Another Alternator Option #1713525
12/21/14 01:58 PM
12/21/14 01:58 PM
IN
ahy Offline OP
ahy  Offline OP
IN
A new squareback replacement from Flaming River... over 100 idle amps and 150 max. Advertised as cool running and durable. I saw the add in the new MA. It looks like it should work with OE style brackets. Just spendy.
I'll probably get along with my late 70's "big Chrysler" alternator for now but would love to hear if anybody tries this option.
http://www.flamingriver.com/index.php/products/c0023/s0013/FR1174
Re: Another Alternator Option [Re: ahy] #1713526
12/21/14 02:16 PM
12/21/14 02:16 PM
No I havent but I had always heard the big Chrysler one (with the fan behind the pulley) puts out alot of juice & the problem with it is how heavy it is. What is your take? Here's a BTT for ya
Re: Another Alternator Option [Re: ahy] #1713527
12/21/14 04:50 PM
12/21/14 04:50 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Re: Another Alternator Option [Re: John_Kunkel] #1713528
12/21/14 08:37 PM
12/21/14 08:37 PM
IN
ahy Offline OP
ahy  Offline OP
IN
That one looks nice also... and cost more manageable. Good to see some bolt in alternatives... especially for folks running AC. Its not easy to adapt non standard high output alternators to "with AC" brackets.
Re: Another Alternator Option [Re: ahy] #1713529
12/21/14 10:40 PM
12/21/14 10:40 PM
BDW Offline
BDW  Offline
Re: Another Alternator Option [Re: BDW] #1713530
12/21/14 11:12 PM
12/21/14 11:12 PM
IN
ahy Offline OP
ahy  Offline OP
IN
It seems like the 100+ amp retrofit kits for square backs are limited to 50 ish amps at idle... not enough for my application. Also, I would be concerned with heat and life of a retrofit if run at high outputs for long periods.
Re: Another Alternator Option [Re: BDW] #1713531
12/22/14 12:25 PM
12/22/14 12:25 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
What about this?
http://store.alternatorparts.com/partnoho-7015.aspx
once I got the 80 amps kit from them sold by an ebay seller whoo didn't use it. Didn't worth a penny. Dunno the 105 amps kit
Re: Another Alternator Option [Re: NachoRT74] #1713532
12/22/14 01:06 PM
12/22/14 01:06 PM
BDW Offline
BDW  Offline
What about this?
Are you saying it didn't work, or increase the current?
Re: Another Alternator Option [Re: BDW] #1713533
12/22/14 01:09 PM
12/22/14 01:09 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I'm thinking for $500 I can get two factory ND alternators wired up from a junkyard.
Don't be the exception.
Re: Another Alternator Option [Re: BDW] #1713534
12/22/14 05:27 PM
12/22/14 05:27 PM
Rio Linda, CA
Rio Linda, CA
What about this?
Keep in mind that there's a difference between maximum output and output at low speed.
Re: Another Alternator Option [Re: John_Kunkel] #1713535
12/22/14 11:12 PM
12/22/14 11:12 PM
BDW Offline
BDW  Offline
I agree, would love to see a current (amps) vs RPM graph for all these options.
Now that I have the 518 tranny, engine never gets above 2500rpm.
Re: Another Alternator Option [Re: BDW] #1713536
12/30/14 02:58 AM
12/30/14 02:58 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
What about this?
didn't increased. Worked exactly to the 60 amps lates 70s wider unit
Re: Another Alternator Option [Re: John_Kunkel] #1713537
12/30/14 03:00 AM
12/30/14 03:00 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
What about this?
you are absolutelly right BUT... increasing max output will mean also the iddle output is being increased "more less proportionally"
Re: Another Alternator Option [Re: BDW] #1713538
12/30/14 03:06 AM
12/30/14 03:06 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I'd love that too... I know rebuilt units ( by a brand ) get the graphic card with those values coming with the alt you get... BUT, Never have being shown those values on those newer replacements with stated higher outputs.
and AN ACTUAL PIC OF THE ALTERNATOR BEING OFFERED!!! ( not a reference pic ) wouldn't be funny, think you'll get the first squarebacks version ( IN MY CASE, what I want ) and get the late ones, since these are a bit wider making a tight fit and in some case requiring longer belts
Re: Another Alternator Option [Re: NachoRT74] #1713539
12/30/14 04:42 PM
12/30/14 04:42 PM
BDW Offline
BDW  Offline
I looked on RockAuto and they show a couple of options are 114 amps for around $80.
I'd bet this would be an improvement.
http://catalog.remyinc.com/Product/Details/20036
Re: Another Alternator Option [Re: BDW] #1713540
12/30/14 06:04 PM
12/30/14 06:04 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Those use a different mount setup than the more common ones. Late M bodies are a good source as well as trucks for an LA engine.
