Page 1 of 3 1 2 3
Gen III Hemi - From Junkyard to Dragstrip #1712021
12/17/14 07:05 PM
12/17/14 07:05 PM
Portersville, Pa
1badx Offline OP
1badx  Offline OP
Portersville, Pa
I thought I would start a new thread on the latest adventure here at OST Dyno.
I indicated in a few of the current Gen III Hemi threads that I would try to provide some details on a build thread for a junkyard 5.7 and various performance modifications.
I don't actually intend to take the junkyard engine down the track but I will be testing various mods on our chassis dyno for reference.
The primary reason for this endeavor is to test various products we will be selling online for modifying these engines. These product will include: intake manifold flanges, exhaust manifold flanges, drag pack to 90mm TB adapters,
and reselling items like the EFI Source Gen III Hemi gold box, TTI headers, swap kits, front motor plates with waterpump adapters, mid plates etc.
So here we go!
The engine fresh from the boneyard. I have been assured it is a runner. I've purchased quite a few engines from this yard and have yet to have one not run well:
And it says "good" on the valve cover so all should be well!
Next is the test platform. Our recently purchased 23T Altered. This formerly housed a BBC but we're going to change that....
Here's the trans. A powerglide w/straight cuts and a pro brake. This is the biggest hold up in the project right now. I ordered a JW Ultra Bell for it 3 weeks ago and it was supposed to be delivered 2 weeks ago. Now I am told it won't ship until the 2nd week in January
If anyone has a JW Ultra Bell for a glide to a small mopar or Gen III Hemi PLEASE let me know.
First on the agenda was to see if the engine even turned over on the stand. So I pulled all the coil packs and one plug from each cylinder(they looked crappy like most junkyard engines)and spun the engine with a breaker bar. I probably could have turned the pulley with my hands it spun so freely.
I also took my bore scope and checked each cylinder. They also looked typical for a junkyard engine and no broken pistons! A little purple power to wipe down the valve covers and she doesn't look so bad.
Ok, so I wanted to find out if my JW Ultra Bell was really going to be shipped on Jan 16th so I called JW myself. Sure enough the EARLIEST it will ship is Jan 16th
This is really going to cramp my plans to have this car ready for the track in April.
So in the mean time......
I grabbed a couple of timing covers off the scrap trailer so you can see the difference between a 5.7 truck cover and a car cover. THe car cover is much cleaner. I'm going to need to take a sawzall to the truck cover on my "test" engine just because it's so stinking ugly.
Truck cover "protrusion"
Car cover - not as bad
On to another topic. My EFI Source Hemi "gold box" showed up today! So far I am very impressed with the MS3 based product. Nice packaging, good instructions and very easy to install.
It even came with a free T-shirt
Do not be intimidated by all the wires. I have made my own harnesses before and this is one very nicely made, well fitted and clearly labeled. Again, very nice.
I love lots of grounds!
Having worked on and modified Megasquirt units in the past I couldn't resist opening this one up and seeing how EFI Source did the coil drivers. I built an MS3x for a Hemi several years ago and used external coil driver which were cumbersome and ugly. EFI Source did and excellent job of putting these on the board, inside the case and with a good heat sink (those babies get hot).
Very nice soldering too!
One important test I had to try after putting the unit back together. Will all the connectors fit?
I slid the coil back back on the valve covers, grabbed the harness and went to town.
It took me exactly 2 minutes and 30 seconds to completely wire the engine with the EFI Source harness. I wasn't trying to do this quickly. I just happened to look at my phone before I started (thinking it was probably going to take 20-30 minutes). Every single connector plugged right in, was the perfect length/position and was labeled appropriately. Two minutes and 30 seconds! Amazing!
My LS ported throttle body had the proper TPS and IAC connectors as well.
The only problem was that this harness was not designed to work with the MAP sensor on a truck intake manifold. But who in their right mind would run a truck manifold on one of these anyway! I'll be swapping out to a car 5.7 intake and eventually a 6.1 intake. The MAP sensor wire will then work without issue.
Speaking of Gen III Hemi swaps - look what showed up at the shop today. A Bee with a supercharged 6.1
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: 1badx] #1712022
12/17/14 07:15 PM
12/17/14 07:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
And what year is this and what did it come out of..
I will be following this
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: 1badx] #1712023
12/17/14 07:16 PM
12/17/14 07:16 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
This is gonna be cool! Someone give this guy a bellhousing so he can start testing.
Mopar to the bone!!!
