Any pump gas B1 motors out there? #1712563
12/18/14 11:15 PM
12/18/14 11:15 PM
Cab_Burge Offline OP
I was worndering if anyone on here has built and used a set of B1 heads on pump gas on the street and or on the strip? If so would you mind sharing your combination and results thanks in advance either way
Re: Any pump gas B1 motors out there? [Re: Cab_Burge] #1712564
12/19/14 02:18 AM
12/19/14 02:18 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
not a pump gas combo
511ci 13.1 comp 277/800 lift B1 heads 1150 dominater
for next year
1.39 9.85 - 137 mph
Re: Any pump gas B1 motors out there? [Re: Cab_Burge] #1712565
12/19/14 03:43 AM
12/19/14 03:43 AM
Finland
LUMI Offline
LUMI  Offline
Finland
i have a full pumpgas streetcar
B1 originals, B1 Intake, Venolia 4.5 pistons, Callies 4.77 Crank, 6.8" H beam Rods, Koleno KP440 Block, 1270cfm AED Max Pro Dominator, Crane Mec Roller 320/328deg 114 disp angle int .79 ex .76 CR10.69
TTI 2.0/ 2 1/8 /3.5 Headers
original B1 rockers broke last summer at 800/275 lbs
i will try T&Dīs original shaft ones next summer
Re: Any pump gas B1 motors out there? [Re: LUMI] #1712566
12/19/14 04:51 AM
12/19/14 04:51 AM
That is quite a bit bigger C.I. than I'm thinking of building, do you mind sharing your results if you dyno tested or ran it at one of your tracks over there? I hope so Thanks
Re: Any pump gas B1 motors out there? [Re: Cab_Burge] #1712567
12/19/14 05:54 AM
12/19/14 05:54 AM
Finland
LUMI Offline
LUMI  Offline
Finland
dynoed 942@6100 and 886@5100 at Koffels Place with 1050 Dominator
not on a strip yet on my Charger
but this engine was i Germany before in Henning Blumeīs Belvedere and it ran high 8īs with this
http://www.b1heads.com/international.html
