Re: Mystery block (to me at least)
[Re: WO23Coronet]
#1710270
12/14/14 01:36 AM
12/14/14 01:36 AM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
With that late of casting date it sounds like it's one of the last 383's made, OR it's a warranty block and they just used a 400 block and bored it to 383 specs, neat piece though
This is not the first time this has come up , the fact that it doesn't have a VIN points to a replacement block, without paperwork to back it up np saying what is going on in there .
OP , what is the SPD of the car ?
[Re: JohnRR]
#1710271
12/14/14 02:05 AM
12/14/14 02:05 AM
Posts: 35 Northern NJ
67440dodge
Northern NJ
Don't know.. the guy sold the car the same time he sold me the motor and moved south. It's been sitting under my bench for 8 months and just started to check it out.
[Re: 67440dodge]
#1710272
12/14/14 02:36 AM
12/14/14 02:36 AM
JohnRR
U.S.S.A.
then it doesn't really matter I guess . It would have been a very late build car , like last week of production to get a 230 based 383 and only because there was no more 383 castings left to use. More than likely a warranty replacement block , couldn't have been the original or else the guy wouldn't have sold the car without it ???
Anyway at .060 it would need to be sonic checked before boring larger , at stock bore it would have been a nice block to build a 383 based race motor , assuming the bores were not core shifted bad , thick bores say rounder under power.
[Re: JohnRR]
#1710273
12/14/14 02:59 AM
12/14/14 02:59 AM
67440dodge
Northern NJ
He put a 440/6 in the car, and intended on selling the 383 with the car to keep them together. But whoever purchased it didn't want the 383, so I bought it from him.
It's more a curiousity thing, had never heard of a block with a lower displacement than what the casting number said it was..
[Re: cudaman1969]
#1710276
12/15/14 09:29 PM
12/15/14 09:29 PM
JohnRR
U.S.S.A.
A 400 block is standard at 4.32. It is not a warrenty block, no way would they go to the trouble to sleave it back to 4.31. A sonic check would tell how thick the walls are. My guess is its a industrial block(they are the best blocks for strength) that started out at 4.25 bore and can go to 4.375 like the 400.
A 400 block is standard at 4.342 , that's nice and thick where it is , but if he wants to bore it out it would be best to have it sonic checked , I had a 230 block that needs 2 sleeves because of core shift to go out to 4.375
[Re: JohnRR]
#1710277
12/16/14 01:56 AM
12/16/14 01:56 AM
67440dodge
Northern NJ
The motor was freshly built when I bought it. Said he changed his mind after it as built and had a 440/6 done and put it in.
Wish I had a sonic tester, love to see how thick the walls really are.
[Re: 67440dodge]
#1710278
12/16/14 02:12 AM
12/16/14 02:12 AM
Posts: 892 Illinois
StrkrDart69
Illinois
Dont ask questions until you have done your homework.
[Re: StrkrDart69]
#1710279
12/16/14 12:41 PM
12/16/14 12:41 PM
Posts: 200 South Coast of Oregon
dweller
Go back into your hole. Nothing wrong with the post or the discussion.
[Re: dweller]
#1710280
12/16/14 05:40 PM
12/16/14 05:40 PM
JohnRR
U.S.S.A.
Huh ??
[Re: 67440dodge]
#1710281
12/16/14 05:43 PM
12/16/14 05:43 PM
JohnRR
U.S.S.A.
What are the pistons , 2315 ? they will be about .015 in the hole , but the block appears to have been decked already , which is why that ID pad is blank.
The only downside to those pistons are the lack of valve reliefs .
I would just run it as it until something causes you to have to take it apart.
[Re: JohnRR]
#1710282
12/16/14 10:12 PM
12/16/14 10:12 PM
Posts: 8,274 fredericksburg,va
cudaman1969
fredericksburg,va
Sorry for the mistake on bore size,thinking one thing typed another.
[Re: JohnRR]
#1710283
12/17/14 02:10 AM
12/17/14 02:10 AM
67440dodge
Northern NJ
yea.. 2315's are in it. The cam that came with it isn't too crazy (Comp XE-274), so no valve reliefs shouldn't be a problem.
[Re: 67440dodge]
#1710284
12/17/14 02:33 AM
12/17/14 02:33 AM
JohnRR
U.S.S.A.
Should be a good base engine, and closer to 400 cubes vs. 383. What heads are you using ?
[Re: JohnRR]
#1710285
12/17/14 07:27 AM
12/17/14 07:27 AM
67440dodge
Northern NJ
Plan right now is to go with 75CC Eddy's. The 452's that came with it are paperweights unfortunately.
[Re: 67440dodge]
#1710286
12/17/14 12:56 PM
12/17/14 12:56 PM
JohnRR
U.S.S.A.
Good choice , so many people blindly go with open chamber heads because they think they were good because they came on 6 pk engines ...
