What to use to fix hole in intake runner?
#171163
12/19/08 09:49 PM
12/19/08 09:49 PM
Posts: 12,165 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I ground a hole in my intake port. (I know, dumb stunt) Anyway, will JB Weld fix it? Or is there something better available at my local auto parts store that will fix it? If there is nothing readily available locally that will do, what will I have to get? Oh, it's an aluminum head. Thanks!
Master, again and still
Re: What to use to fix hole in intake runner?
[Re: boatracer572]
#171165
12/19/08 10:08 PM
12/19/08 10:08 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Not what I wanted to hear, but okay. Thanks.
[Re: DaveRS23]
#171168
12/19/08 11:12 PM
12/19/08 11:12 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Iron...Splash Zone.
Aluminum...Weld that (I know, I know...Can't say Ditch on Moparts).
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Adobedude]
#171169
12/20/08 08:35 PM
12/20/08 08:35 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I had my sons Eddy head runner welded were we put a small hole in it but it was very hard to get at so we used this metal epoxy from Manley and put it over the weld. Ron
[Re: rebel]
#171171
12/20/08 10:31 PM
12/20/08 10:31 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Thanks for the replys. I'm relieved that I am not the only one who has done this. I was being real careful, BUT I was trying to get the last little bit out and............. Anyway, there is a shop here in town that said they can weld it up. I'll drop it off Monday. Thanks again.
[Re: DaveRS23]
#171172
12/21/08 11:27 AM
12/21/08 11:27 AM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
If you broke through to the head bolt area in the intake ports, they make sleeve kits for this. Or, just put silicone under the washer and on the threads. This will stop the oil too.
8.30's @3400 lbs
[Re: Mike Swann]
#171173
12/21/08 11:44 AM
12/21/08 11:44 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I have to tube my one W-5 head, trying to get more out of it I got thin in one of the bolt area's, so I need to get a tube in there. I didnt see it at first and was feeling the port and I thought I felt a bump at that point and for some reason I pushed on that spot and it blew thru... glad I found it then
