Monte Smith ? #1713333
12/20/14 10:47 PM
12/20/14 10:47 PM
MR_P_BODY Offline OP
Monte do you know what brand name the wide band O2
sensor is Holley sends out in the Dominator EFI kit..
I need to know so I can plug that in for the down
load info... all it says on it is Holley
thanks
Re: Monte Smith ? [Re: MR_P_BODY] #1713334
12/20/14 11:16 PM
12/20/14 11:16 PM
The Great White North
RAMM Offline
RAMM  Offline
Pretty sure its a BOSCH not the NTK. I wondered the same thing. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Monte Smith ? [Re: RAMM] #1713335
12/20/14 11:20 PM
12/20/14 11:20 PM
I think it is also but I want to make sure so I dont
fry it... thanks
Re: Monte Smith ? [Re: MR_P_BODY] #1713336
12/20/14 11:44 PM
12/20/14 11:44 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
if its can on the end of the sensor with holes in it its a NTK and would cost around 450.00 if it has a ball on the end its a bosche and cost around 150.00
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Monte Smith ? [Re: bigtimeauto] #1713337
12/20/14 11:47 PM
12/20/14 11:47 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
bosch
Re: Monte Smith ? [Re: bigtimeauto] #1713338
12/20/14 11:49 PM
12/20/14 11:49 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
ntk l1h1
Re: Monte Smith ? [Re: bigtimeauto] #1713339
12/21/14 12:29 AM
12/21/14 12:29 AM
Thanks... by the way you can get the Bosch wide
band sensor for $69. .. I bought one a short time
back for my A/F meter.. if I remember right it was
at NAPA
Re: Monte Smith ? [Re: MR_P_BODY] #1713340
12/21/14 02:12 AM
12/21/14 02:12 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
at advance auto the bosch 17014 is $57 - 20% online discount plus a $10 rebate. net cost $36
i run 8 of em on the dyno and 2 in the car.
Joe
Without Data, you’re just another guy with an opinion.
Re: Monte Smith ? [Re: sr4440] #1713341
12/21/14 02:17 AM
12/21/14 02:17 AM
Joe
Thanks I'll write that down
Re: Monte Smith ? [Re: MR_P_BODY] #1713342
12/21/14 03:04 AM
12/21/14 03:04 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I don't use them, I still read plugs
Re: Monte Smith ? [Re: bigtimeauto] #1713343
12/21/14 03:06 AM
12/21/14 03:06 AM
This EFI reads it
Re: Monte Smith ? [Re: MR_P_BODY] #1713344
12/21/14 03:17 AM
12/21/14 03:17 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
This EFI reads it
I have a motec unit in one of my cars but no O2. Oh that's right I tune it I don't run it in closed loop. got it.
Re: Monte Smith ? [Re: bigtimeauto] #1713345
12/21/14 03:21 AM
12/21/14 03:21 AM
This EFI reads it
I have my choice of open or closed.. it HAS to have
something entered in the down load
Re: Monte Smith ? [Re: bigtimeauto] #1713346
12/21/14 01:37 PM
12/21/14 01:37 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
What about on the dyno? No A/F ratio there either? Individual runner temps???
Re: Monte Smith ? [Re: Blusmbl] #1713347
12/21/14 03:18 PM
12/21/14 03:18 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
and my outlaw 10.5 car is mechanical fuel injected. If its not about fuel economy the 02 will never tell the whole truth. EGT's are good to see if all cylinders have the same temp in the pipe but to many variables there to....timing versus fuel.
I will say the 02 is the easy way to tune to get you close but there is still no substitue for max power in a drag car for pulling plugs.
Re: Monte Smith ? [Re: bigtimeauto] #1713348
12/21/14 03:30 PM
12/21/14 03:30 PM
I will come up with another program for the track
which wont use the O2.. but for the fire up it will
use the O2 and for the street... this is trying to
drive to stoich all the time.. so for power I'll come
up with a different program to load
Re: Monte Smith ? [Re: MR_P_BODY] #1713349
12/21/14 04:06 PM
12/21/14 04:06 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
We run our 738 on 4 dry kits in closed loop and let the box do it's job and correct. Been told and told that won't work and the car will be faster open loop on the tune itself........WRONG. Ran it both ways, makes no difference. No possible reason NOT to run a gas car closed loop. You are going to pay the money for EFI.....why not let it DO its job
Monte
Re: Monte Smith ? [Re: Monte_Smith] #1713350
12/21/14 04:16 PM
12/21/14 04:16 PM
Monte
Good to know... I found out that the O2 sensor is
a Bosch unit so that takes care of that part...
one other thing Monte... when down loading the global
base program I see for it shows for the GM small cap
and I'm gonna try that but will it matter for the
base set up.. my engine falls within most of the
parameters, mine has a bit more duration but I think
it'll learn from the base
Re: Monte Smith ? [Re: bigtimeauto] #1713351
12/21/14 05:56 PM
12/21/14 05:56 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
I don't understand why you don't like A/F numbers??? Thing is, most people WRONGLY assume that if you tune for a certain A/F number you'll make max hp....A/F numbers are EXACTLY like oil pressure numbers, tire pressure numbers and even a tach in that they DO NOT tell you what A/F you should run, or what oil pressure you need, or what tire pressure to run or where to shift...they are just numbers and the user has to be smart enough to know what numbers to shoot for...
IMHO, spark plugs and A/F numbers are no substitute for max power in a drag car for time slip incrementals, because at the end of the day, as long as it's not detonating, that's ALL that matters...
Now, having said that, once you tune for and find out what A/F your motor wants for max HP, it's easy to get there in different DA's while using A/F numbers...
If you can't handle the truth, you're living a lie.......
Re: Monte Smith ? [Re: Big Squeeze] #1713352
12/21/14 06:26 PM
12/21/14 06:26 PM
I understand what your saying.. If you find out what
the car runs the fastest THEN you take the reading
so its easy to get back to that A/F reading.. we have
found that a engine runs the best(for power) somewhere
around 12.5-13.0(but not always) so the O2 doesnt know
where the peak is at
