Re: Did all 69 440 blocks have machined serial number pad
[Re: 6bblgt]
#1713635
12/21/14 08:35 PM
12/21/14 08:35 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
I would look for other early (July '68) assembled '69 model year blocks & ask:
When did Chrysler start machining the VIN pad, or did this one just get missed?
IMO, looks like: cast - 4*2*68 (Tuesday)
EAD: E 440 7 25 2 engine assembly date - 7 25 (68) 2nd shift (Thursday)
CH43K9C125209? - Jefferson Ave. 4-door hardtop New Yorker built latter half of September '68.
Winner , I think I have seen a couple of 69 blocks like this.
To me the giveaway that this is early 69 production is the FULL vin , definitely a 68 casting and the block sat around before getting used for whatever reason including bad inventory control.
[Re: Stewpar]
#1713638
12/21/14 08:39 PM
12/21/14 08:39 PM
JohnRR
U.S.S.A.
Boss looks to have E possibly D assembled 7-25 ?
That,s a D with a divot in the middle......
I don't know
But remember this , 69 model year assembly was schedule to start on 8/1/68 , this engine was assembled 6 days before that. I imagine that 68 model year production had already stopped, the only reason it would be a D is because the guy stamping it goofed, and it may have an E stamped over the D????
[Re: JohnRR]
#1713641
12/21/14 11:23 PM
12/21/14 11:23 PM
Posts: 2,963 Wisconsin
Stewpar
Wisconsin
I don't know
At regular scale, it looks like an E. However, if you blow it up, you can definitely see curves on both the top and bottom. That seals the deal for me.......
Admiration For Multiple Carburetor Vehicles...
[Re: Stewpar]
#1713642
12/22/14 12:58 AM
12/22/14 12:58 AM
JohnRR
U.S.S.A.
I don't know
If the pad weren't all pitted with rust in that area AND the block didn't have a 1969 VIN on it ....
[Re: JohnRR]
#1713643
12/22/14 03:12 AM
12/22/14 03:12 AM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
The 7 after the casting number I believe is the casting mold or mould number for this block. I have seen 6 7 8 10, was there 1 2 3 4 5 and 9. Was there any numbers after 10. Makes you wonder if Chrysler did this on any other blocks such as Hemis, 383s between the 1968 to 1969 build. Hemi might of been a little more tighter on when they were build and assembled, but this is Chrysler after all and anything goes. Love to see an early HP 440 motor from 1969 with no machined pad and a serial number on it and people start saying the block was restamped. Good stuff Mccannix.
1971 HEMI E BODY REGISTRY
