71 Satellite 383 Engine #1711586
12/16/14 08:17 PM
12/16/14 08:17 PM
Missouri
P
petty43 Offline OP
petty43  Offline OP
P
Missouri
Picked this baby up Saturday.
It is kind of an odd optioned car.
E65 383 4 BBL
D32 HD 727
RP23
N1G
EV2 TORED/Hemi Orange
P6X9 Premium Bucket Black Seats
TX9 Upper Door Frame Black/Black Velvet
V1X Black Vinyl Roof
A01 Light Package (Don't know what that gets you)
D41 Heavy Duty Clutch
D51 2.76 Rear (I have not checked to see if it is still a 2.76)
C16 Console w/Buckets
C55 Bucket Seats
L31 Hood/Fender Mount Turn Signal
M21 Drip Moldings
M25 Wide Sill Moldings
M41 Dual Exhaust
R11 Am Radio
V6X Black Longitude Stripe
The D's above may be B's as it has power disc brakes.
Now to the question. I have the following items to use.
I have a 69HP block out of a RR bored .030.
I have KB400 Pistons balanced and ready to put in.
Edelbrock Open Plenum intake. Can't remember if it is a TM6 or Torker.
Holley 600
906 Heads
Hooker Competition Plus Headers
The engine and transmission were gone and I plan to put an automatic trans and this engine back in.
Thinking of using a Comp Cams XE-268 per the tech line at Comp Cams.
Just want to get a second opinion on the camshaft for street fun and good vacuum on the brakes.
1968 Satellite RR Copy Cat My Fleet
Re: 71 Satellite 383 Engine [Re: petty43] #1711587
12/16/14 08:32 PM
12/16/14 08:32 PM
Texas
carcrazyguy Offline
carcrazyguy  Offline
Texas
Yep...B41 FRONT DISC BRAKES
Nice find!
Does your build date happen to be close to 6/21? Wondering if it was close to my orange car.
Re: 71 Satellite 383 Engine [Re: carcrazyguy] #1711588
12/16/14 08:35 PM
12/16/14 08:35 PM
Missouri
P
petty43 Offline OP
petty43  Offline OP
P
Missouri
Built 10-25 just in time for Halloween! The seats are orange and black in it now.
Re: 71 Satellite 383 Engine [Re: carcrazyguy] #1711589
12/16/14 08:37 PM
12/16/14 08:37 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
B41 disc brakes
B51 power brakes.
RP23 Satellite Sebring Plus
A code N SSP is not to rare. Had one myself.
Nice car.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 71 Satellite 383 Engine [Re: petty43] #1711590
12/16/14 08:40 PM
12/16/14 08:40 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
A good cam for a 383. Lots of guys running that stick in those engines. I think if you search it on youtube there are a couple videos of 383's running with it.
Re: 71 Satellite 383 Engine [Re: DaytonaTurbo] #1711591
12/16/14 08:50 PM
12/16/14 08:50 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I would rethink that manifold with your combo.
Performer would work much better.
Ron
Re: 71 Satellite 383 Engine [Re: RJS] #1711592
12/16/14 11:31 PM
12/16/14 11:31 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Nice car.
Sheldon
Re: 71 Satellite 383 Engine [Re: petty43] #1711593
12/17/14 12:46 AM
12/17/14 12:46 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
How could it have come with a 727, and a heavy duty clutch? Or did I miss read? :scope out:
Re: 71 Satellite 383 Engine [Re: 71birdJ68] #1711594
12/17/14 01:40 AM
12/17/14 01:40 AM
Missouri
P
petty43 Offline OP
petty43  Offline OP
P
Missouri
That's why I figured the d codes were b codes. Thanks for the replies. Gonna look for a different intake and order the bump stick as suggested by the mfr.
Re: 71 Satellite 383 Engine [Re: petty43] #1711595
12/17/14 01:55 AM
12/17/14 01:55 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
not a good piston or head choice , but you'll figure that out. I'd think about a Performer RPM.