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: MR_P_BODY] #1712024
12/17/14 07:39 PM
12/17/14 07:39 PM
Portersville, Pa
1badx Offline OP
1badx  Offline OP
Portersville, Pa
I believe it's 2014 at least for a few more days.....
JK - I have no idea what year the engine is. From the front cover I can tell it's out of a truck, from the coil packs it's 2005 or newer. I also know it's not a VVT engine so that's about as much as I can narrow it down
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: 1badx] #1712025
12/17/14 07:44 PM
12/17/14 07:44 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
It's got an egr.
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: 1badx] #1712026
12/17/14 07:46 PM
12/17/14 07:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
At least its a start so we know what to look for
while we follow this
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: 72Swinger] #1712027
12/17/14 07:50 PM
12/17/14 07:50 PM
Canada
onig Offline
onig  Offline
Canada
Will definitely be watching this thread.
I have a 5.7 out of a truck as well, hopefully start on it in the new year.
69 Dart
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: onig] #1712028
12/17/14 08:51 PM
12/17/14 08:51 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
I am also going to be tuned into this thread!
Please be as detailed as time allows you.
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: 1badx] #1712029
12/17/14 09:23 PM
12/17/14 09:23 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Judging by the oil filter adapter I'd guess a Jeep, pretty sure they have angled adapters
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: MR_P_BODY] #1712030
12/17/14 09:29 PM
12/17/14 09:29 PM
Portersville, Pa
1badx Offline OP
1badx  Offline OP
Portersville, Pa
At least its a start so we know what to look for while we follow this
I was just messing with you and as far as what to look for to duplicate what I plan on doing:
- Any 6.1 Hemi
- Any non-VVT 5.7 Hemi (the earlier models will just have different coil packs and valve covers that can easily be switched out if desired)
I'm thinking of testing what I can to see what type of gains are made on the dyno - which is only a tool - nothing is as definitive as the track.
Things like:
- complexity level of installing the EFIsource EMS
- stock 5.7 exhaust manifolds vs. stock 6.1's
- 5.7 car intake vs. 6.1 intake
- Cam change (whatever I have available)
- Head change (I have some stock 6.1's)
Not sure what else will be worth testing before I put my built 5.7 based engine in and go racing
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: 1badx] #1712031
12/17/14 09:35 PM
12/17/14 09:35 PM
Rockford,Il
DFlanagan Offline
DFlanagan  Offline
Rockford,Il
This should be a good thread. I've been a member over at LXForums for almost 10 years and Mike and OST are pretty darn good with the Gen III HEMI.
Can't wait to see what you guys come up with.
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: DFlanagan] #1712032
12/17/14 10:27 PM
12/17/14 10:27 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I'm subscribing!
Alan Jones
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: LA360] #1712033
12/18/14 01:44 AM
12/18/14 01:44 AM
Toronto
mshred Offline
mshred  Offline
Toronto
Cool! In for updates
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: 1badx] #1712034
12/18/14 07:28 AM
12/18/14 07:28 AM
gregsdart Online content
gregsdart  Online Content
It would be great to include some SRT8 exhaust manifolds in the exhaust test. I bought a set from a jeep to go in my 65 dart project, and I bet there are other applications where they will work without too much trouble.
I am also VERY interested in the EFI setup.
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: 1badx] #1712035
12/18/14 10:00 AM
12/18/14 10:00 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Look at the bottom of the block near the oil pan rail. Should be a bunch of letters and numbers stamped into it. Let me know what you come up with.
Matt
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: gregsdart] #1712036
12/18/14 01:09 PM
12/18/14 01:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I bought the Holley HP EFI multi-point for my 416
and am planning to use it on the gen 3 when I get
one ready... it can handle the fuel and timing with
no issues... I just finished up the install yesterday
on the 416.. now I have to hook up the laptop to
load the info and answer the question which is part
of the down load
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: MR_P_BODY] #1712037
12/18/14 01:21 PM
12/18/14 01:21 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I like the altered. This should be a cool thread
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: sixpackgut] #1712038
12/18/14 01:27 PM
12/18/14 01:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I built my brother a 23T altered for his chevy engine...
they are lite
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: MR_P_BODY] #1712039
12/18/14 09:03 PM
12/18/14 09:03 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
this should be good
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: 340RICK] #1712040
12/18/14 10:44 PM
12/18/14 10:44 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
I'll be following along too. I would like to bolt one of these in my 64 Savoy wagon.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Page 1 of 3 1 2 3
