Did all 69 440 blocks have machined serial number pad #1713627
12/21/14 07:51 PM
12/21/14 07:51 PM
Ontario, Canada
mccannix Offline OP
mccannix  Offline OP
Ontario, Canada
I have a 440 block that looks like a 68 with unmachined pad.
It has a full 69 C-body serial number stamped here
Re: Did all 69 440 blocks have machined serial number pad [Re: mccannix] #1713628
12/21/14 07:53 PM
12/21/14 07:53 PM
Ontario, Canada
mccannix Offline OP
mccannix  Offline OP
Ontario, Canada
Boss looks to have E possibly D assembled 7-25 ?
Re: Did all 69 440 blocks have machined serial number pad [Re: mccannix] #1713629
12/21/14 07:55 PM
12/21/14 07:55 PM
Ontario, Canada
mccannix Offline OP
mccannix  Offline OP
Ontario, Canada
cast April 2..69 ?. hard to tell..perhaps 68
Re: Did all 69 440 blocks have machined serial number pad [Re: mccannix] #1713630
12/21/14 08:26 PM
12/21/14 08:26 PM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
Can't wait for some intel on this one!
Re: Did all 69 440 blocks have machined serial number pad [Re: mccannix] #1713631
12/21/14 08:28 PM
12/21/14 08:28 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
I see 4-2-68 Terry......
Admiration For Multiple Carburetor Vehicles...
Re: Did all 69 440 blocks have machined serial number pad [Re: mccannix] #1713632
12/21/14 08:30 PM
12/21/14 08:30 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
D=68
Re: Did all 69 440 blocks have machined serial number pad [Re: mccannix] #1713633
12/21/14 08:30 PM
12/21/14 08:30 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I would look for other early (July '68) assembled '69 model year blocks & ask:
When did Chrysler start machining the VIN pad, or did this one just get missed?
IMO, looks like:
cast - 4*2*68 (Tuesday)
EAD: E 440 7 25 2
engine assembly date - 7 25 (68) 2nd shift (Thursday)
CH43K9C125209? - Jefferson Ave. 4-door hardtop New Yorker built latter half of September '68.
Re: Did all 69 440 blocks have machined serial number pad [Re: mccannix] #1713634
12/21/14 08:31 PM
12/21/14 08:31 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
That,s a D with a divot in the middle......
Re: Did all 69 440 blocks have machined serial number pad [Re: 6bblgt] #1713635
12/21/14 08:35 PM
12/21/14 08:35 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
IMO, looks like:
EAD: E 440 7 25 2
Winner , I think I have seen a couple of 69 blocks like this.
To me the giveaway that this is early 69 production is the FULL vin , definitely a 68 casting and the block sat around before getting used for whatever reason including bad inventory control.
Re: Did all 69 440 blocks have machined serial number pad [Re: Stewpar] #1713636
12/21/14 08:36 PM
12/21/14 08:36 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
It looks like an E to me also.
Re: Did all 69 440 blocks have machined serial number pad [Re: 6bblgt] #1713637
12/21/14 08:38 PM
12/21/14 08:38 PM
Ontario, Canada
mccannix Offline OP
mccannix  Offline OP
Ontario, Canada
I think you have it right on Dan...
I would be curious also as to when they started to machine the pad.
Just that I never seen the number stamped not on the recessed pad but since John has, we have an answer.
Re: Did all 69 440 blocks have machined serial number pad [Re: Stewpar] #1713638
12/21/14 08:39 PM
12/21/14 08:39 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't know
But remember this , 69 model year assembly was schedule to start on 8/1/68 , this engine was assembled 6 days before that. I imagine that 68 model year production had already stopped, the only reason it would be a D is because the guy stamping it goofed, and it may have an E stamped over the D????
Re: Did all 69 440 blocks have machined serial number pad [Re: Alaskan_TA] #1713639
12/21/14 09:34 PM
12/21/14 09:34 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Looks like a E to me to.
Re: Did all 69 440 blocks have machined serial number pad [Re: NITROUSN] #1713640
12/21/14 10:31 PM
12/21/14 10:31 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
All I know is that 4-2-68 was my 10th birthday! Looks to me like an E to me too. Interesting thing would be to find out when they did start machining the pad, might be a left-over block that was supposed to be used for a 68 model car but was in the back of the queue when the 69 model year started.
JB Rhinehart, Realist
A-Body's RULE!
Re: Did all 69 440 blocks have machined serial number pad [Re: JohnRR] #1713641
12/21/14 11:23 PM
12/21/14 11:23 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
I don't know
At regular scale, it looks like an E. However, if you blow it up, you can definitely see curves on both the top and bottom. That seals the deal for me.......
Re: Did all 69 440 blocks have machined serial number pad [Re: Stewpar] #1713642
12/22/14 12:58 AM
12/22/14 12:58 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't know
If the pad weren't all pitted with rust in that area AND the block didn't have a 1969 VIN on it ....
Re: Did all 69 440 blocks have machined serial number pad [Re: JohnRR] #1713643
12/22/14 03:12 AM
12/22/14 03:12 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
The 7 after the casting number I believe is the casting mold or mould number for this block. I have seen 6 7 8 10, was there 1 2 3 4 5 and 9. Was there any numbers after 10. Makes you wonder if Chrysler did this on any other blocks such as Hemis, 383s between the 1968 to 1969 build. Hemi might of been a little more tighter on when they were build and assembled, but this is Chrysler after all and anything goes. Love to see an early HP 440 motor from 1969 with no machined pad and a serial number on it and people start saying the block was restamped. Good stuff Mccannix.
1971 HEMI E BODY REGISTRY
