Re: 99 cummins quit!!!
[Re: mopartruckguy]
#1714895
12/24/14 04:07 PM
12/24/14 04:07 PM
Posts: 2,106 Byron, NY
W.I.N. Racing
Byron, NY
sounds like a pressure pump Just did mine and used these guy's and am very happy with the outcome http://www.bluechipdiesel.com/vp44_diagnostics.html
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: NITROUSN]
#1714899
12/26/14 02:19 PM
12/26/14 02:19 PM
W.I.N. Racing
Byron, NY
Yes it is normal. The typical failure is a soldered connection on the pump control board fails due to vibration and heat. Boards are not available separately so a new pump is required. Also they are prone to main shaft breakage. both resulting instantaneous pump failure.
