Ram leveling kit #1714903
12/24/14 01:09 PM
12/24/14 01:09 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I have been considering a 4x4 truck anywhere from a 1998 to a 2006. The question that I have is which ones still run torsion bars and which were switched to coil springs. From what little research I have done it appears that they ran torsion bars on the 1500s for a few years into the 2000s with the 2500s getting the springs.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Ram leveling kit [Re: cdstl] #1714904
12/24/14 01:34 PM
12/24/14 01:34 PM
ND
dodgedon Offline
dodgedon  Offline
ND
none of the 94-2006 1500 2500 trucks have torsion bars. just the Dakota and Durango's
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: Ram leveling kit [Re: dodgedon] #1714905
12/24/14 01:53 PM
12/24/14 01:53 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
What are the 2002 and up 1500's using if not torsion bars. I never looked.
Re: Ram leveling kit [Re: dodgedon] #1714906
12/24/14 01:56 PM
12/24/14 01:56 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
OK, good news. I have a '96 Dakota and am aware of the TBs. I have been looking at a bigger truck and decided to look into the kits. On youtube a guy is claiming to level an '03 1500 and he is messing with TBs.
What is the preferred method for leveling, using a spacer or taller springs?
edit: After looking some more I am seeing TB keys that are available for the '02-'05 1500 4x4s. The guy on the video claimed to be doing an '03 1500 4x4 using a different TB key. I doubt that they have coil springs as well.
http://www.roughcountry.com/suspension-lift-kits/dodge-suspension-lift-kits.html
Anyone?
Re: Ram leveling kit [Re: cdstl] #1714907
12/24/14 03:08 PM
12/24/14 03:08 PM
ND
dodgedon Offline
dodgedon  Offline
ND
Yes, I stand corrected the 2002 + 1500 does have torsion bars
67 Charger 383 auto
Re: Ram leveling kit [Re: dodgedon] #1714908
12/24/14 04:26 PM
12/24/14 04:26 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
topguncustomz.com I got my 2 inch leveling kit from them
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Ram leveling kit [Re: dodgedon] #1714909
12/24/14 04:36 PM
12/24/14 04:36 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
You will be disappointed if you truly want the truck level.
All of these kits are advertised as 2 to 2 1/2" and thats' exactly what you get: the front-end riding higher than the back.
Mo' Farts
Moderated by "tbagger".
Re: Ram leveling kit [Re: Grizzly] #1714910
12/24/14 04:38 PM
12/24/14 04:38 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
2
Mo' Farts
Re: Ram leveling kit [Re: Grizzly] #1714911
12/24/14 09:53 PM
12/24/14 09:53 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I have air bags in the rear to help when pulling my trailer, so I can keep the truck level if I am towing or not. Even with out any air in the bags it sits level. When I bought the truck new it sat higher in the rear and I didn`t like the look so I put in the leveling kit, I only wish I would have went to a 2 1/2 instead of a 2 kit.
68 Dart 410 / 904
23 Audi Q5
16 Honda HRV
Re: Ram leveling kit [Re: cdstl] #1714912
12/25/14 01:18 PM
12/25/14 01:18 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Have any of you used the aftermarket TB keys to level a 1500. Here is an example of a truck that I was looking at and it is WAY low in the front.
Re: Ram leveling kit [Re: cdstl] #1714913
12/25/14 01:44 PM
12/25/14 01:44 PM
Friendly, WV
wedgeheaded Offline
wedgeheaded  Offline
Friendly, WV
I have an 06 1500 QC 4x4. 06 was the first year to get the coils. I used Bilstein adjustable shocks set on the highest setting. Worked great. If you go that way, do your self a favor and buy new lower bolts. You'll most likely have to cut the factory ones to get them out. I later added a 3" Zone body lift with gap guards. Very happy with the results.
Re: Ram leveling kit [Re: cdstl] #1714914
12/25/14 02:21 PM
12/25/14 02:21 PM
aZLiViN
J_BODY Online rolleyes
J_BODY  Online Rolleyes
aZLiViN
If you plan on towing a trailer leave it ALONE!
Re: Ram leveling kit [Re: wedgeheaded] #1714915
12/25/14 02:26 PM
12/25/14 02:26 PM
ND
dodgedon Offline
dodgedon  Offline
ND
I was wrong above, But 94 was the first year a 1500 4x4 had coils. It looks like they went to TB and back to coils
67 Charger 383 auto
Re: Ram leveling kit [Re: J_BODY] #1714916
12/25/14 04:36 PM
12/25/14 04:36 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Just looking for a bitchin ride.
Re: Ram leveling kit [Re: cdstl] #1714917
12/25/14 06:58 PM
12/25/14 06:58 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Yep, nothin' sez bitchin' like cupped tires, death wobble, wheel alignment problems, headlights pointing at the sky and looking like you have 1500 pounds of rocks in the back all the time.
Mo' Farts
Re: Ram leveling kit [Re: cdstl] #1714918
12/25/14 07:00 PM
12/25/14 07:00 PM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
If you do not tow with the truck or carry heavy weight in the back they are fine. But if you do use the truck to do the mentioned things above the rear end will drop and sag. If you want to raise the truck a bit without going full lift kit, the level kit and same size blocks in the rear is an easy an cost effective way to do it. Dont go over 2" in the front or it will sit nose high.
Re: Ram leveling kit [Re: Grizzly] #1714919
12/26/14 01:55 AM
12/26/14 01:55 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Yea, ok, whatever. Who said anything about a 4" body and a 6" suspension lift and 35", or larger, tires which would certainly cause all of the above.
I said a LEVELING kit that would LEVEL the truck and nothing else. I wanted to know which trucks, if anyone knew, used TBs and which used springs and I found that out. Then I was wondering if anyone had used the TB version of leveling kit and was also wondering how it worked out.
I've seen trucks with the front end up in the air like some of the pics above and would try to avoid it. I am just looking at trucks and trying to figure out which models would pose the biggest pain in the butt to level up. Which would most certainly be the TB trucks vs. the coil spring trucks. I've got a buddy experiencing all of the problems you mentioned because he did what I mentioned.
Geesuz
Re: Ram leveling kit [Re: cdstl] #1714920
12/26/14 03:43 AM
12/26/14 03:43 AM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Sounds like You looked at the photos I attached but ignored what I wrote in the same entry.
Fine.
Learn the hard way, Noobie. $$
Mo' Farts
Re: Ram leveling kit [Re: cdstl] #1714921
12/26/14 04:37 PM
12/26/14 04:37 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Not trying to be a smart azz, but when I look at this truck I don't see the front too low, I see the rear too high. Specially for a 1500
I have mechanical Aptitude.
I can screw up anything.
Re: Ram leveling kit [Re: bboogieart] #1714922
12/27/14 01:06 AM
12/27/14 01:06 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Arthur, I agree. It's not near me but it is a 120k, '03 with a 4.7 and a clutch. It looks really clean in the pictures. Here's the URL: http://easttexas.craigslist.org/ctd/4809795728.html
My Dakota is clean but after living in the rust belt all of these years it's probably time for it to go.
