's already got adjustable dial-ins with staggered timing and adjustable roll-out.
It currently only runs on a PC/laptop but I really should go ahead and port it to a phone/tablet.
Chasing bears through the woods drunk with a dull hatchet is strongly not advised
Re: reaction time practice??? [Re: booger] #1715356
12/31/14 06:23 PM
12/31/14 06:23 PM
is that something you found on the web? I have been practicing now for a few weeks and my times have improved. Plan on staying with it even after the season starts. Birdtracker
