Engine Stand
#1713130
12/20/14 01:40 PM
12/20/14 01:40 PM
Posts: 10,710 North Dakota
6PakBee
North Dakota
I've had it with my el-cheapo engine stand. Any reasonable force like torquing head bolts or mains and the thing wobbles to the point I'm afraid something is going to break. I'm going to start on my first Hemi next year and I'd rather it not end up on the floor. I'd like to get a good 2000# version for around $1000 but I can't find one. They seem to go from the cheap 2000# versions for a couple hundred bucks to the 3000# diesel stands that are four thousand bucks. I could make one but I really don't want to take the time. Anybody know of somebody that sells a quality 2000# stand in that price range?
Re: Engine Stand
[Re: 6PakBee]
#1713133
12/20/14 01:56 PM
12/20/14 01:56 PM
Posts: 1,377 Tennessee
WyleECoyote
Tennessee
For a few bucks, couldn't you add some reinforcement / improvements to yours? This one looks beefy:
Wile E. Coyote Super Genius, Lover of FCA US LLC Products ************* 68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: Engine Stand
[Re: 6PakBee]
#1713138
12/20/14 04:36 PM
12/20/14 04:36 PM
Challenger 1
Cincinnati, Ohio
If I needed a one, I think I would consider this one from Summit just as long as you are short. Most new stands I see are short, I'm 6'3 tall, what are they thinking? It looks sturdy and the geared head is a plus at a cheap price, imo. web page Then the only reason I say summit is because they have many choices and provide pretty good delivery service. web page My homemade stand, it has held International MV404 and 392 gasoline fueled truck engines which are heavier than the heaviest big block. And I have hung many engines with grade 5 all thread rod, 3/8" and 7/16" all thread rod. Not just SBs but huge BAE hemis and cast iron truck engines with all thread rod. That way I'm sure I'm screwed into the block the max and there's no block thread damage. Grade 8 bolts are not needed and bolts are bad for this application. I have repainted this engine stand 3 times since 78 when I got it. 20 years ago I'd be all over you to build your own and have it for life like mine. But now you really can't afford to build your own. This one was built in a hi school welding class at diamond oaks in 78.
Re: Engine Stand
[Re: AndyF]
#1713139
12/20/14 04:41 PM
12/20/14 04:41 PM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
One thing that helps is to use a steel plate to hold the engine rather than the flimsy arms that most stands come with.
BEST IDEA ive seen yet !!!
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
Re: Engine Stand
[Re: 6PakBee]
#1713140
12/20/14 05:33 PM
12/20/14 05:33 PM
Posts: 15,749 Jefferson State
srt
ESYC
ESYC
Jefferson State
I can not think of a better stand than the Stroppini that I bought in the 80's. The thing is stout, stable and has a fairly small foot-print. Heres a pic from online (not my stand and pic is the older 3 wheel version). My stand and all? are now made with a front cross-tube with 2 wheels in front to make it very stable. I've had some very heavy motors on it and have no problem with stability. Also the plate and arms are adjustable so as to be able to center the load making it pretty easy to rotate. edit--> The vertical and horizontal tube are one piece made with a bend, ne new versions don't have the big plate covering the bend, rather it's a bolted connection.
Re: Engine Stand
[Re: hemi71x]
#1713149
12/21/14 01:40 AM
12/21/14 01:40 AM
Posts: 74,990 U.S.S.A.
JohnRR
U.S.S.A.
Too bad your not closer. I would sell you mine. I bought this one from NAPA when i had 3 hemi engines in a storage locker. Never used it, as i sold all the engines.
I have one like this , Sunnex version , I'm going to have to make something like Andy F showed before I put a megablock with new MP iron heads on it , I don't really trust it with all that weight .
