What to use to fix hole in intake runner? #171163
12/19/08 09:49 PM
12/19/08 09:49 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
I ground a hole in my intake port. (I know, dumb stunt) Anyway, will JB Weld fix it? Or is there something better available at my local auto parts store that will fix it? If there is nothing readily available locally that will do, what will I have to get? Oh, it's an aluminum head.
Thanks!
Master, again and still
Re: What to use to fix hole in intake runner? [Re: DaveRS23] #171164
12/19/08 10:05 PM
12/19/08 10:05 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
get It welded!any epoxy is only a temporary fix!!
Re: What to use to fix hole in intake runner? [Re: boatracer572] #171165
12/19/08 10:08 PM
12/19/08 10:08 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Not what I wanted to hear, but okay. Thanks.
Re: What to use to fix hole in intake runner? [Re: DaveRS23] #171166
12/19/08 10:10 PM
12/19/08 10:10 PM
Get-X Offline
Get-X  Offline
Have somebody tig weld it shut. That's the beauty of using aluminum, you can fix them
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: What to use to fix hole in intake runner? [Re: boatracer572] #171167
12/19/08 11:10 PM
12/19/08 11:10 PM
Don't feel bad about grinding though the port, my Eddy head that I ground through 3 times, twice after having it welded needed a good tig welder to fix it properly the fourth time it was welded. Check your repair real closely to make sure that the repair covers all of the hole and any subsequent cracks that result fom the welding, I didn't look close enough after the third reapir and fought a oil consumption problem for one complete year I'm still learning how many different ways you can mess up a HP motor
Re: What to use to fix hole in intake runner? [Re: DaveRS23] #171168
12/19/08 11:12 PM
12/19/08 11:12 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Iron...Splash Zone.
Aluminum...Weld that (I know, I know...Can't say Ditch on Moparts).
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: What to use to fix hole in intake runner? [Re: Adobedude] #171169
12/20/08 08:35 PM
12/20/08 08:35 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I had my sons Eddy head runner welded were we put a small hole in it but it was very hard to get at so we used this metal epoxy from Manley and put it over the weld. Ron
Re: What to use to fix hole in intake runner? [Re: 383man] #171170
12/20/08 08:50 PM
12/20/08 08:50 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
weld it to be sure. another racer i know used some epoxy on a set of B1TS heads. the epoxy fell out & allowed the water to hydraulic the cylinder which in turn threw a leg outta bed. new mega block was trash & the head was severely cracked & distorted. the price to weld is waaaaay less than the price to replace all that gear. weld it!
not saying this is going to happen to you but the B1 boy didn't think this would happen to him. how lucky do you feel?
Re: What to use to fix hole in intake runner? [Re: rebel] #171171
12/20/08 10:31 PM
12/20/08 10:31 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Thanks for the replys. I'm relieved that I am not the only one who has done this. I was being real careful, BUT I was trying to get the last little bit out and............. Anyway, there is a shop here in town that said they can weld it up. I'll drop it off Monday. Thanks again.
Re: What to use to fix hole in intake runner? [Re: DaveRS23] #171172
12/21/08 11:27 AM
12/21/08 11:27 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
If you broke through to the head bolt area in the intake ports, they make sleeve kits for this. Or, just put silicone under the washer and on the threads. This will stop the oil too.
8.30's @3400 lbs
Re: What to use to fix hole in intake runner? [Re: Mike Swann] #171173
12/21/08 11:44 AM
12/21/08 11:44 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have to tube my one W-5 head, trying to get more
out of it I got thin in one of the bolt area's, so
I need to get a tube in there. I didnt see it at first
and was feeling the port and I thought I felt a bump
at that point and for some reason I pushed on that
spot and it blew thru... glad I found it then
