Re: reaction time practice???
[Re: birdtracker]
#1715340
12/25/14 03:08 AM
12/25/14 03:08 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Top bulb or bottom bulb racer?
[Re: birdtracker]
#1715342
12/25/14 05:40 AM
12/25/14 05:40 AM
Posts: 5,894 Florida
Locomotion
Practice, practice, practice. Get into a routine so you don't even have to think about what you are doing while staging, bringing the rpm's up, etc. YOU get consistent regardless of the actual RT's. Then make changes to the car to adjust the RT's as needed, not yourself. (i.e.: tire diameter, air pressure, staging rpm's, etc.) A person is normally not able to change his/her reactions consistently. Do it mechanically.
Lot's of variable in your car will affect how much you can mechanically adjust/change - converter, condition of the brakes, carb set up (ESPECIALLY if footbraking), traction, firmness/slop in the chassis/suspension, etc.
Rollout does vary from track-to-track and can from lane-to-lane. Your reactions can vary from day-to-day or even within a day. How much sleep did you get? What's on your mind? Did you drink a lot of caffeinated/sugared coffee, Mountain Dew, etc.? Are you hungry?
Your results may vary. Each person is different just like each vehicle can be different. Some people and some vehicles just aren't easily adapted to cut good, consistent reaction times. But try to get YOUR consistency down first. Narrow down your "range", then work on getting that range closer to .000 on the "green" side.
[Re: Locomotion]
#1715343
12/25/14 08:32 AM
12/25/14 08:32 AM
Quicktree
take Quote:
take this guys advice he's pretty dang good. almost as good the tree
[Re: Quicktree]
#1715344
12/25/14 10:45 AM
12/25/14 10:45 AM
Posts: 10,000 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Practicing in the car, going through your entire sequence from burnout to launch is important to keeping your mind focused for the race. If you can wire the switch in the car to run the practice tree then you have it all. A mindset of not letting anything other than your bulb into your thinking is key. Any odd thoughts and the reaction time is toast.
[Re: Quicktree]
#1715347
12/25/14 11:16 AM
12/25/14 11:16 AM
Posts: 7,506 Az
Crizila
Az
takeQuote:
-and practice during your down time.
Fastest 300
[Re: Crizila]
#1715350
12/25/14 09:49 PM
12/25/14 09:49 PM
Posts: 1,532 off the grid
340B5
off the grid
takeQuote:
That's the unit I have. (with a foot pedal) I noticed I have to see the yellow and think(click) before I go bang(hit the pedal).
Yeah, it's got a smallblock.
[Re: Quicktree]
#1715351
12/26/14 03:58 PM
12/26/14 03:58 PM
Posts: 19,366 Las Vegas
Al_Alguire
Las Vegas
Practice!!! You need to shoot for a small window and work form there. What I am referring to is trying to get your reaction times to fall in a small grouping, say a few thousands on a regular basis. That is what you are shooting for with a practice tree.
[Re: Crizila]
#1715355
12/31/14 06:16 PM
12/31/14 06:16 PM
Posts: 836 Up a holler, down a crick
booger
I've been working on this over the holidays since I'm off work.
The stats show I'm not doing too good, but I'll use the excuse that I'm trying hard to find/fix bugs, not to cut a good light.
I'm in process of adding top-bulb play capability, and it's already got adjustable dial-ins with staggered timing and adjustable roll-out.
It currently only runs on a PC/laptop but I really should go ahead and port it to a phone/tablet.
Chasing bears through the woods drunk with a dull hatchet is strongly not advised
