10" Rear Wheels in a '63? #1712213
12/18/14 12:36 PM
12/18/14 12:36 PM
MN
ryangtogtx Offline OP
MN
I'm having my '63 Dodge mini-tubbed in January and want 10" wheels in the rear. I want them to look as deep dish as possible and looking for opinions on offset. I haven't ordered the rear end from Strange yet until the shop gives me the specs, but basically looking for what everyone is running. I'm probably going with a Billet Specialties Comp 5 on all four wheels. Any pics or opinions would be great! Thanks.
Re: 10" Rear Wheels in a '63? [Re: ryangtogtx] #1712214
12/18/14 12:55 PM
12/18/14 12:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run a 12" wheel with a 4" back spacing so you see
a 8" dish
Re: 10" Rear Wheels in a '63? [Re: MR_P_BODY] #1712215
12/18/14 02:16 PM
12/18/14 02:16 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Mine '63 has stock tubs and 15x8 Wheel Vintiques with 4 1/2" backspace. Rearend is out of a 68-70 Charger. The wheels are perfectly centered in the wheelwell. 275/60/15 tires
Re: 10" Rear Wheels in a '63? [Re: ryangtogtx] #1712216
12/18/14 02:21 PM
12/18/14 02:21 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I guess I don't understand the question. You say you want a 10" wheel with as much dish as possible. Since you are doing a custom rear, that's exactly what you should order and then make the rear fit the wheels. Get what you want
Monte
Re: 10" Rear Wheels in a '63? [Re: Monte_Smith] #1712217
12/18/14 02:35 PM
12/18/14 02:35 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
As Monte said,get the wheels and tires that you want and that fit your wheelwell,set them in the wells then measure the rearend length.Don't forget to allow for the thickness of the brake componants.You may also want to consider centering the wheel in the opening for front and back clearences and make the adjustment in your suspension attaching points.
Re: 10" Rear Wheels in a '63? [Re: GY3] #1712218
12/18/14 02:36 PM
12/18/14 02:36 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Depending on tire sizing, I'm not sure you'll need to mini tub if you get the right offset wheel.
Re: 10" Rear Wheels in a '63? [Re: GY3] #1712219
12/18/14 02:39 PM
12/18/14 02:39 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I can't speak to a '63, but my '62 has 10" wide wheels on it. The front spring hanger is just pushed over to the framerail. Fits a 275/60 drag radial on the 10" wheel SNUG!
Re: 10" Rear Wheels in a '63? [Re: dizuster] #1712220
12/18/14 02:41 PM
12/18/14 02:41 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I actually have a spacer, because it was a TOUCH on the tight side.
Re: 10" Rear Wheels in a '63? [Re: dizuster] #1712221
12/18/14 02:41 PM
12/18/14 02:41 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Rear view.
Re: 10" Rear Wheels in a '63? [Re: dizuster] #1712222
12/18/14 02:45 PM
12/18/14 02:45 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Side
Re: 10" Rear Wheels in a '63? [Re: dizuster] #1712223
12/18/14 03:28 PM
12/18/14 03:28 PM
S.E. Michigan
TruPerformance Offline
S.E. Michigan
The 15x10" will fit without the mini-tub, depending on the tire you are looking to put on it. I have 15x10" with 5 3/4" b.S. and 9x30 slicks. No mini-tub, I just moved the springs inboard, and ordered the S60 to fit. You need the mini-tub for anything wider than 9" slick, or 275's on a 10" wheel.
1963 Belvedere (mine)
1969 Roadrunner (wife's)
Re: 10" Rear Wheels in a '63? [Re: TruPerformance] #1712224
12/18/14 03:34 PM
12/18/14 03:34 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Some of you guys are still talking about backspacing. That does NOT matter if you are doing a custom width rear. A 10" wheel is a 10" wheel. It fits or it doesn't. So order what you want and fit the rear.
Now, that said, you can get a 10" wheel on a 63 without mini-tubs. If I mini-tubbed it, I would put a 12" wheel on it, depending on the tire you want to use
Monte
Re: 10" Rear Wheels in a '63? [Re: Monte_Smith] #1712225
12/18/14 03:40 PM
12/18/14 03:40 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
My valiant wagon
Has a cut down Dana, split the wheel tub and moved it over .
In this pic
10.5 x 28 x 15 M/T (worn out)
On 15 x 10's with 3 1/2 back space
Re: 10" Rear Wheels in a '63? [Re: bigdad] #1712226
12/18/14 03:41 PM
12/18/14 03:41 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
side
Re: 10" Rear Wheels in a '63? [Re: Monte_Smith] #1712227
12/18/14 03:50 PM
12/18/14 03:50 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Backspacing is definitely important.
If the tires fit tight against the outside of the wheel well, wheels with minimal backspacing are much easier to remove.
In other words, when in doubt, order wheels with minimal backspacing, center the wheels in the tubs then spec the rearend to fit.
Re: 10" Rear Wheels in a '63? [Re: DoctorDiff] #1712228
12/18/14 05:24 PM
12/18/14 05:24 PM
My Cuda has 16 inch wide wheels with 3.5 back spacing, there still a pain to take on and off. I think I will shorten up the wheel studs some to make it easier to get them on and off
Re: 10" Rear Wheels in a '63? [Re: Cab_Burge] #1712229
12/18/14 08:00 PM
12/18/14 08:00 PM
Harleysville, PA USA
Tommy D Offline
Tommy D  Offline
1963 Plymouth or Dodge B-bodies will fit 10" wheels as said above. The Stock Eliminator guys all run 15 x 10. I believe the backspacing on a stock, B-Body rear would need to be 5", not the 5 3/4" specified above. Check your application first. In order to see what they look like, go to the Cal Tracs website. In their Mopar section, they have photos of stockers with this wheel, running the 29 x 9 x 15" tires. TD
Re: 10" Rear Wheels in a '63? [Re: Tommy D] #1712230
12/18/14 08:45 PM
12/18/14 08:45 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
When doing a custom length rear, I run the shallowest back spacing I can get. A 10" wheel is a 10" wheel and weighs the same. However, if you run a 3" backspace wheel vs a 6" backspace wheel, that is 3" of axle housing and axle length you can remove from either side of the car, ie a good bit lighter. PLUS deep wheels just look way better, to me at least. As already touched on, that generally makes the wheels easier to get on and off as well. You should also use a thinned lug nut and have no threads past the end of that nut. Exposed threads are dead weight, plus get in the way when changing wheels.
Monte
Re: 10" Rear Wheels in a '63? [Re: Monte_Smith] #1712231
12/18/14 09:30 PM
12/18/14 09:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Monte
A shorter housing and axle is way lighter
and I like the deep wheels also
