Re: lighten up a little ! NSS K frame finished at 21 lbs.
[Re: BobsProFab]
#171054
12/21/08 08:14 PM
12/21/08 08:14 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
What kind of turn around time Bob?
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: Chad Bittle]
#171056
12/21/08 08:59 PM
12/21/08 08:59 PM
Posts: 2,584 sycamore,ohio
BobsProFab
sycamore,ohio
how long depends on the work ahead of it in the shop. shouldnt be any longer than a few weeks to work one in thanks Chad Bondo
Re: lighten up a little ! NSS K frame goes under the knife
[Re: 8secDart]
#171057
12/21/08 09:38 PM
12/21/08 09:38 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Would you be able to take a stock B body K, make some Hemi mounts so the engine would be 1 inch lower and your fabbing like above? I need some under hood clearance ? Thanks.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Post deleted by Defbob
[Re: kosdart1]
#171060
12/22/08 01:55 AM
12/22/08 01:55 AM
#171061
12/22/08 09:48 AM
12/22/08 09:48 AM
Posts: 729 Lebanon,IN
mr2performance
Lebanon,IN
Yes you can trim the k-frame that much for superstock. I've heard questions from two of the head NHRA SS tech guys about the center piece being removed, so we leave ours "stock appearing", or whatever the customer wants. We also offer lightened strut rods and centerlinks for any mopar, offer roller bearing idler arms, and our patented quick release drag link bushings for applications where the centerlink runs through the pan. Mike Roth
MR2PERFORMANCE RACE CARS
765 483 9371
[Re: BobsProFab]
#171063
12/22/08 01:30 PM
12/22/08 01:30 PM
sunroofgtx
Cleveland
I think he means buying an 8 cylinder vs a 6 for initial cost, or not cutting up my original. Thanks.
[Re: sunroofgtx]
#171064
12/22/08 02:05 PM
12/22/08 02:05 PM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
Awesome work Bondo ! Just wondering how low you can drop a BB wedge with the factory mounts. Is a 3 or 4in drop possible ? Thanks, Ron
[Re: firefighter3931]
#171065
12/22/08 04:21 PM
12/22/08 04:21 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Thanks, Ron
You can put a motor anywhere you want it, but you have to remember to keep a workable crank centerline to the ground number. Get it too low and the car will never work, depending on suspension, power and how the rest of the car is setup. With the crank C/L low, you will need lots of power and a very good working car to stick the tire.
Monte
[Re: VernMotor]
#171067
12/22/08 07:15 PM
12/22/08 07:15 PM
dartman366
Mt. Vernon, Ohio
Yea my 67 dart has a V-8 k-member ,,wish I had a 6cy one to cut up ! I have put this off for years..but push is coming to shove...
So,, does this mean that I can stop by and give you a little motivational boot in the short's to get this project up and running?????
[Re: RoadSkinner]
#171072
12/23/08 10:12 AM
12/23/08 10:12 AM
BobsProFab
sycamore,ohio
i make a .120 wall flanged cap (1/2" lips)that i insert into the k frame before i finish weld it. strong enough to use a floor jack under it. thanks again guys Bondo
