Engine Stand #1713130
12/20/14 01:40 PM
12/20/14 01:40 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
I've had it with my el-cheapo engine stand. Any reasonable force like torquing head bolts or mains and the thing wobbles to the point I'm afraid something is going to break. I'm going to start on my first Hemi next year and I'd rather it not end up on the floor. I'd like to get a good 2000# version for around $1000 but I can't find one. They seem to go from the cheap 2000# versions for a couple hundred bucks to the 3000# diesel stands that are four thousand bucks. I could make one but I really don't want to take the time. Anybody know of somebody that sells a quality 2000# stand in that price range?
Re: Engine Stand [Re: 6PakBee] #1713131
12/20/14 01:51 PM
12/20/14 01:51 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I have an old Lakewood that has been reinforced that works well with a big block .
Re: Engine Stand [Re: 6PakBee] #1713132
12/20/14 01:55 PM
12/20/14 01:55 PM
AndyF Offline
AndyF  Offline
One thing that helps is to use a steel plate to hold the engine rather than the flimsy arms that most stands come with.
Re: Engine Stand [Re: 6PakBee] #1713133
12/20/14 01:56 PM
12/20/14 01:56 PM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
For a few bucks, couldn't you add some reinforcement / improvements to yours?
This one looks beefy:
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: Engine Stand [Re: AndyF] #1713134
12/20/14 01:56 PM
12/20/14 01:56 PM
AndyF Offline
AndyF  Offline
Or go to the next step and replace the entire head of the engine stand with a custom built head which is more rigid. This is what I did to build a big block stand.
Re: Engine Stand [Re: AndyF] #1713135
12/20/14 01:57 PM
12/20/14 01:57 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
OTC makes good stands. We have this one at work and use it on smaller diesel engines. http://www.summitracing.com/parts/otc-1726a?seid=srese1&gclid=CJ_5k9H91MICFS0Q7AodNCUAKw I used it on my big block and it handled it no problem.
Re: Engine Stand [Re: 6PakBee] #1713136
12/20/14 02:07 PM
12/20/14 02:07 PM
just me, no way I'd want that kind of money in a stand. Definitely get one with 4 legs (wheels)
Re: Engine Stand [Re: RapidRobert] #1713137
12/20/14 03:29 PM
12/20/14 03:29 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
I don't understand your comment.
Re: Engine Stand [Re: 6PakBee] #1713138
12/20/14 04:36 PM
12/20/14 04:36 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
If I needed a one, I think I would consider this one from Summit just as long as you are short. Most new stands I see are short, I'm 6'3 tall, what are they thinking? It looks sturdy and the geared head is a plus at a cheap price, imo.
web page
Then the only reason I say summit is because they have many choices and provide pretty good delivery service.
web page
My homemade stand, it has held International MV404 and 392 gasoline fueled truck engines which are heavier than the heaviest big block. And I have hung many engines with grade 5 all thread rod, 3/8" and 7/16" all thread rod. Not just SBs but huge BAE hemis and cast iron truck engines with all thread rod. That way I'm sure I'm screwed into the block the max and there's no block thread damage. Grade 8 bolts are not needed and bolts are bad for this application. I have repainted this engine stand 3 times since 78 when I got it.
20 years ago I'd be all over you to build your own and have it for life like mine. But now you really can't afford to build your own. This one was built in a hi school welding class at diamond oaks in 78.
Re: Engine Stand [Re: AndyF] #1713139
12/20/14 04:41 PM
12/20/14 04:41 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
BEST IDEA ive seen yet !!!
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: Engine Stand [Re: 6PakBee] #1713140
12/20/14 05:33 PM
12/20/14 05:33 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I can not think of a better stand than the Stroppini that I bought in the 80's. The thing is stout, stable and has a fairly small foot-print.
Heres a pic from online (not my stand and pic is the older 3 wheel version). My stand and all? are now made with a front cross-tube with 2 wheels in front to make it very stable. I've had some very heavy motors on it and have no problem with stability. Also the plate and arms are adjustable so as to be able to center the load making it pretty easy to rotate.
edit--> The vertical and horizontal tube are one piece made with a bend, ne new versions don't have the big plate covering the bend, rather it's a bolted connection.
Re: Engine Stand [Re: srt] #1713141
12/20/14 05:50 PM
12/20/14 05:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Here's my oldie but sturdy. Use it for years and it's being used to strip a big block right now. Don't know what brand it is.
Re: Engine Stand [Re: srt] #1713142
12/20/14 05:57 PM
12/20/14 05:57 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I stopped using 3 legged stands after dumping an engine in the driveway when it hit a small rut.
Re: Engine Stand [Re: 6PakBee] #1713143
12/20/14 07:49 PM
12/20/14 07:49 PM
1k would be way more than I would want to have invested in an eng stand. I have a NAPA one (dont remember the new price maybe several hundred) with 4 legs (wheels) & it works good on the SB/BB's I have done. I Like Andys' idea of adding the flat plate
Re: Engine Stand [Re: RapidRobert] #1713144
12/20/14 08:11 PM
12/20/14 08:11 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Wow !! Send me the $ 1000. and I'll ship you my stand.
Seriously, that's way too nuch to have tied up in an engine stand - even one that will hold a complete iron hemi.
But if you really want to, my offer stands !
Re: Engine Stand [Re: Stanton] #1713145
12/20/14 08:40 PM
12/20/14 08:40 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
If you have a QUALITY 2000# stand, send me a picture, I'll consider it. If you have one of the 2000# Harbor Freight units (or something similar, or God forbid of less capacity).....I already have that quality level.
Re: Engine Stand [Re: 6PakBee] #1713146
12/20/14 09:30 PM
12/20/14 09:30 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
One thing to think about, a Hemi is so top heavy, I wish I had got one with the gear crank mechanism, my whole Hemi is aluminum and I almost couldn't get it turned back right side up.
Re: Engine Stand [Re: 71birdJ68] #1713147
12/20/14 10:34 PM
12/20/14 10:34 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
A decent rotator can be made from a air brake slack adjuster. thus:
https://www.youtube.com/watch?v=dUJKwFE_NvE
Re: Engine Stand [Re: srt] #1713148
12/20/14 11:23 PM
12/20/14 11:23 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Too bad your not closer.
I would sell you mine.
I bought this one from NAPA when i had 3 hemi engines in a storage locker.
Never used it, as i sold all the engines.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Engine Stand [Re: hemi71x] #1713149
12/21/14 01:40 AM
12/21/14 01:40 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I have one like this , Sunnex version , I'm going to have to make something like Andy F showed before I put a megablock with new MP iron heads on it , I don't really trust it with all that weight .
