Hydraulic-pneumatic long ram jack ??? #1712518
12/18/14 07:51 PM
12/18/14 07:51 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Anyone on here use an air/hydraulic long ram jack for their engine hoist or anything like that? What I need to know id how the jack is lowered. Do you lower it like any other jack - by turning the bleeder valve, or does it lower by bleeding the air?
Thanks,
Re: Hydraulic-pneumatic long ram jack ??? [Re: Stanton] #1712519
12/18/14 09:49 PM
12/18/14 09:49 PM
Kings Beach, CA
tahoechallenge Offline
Kings Beach, CA
All the ones I've used have been single acting. You turn the knob to lower the load.
Re: Hydraulic-pneumatic long ram jack ??? [Re: Stanton] #1712520
12/18/14 10:01 PM
12/18/14 10:01 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Thanks,
It lowers by bleeding hydraulic fluid.
Yea I have done it many years ago, when that cylinder wore out I replaced with a regular hand pump cylinder.
My pro jacks operate the same way also.
Re: Hydraulic-pneumatic long ram jack ??? [Re: Challenger 1] #1712521
12/19/14 12:37 AM
12/19/14 12:37 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Well that sucks. I was planning to build a two-post hoist using one in each post. Raising them simultaneously would be fine but lowering them would be an issue !!
Re: Hydraulic-pneumatic long ram jack ??? [Re: Stanton] #1712522
12/19/14 11:40 AM
12/19/14 11:40 AM
Cincinnati, Ohio
Cincinnati, Ohio
My pro jacks have one valve that lowers both at the same time. Later when I go down to my race shop I can snap a picture of the valve.
Re: Hydraulic-pneumatic long ram jack ??? [Re: Challenger 1] #1712523
12/19/14 11:49 AM
12/19/14 11:49 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
I'd appreciate that.
Re: Hydraulic-pneumatic long ram jack ??? [Re: Stanton] #1712524
12/19/14 09:45 PM
12/19/14 09:45 PM
Cincinnati, Ohio
Cincinnati, Ohio
Here's my air over hydraulic pump with a flow control knob. It can block the pressure altogether to hydraulically hold the rams up and then turned counter clock wise to bleed off the pressure to let the rams down in a controlled manner. Sorry for the messy floor, it's going to get cleaned here real soon.
