Trailer compressors... #171416
12/20/08 01:47 PM
12/20/08 01:47 PM
Las Vegas
Al_Alguire Offline OP
Las Vegas
Looking to install a compressor in my trailer. What are you guys using for compressors. I am thinking of running a smaller unit, mainly just for tires etc. Any pics of installs might be nice.
Re: Trailer compressors... [Re: Al_Alguire] #171417
12/20/08 01:57 PM
12/20/08 01:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I bought a small twin tank unit from harbor freight
120v,4.5 gal tank, 125 psi max,5.3 @ 40,4.4 @ 90,
100% duty cycle. I cant remember the price but it
was about $229. I can run small air tools but
have to let it fill back some but for the most stuff
in the trailer it works fine plus its small and fits
in my cabinet out of the way
EDIT
I found the one I got, its a Ingersoll Rand (no pic)
Re: Trailer compressors... [Re: MR_P_BODY] #171418
12/20/08 02:19 PM
12/20/08 02:19 PM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
I have this one from HF installed next to the tool box but do not have pic of it installed, it will run anything except my NOS pump!!
Re: Trailer compressors... [Re: Al_Alguire] #171419
12/20/08 02:20 PM
12/20/08 02:20 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
Onan 57 amp unit...twin cylinder...seems compact..Ill get a pic later
Re: Trailer compressors... [Re: Al_Alguire] #171420
12/20/08 02:30 PM
12/20/08 02:30 PM
I have a small portable 110 volt five gallon Devillbliss that I use in the trailer and around the house when needed, I bought it used out of a pawn shop years ago so I dion't know if there still avaible new works fine for tires, blowing out a carb. circuit bit it will not run any air tools, so I bought a new 110 volt 1/2 drive electric impact wrench from H.F. It has been work like a red headed step child any time I need it
Re: Trailer compressors... [Re: Al_Alguire] #171421
12/20/08 04:48 PM
12/20/08 04:48 PM
Shelbyville, TN USA
40ford Offline
mopar addict
40ford  Offline
mopar addict
Shelbyville, TN USA
Keep in mind the wattage requirements of an electric motor---750 watts per motor HP---and about 150% of that for start up. So a 2HP electric motor will require about 2300 watts for starting. It is a hassle to turn everything else off when starting a compressor---especially at night!
Re: Trailer compressors... [Re: 40ford] #171422
12/20/08 05:24 PM
12/20/08 05:24 PM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
heres the one I have.
http://www.eaglecompressor.com/air_compressor_model.php?recordID=197
quiet, fast, and not junk. Paid $150 for it from Snap On. great for tires, blow guns etc...
its nice for blowing the dust/dirt/rubber off the rear of the car that seems to accumulate there because of the rear wing.
Post deleted by Defbob [Re: 5537SG] #171423
12/20/08 06:13 PM
12/20/08 06:13 PM
Re: Trailer compressors... #171424
12/20/08 07:46 PM
12/20/08 07:46 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
I've got a little "Delta" that came with a brad nailer, trim gun, hose and accesories at Home Depot for $89 Fits perfectly in the gen box next to the Honda eu3000
I leave the big equipment at the shop
Re: Trailer compressors... [Re: MegaDart] #171425
12/20/08 10:48 PM
12/20/08 10:48 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
I bought a little Coleman verticle 8 gallon to do the roof on the house. Honestly it was for the house project honey. It just looks like it will fit in trailer REALLY nice when I am done with the roof. The neat thing is it looks just like my 2 stage unit in the shop, but a lot smaller. Beep
Re: Trailer compressors... [Re: Bigbeep] #171426
12/20/08 11:24 PM
12/20/08 11:24 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Al, i was at sears today and seen a compact one that would set right on top of the counter cabinet. on sale $99.00
Re: Trailer compressors... [Re: rowin4] #171427
12/21/08 03:00 AM
12/21/08 03:00 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
My dad and I picked this one up at Lowes. Works well, is on wheels, and has a flip up handle so it can be rolled around. 1.5 gal and my 2000 watt compressor runs it without any issues.
Re: Trailer compressors... [Re: J_BODY] #171428
12/21/08 09:19 AM
12/21/08 09:19 AM
The Grand State of Confusion-O...
SKR8PN Offline
SKR8PN  Offline
I bought one of these Makita compressors and it works great!
They call it portable but you better get a good grip on it when you go to move it!
Karma has no menu. You get served what you deserve.
Re: Trailer compressors... [Re: SKR8PN] #171429
12/21/08 09:31 AM
12/21/08 09:31 AM
Shelbyville, TN USA
40ford Offline
mopar addict
40ford  Offline
mopar addict
Shelbyville, TN USA
I am not cheap---but I am tight! I bought a Grainger two piston, oiless pump with intergral 1/2HP motor for $5 at a yard sale(they sell for about $400 new). Mounted it to an air tank, added the pressure switch and presto, I have a compressor that puts out very clean air and doesn't strain the generator.
My son says I squeak when I walk! But I remind him that we need to conserve to afford the Pro Jacks!
Re: Trailer compressors... [Re: 40ford] #171430
12/21/08 10:15 AM
12/21/08 10:15 AM
Pottstown, Pa.
sg1093 Offline
sg1093  Offline
Pottstown, Pa.
I bought a Snap On small compresor that uses the cordless batterires that my Snap On Impact does. It works good to fill tires. It small at light enough to carry to the staging lanes.
Re: Trailer compressors... [Re: sg1093] #171431
12/21/08 02:21 PM
12/21/08 02:21 PM
Las Vegas
Las Vegas
Well if I were wanting a small portable you can pick these up they are nice and work well, for those looking for a compressor for the lanes. They put out up to 120 psi and about as portable as they come. Oh yeah they are on sale at RJ race cars for $39.95 too.
Re: Trailer compressors... [Re: Al_Alguire] #171432
12/21/08 02:31 PM
12/21/08 02:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When I go to the lanes I pump up my tires before
I leave the trailer(when I'm by myself) or if the
wife or some one is with me I have one of those
jumper battery air compressor things in my golf cart
(cheapo things) but its been running years now, just
to top off the tires if I forgot at the trailer
Re: Trailer compressors... [Re: rowin4] #171433
12/21/08 02:42 PM
12/21/08 02:42 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
http://www.sears.com/shc/s/p_10153_12605_00915310000P?mv=rr
I have had one of these for a couple of years and really like it. Don't get one of the "oil-less" compressors, extremely loud!
Good Luck,
Bill
Re: Trailer compressors... [Re: J_BODY] #171434
12/21/08 06:22 PM
12/21/08 06:22 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I think thats the one I have also.. it works
Re: Trailer compressors... [Re: Jeepmon] #171435
12/23/08 04:16 PM
12/23/08 04:16 PM
Hibbing Mn
tazmaniac Offline
tazmaniac  Offline
Hibbing Mn
Just noticed this one at Lowes even comes with a brad nailer
http://www.lowes.com/lowes/lkn?action=pr...&lpage=none