Re: 71 Satellite 383 Engine [Re: JohnRR] #1711596
12/17/14 02:17 AM
12/17/14 02:17 AM
Missouri
P
petty43 Offline OP
petty43  Offline OP
P
Missouri
JohnRR.
I already have these parts and am looking to use them. What head would you use with the pistons? What's the problem with the pistons?
Re: 71 Satellite 383 Engine [Re: petty43] #1711597
12/17/14 02:31 AM
12/17/14 02:31 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The pistons are a bad bandaid for a poorly thought out design, the valve relief canyon is so big that they had to put a dome on the piston to make up for it, and the fact that it's .027 in the hole. The good thing is you won't have 10.0 as claimed by KB.
Has anything been done to the heads yet ?
Re: 71 Satellite 383 Engine [Re: JohnRR] #1711598
12/17/14 02:48 AM
12/17/14 02:48 AM
Missouri
P
petty43 Offline OP
petty43  Offline OP
P
Missouri
I have three sets of heads. One stock 906, one set of 906 heads with dual springs from a swap meet, and a set of 452's.
I have a friend with a valve grinding machine who used to do head work for a living. My plan was to pick a set of heads, grind the valves, new seals and seats and go.
I spoke with kb today and they claim with 906 heads I would be in the 9.4 cr range.
It would probably be easier to find a running big block car and use that.
Re: 71 Satellite 383 Engine [Re: petty43] #1711599
12/18/14 02:56 AM
12/18/14 02:56 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
That car has to be the best handling and riding car I've ever driven in terms of an old Mopar. I'd do a mild build on that 383, update the suspension with some nice wheels and a good tire and drive it. Looks like a good ride for Mopower Tour.
Re: 71 Satellite 383 Engine [Re: dart4forte] #1711600
12/20/14 12:56 AM
12/20/14 12:56 AM
Missouri
P
petty43 Offline OP
petty43  Offline OP
P
Missouri
Found my receipt from 06
Degrease block, dust for cracks, pressure check, check line bore, install frost plugs, install cam bearings, deck block 9.965.
$344.90
How does .015 decking the block affect the situation?
Re: 71 Satellite 383 Engine [Re: RJS] #1711601
12/20/14 04:22 AM
12/20/14 04:22 AM
Eastern WA
P
ProStock1320 Offline
P
Eastern WA
with RJS & JohnRR. A Performer is inexpensive enough and you'll be happier in the long run.
Re: 71 Satellite 383 Engine [Re: petty43] #1711602
12/20/14 10:56 AM
12/20/14 10:56 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Maybe that's what it took to get the block "squared". Meaning, the cylinderhead deck surface parallel to the crankshaft centerline.
Re: 71 Satellite 383 Engine [Re: petty43] #1711603
12/20/14 11:54 AM
12/20/14 11:54 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Very cool car.
Sounds like you are very budget conscious. In my opinion, you will need to plow a bunch of money into that 383 to make it a really good performance engine, and I don't think that is your goal.
I think everything that you are planning is okay. That cam is fine.
I think changing the intake, like others have mentioned, is the one low cost item to seriously consider. However, my recommended hierarchy would be: stock intake, DP4B/Performer, Weiand dual plane.
The stock intake manifold (1968 or newer) is the best choice for 383/400 drivers at this performance level.
Re: 71 Satellite 383 Engine [Re: petty43] #1711604
12/20/14 01:18 PM
12/20/14 01:18 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
$344.90
A 2315 piston would be a zero deck , your KB 400 would be higher up and increase compression , which in this case may not be a positive .
Re: 71 Satellite 383 Engine [Re: JohnRR] #1711605
12/22/14 01:16 PM
12/22/14 01:16 PM
Missouri
P
petty43 Offline OP
petty43  Offline OP
P
Missouri
$344.90
JohnRR and others:
If I find another intake how would you describe how this car will drive?
A. Like a slant 6 in a station wagon full of clowns.
B. Like a 71 Satellite Sebring Plus that needs 93 Octane fuel to run well.
C. Just fine quit worrying about it and build the stupid engine. It will roast the tires when you want to and do fine on the highway.
