99 cummins quit!!! #1714889
12/24/14 03:17 AM
12/24/14 03:17 AM
Paris, Tx
mopartruckguy Offline OP
Paris, Tx
Just driving home a couple of hours ago and it was like the key was cut off. I have a lift pump pressure gauge on the a-pillar and it would still make about 10 psi when you would crank the engine. I haven't had the chance to look into it further. What do you experts suggest looking at first?
Re: 99 cummins quit!!! [Re: mopartruckguy] #1714890
12/24/14 10:37 AM
12/24/14 10:37 AM
N
NITROUSN Offline
NITROUSN  Offline
N
codes?
Re: 99 cummins quit!!! [Re: NITROUSN] #1714891
12/24/14 11:14 AM
12/24/14 11:14 AM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
I have never had my 2000 quit while driving, but I did have an issue with it not starting back when I would cut it off. Both times in that case it was the crank shaft sensor.
I believe you can cycle the key 3 times and get some code where the odometer is and maybe that will help out. Best of luck.
Matt
Re: 99 cummins quit!!! [Re: NITROUSN] #1714892
12/24/14 11:43 AM
12/24/14 11:43 AM
Paris, Tx
Paris, Tx
No codes what so ever.
Re: 99 cummins quit!!! [Re: mopartruckguy] #1714893
12/24/14 12:03 PM
12/24/14 12:03 PM
Paris, Tx
Paris, Tx
Well I say no codes. The engine light never came on so I assume there is no code.
Re: 99 cummins quit!!! [Re: mopartruckguy] #1714894
12/24/14 02:37 PM
12/24/14 02:37 PM
Paris, Tx
Paris, Tx
Checked all fuses, and verified that I have 11 psi at the lift pump. I then broke the fuel line at the head and there was no fuel.
Re: 99 cummins quit!!! [Re: mopartruckguy] #1714895
12/24/14 04:07 PM
12/24/14 04:07 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
sounds like a pressure pump
Just did mine and used these guy's and am very happy with the outcome
http://www.bluechipdiesel.com/vp44_diagnostics.html
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 99 cummins quit!!! [Re: mopartruckguy] #1714896
12/25/14 02:05 PM
12/25/14 02:05 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Unfortunely having fuel volume to the VP44 is no guarantee that it will live.... it helps!, but it's no gold card. Unfortunately on your 99 you are going to need a pretty high end scan tool, or best is if you have access to a DRB chrysler scan tool to communicate with the ECM. Easy money is to always bet on the VP44 injection pump without seeing the situation hands on. good luck!
Re: 99 cummins quit!!! [Re: J_BODY] #1714897
12/26/14 12:08 AM
12/26/14 12:08 AM
Paris, Tx
Paris, Tx
Is that "normal" for the injector pump to stop all at once like mine did?
Re: 99 cummins quit!!! [Re: mopartruckguy] #1714898
12/26/14 12:13 AM
12/26/14 12:13 AM
N
NITROUSN Offline
NITROUSN  Offline
N
It can do that.
Re: 99 cummins quit!!! [Re: NITROUSN] #1714899
12/26/14 02:19 PM
12/26/14 02:19 PM
Byron, NY
Byron, NY
Yes it is normal. The typical failure is a soldered connection on the pump control board fails due to vibration and heat. Boards are not available separately so a new pump is required. Also they are prone to main shaft breakage. both resulting instantaneous pump failure.
'60 Willys CJ5
Re: 99 cummins quit!!! [Re: mopartruckguy] #1714900
12/26/14 04:42 PM
12/26/14 04:42 PM
Beeware Offline
Beeware  Offline
Same thing happened to me have a 99 CTD had a new lift pump on the truck 2 months old and good fuel pressure, driving along and it just stopped. No codes no check engine light just stopped like it was out of fuel but it wasn't.
Truck had 150K when that happened, changed out VP44 and its been great since. Got lucky on the VP44 friend that works for Mopar checked stock when Mopar was closing dealerships around 07/08??? He found one on the shelf for my truck and one for his so I did have one on the shelf.
Betting on the VP44............Good Luck.
