hood question 73 dart / 69 barracuda? #1713244
12/20/14 05:30 PM
12/20/14 05:30 PM
Dalton, MA
Slipknot440 Offline OP
Dalton, MA
Had crazy old timer looking at the 73 dart i just scooped up and said he put a hood from a 67-69 barracuda with no modifications back in his time. I humored him for the time being but is it possible?
Re: hood question 73 dart / 69 barracuda? [Re: Slipknot440] #1713245
12/20/14 05:34 PM
12/20/14 05:34 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
73-76 Dart/Dart Sport used the same hood skin as the 69 Barracuda. The underside of the later hood has crumple zones not found on the 69 Barracuda but one will fit on the other. 69 Barracuda only though. Different hood than the 67-68 Barracuda.
Re: hood question 73 dart / 69 barracuda? [Re: nomore65BelvJim] #1713246
12/20/14 06:55 PM
12/20/14 06:55 PM
canaan ct usa
moparclown Offline
moparclown  Offline
canaan ct usa
I use a hood I removed from a 73 Dart sport on my 69 Barracuda.
Re: hood question 73 dart / 69 barracuda? [Re: moparclown] #1713247
12/20/14 07:15 PM
12/20/14 07:15 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
hinges are different for each year(for adjustment) 73 hinge with 73 hood
Re: hood question 73 dart / 69 barracuda? [Re: cudaman1969] #1713248
12/20/14 07:18 PM
12/20/14 07:18 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yep, saw a pic of a dart sport with a 69 barracuda front nose on it. Bet he left his original hood on it!
Wire hole for the 4 speed reverse light. [Re: Slipknot440] #1713249
12/20/14 07:46 PM
12/20/14 07:46 PM
USA
l13 Offline
l13  Offline
USA
Is there a dedicated hole on the firewall for the wire from the 4 speed trans to fuse block then to the reverse light on the lower dash? If so where is the hole located and what is the diameter?
