Mystery block (to me at least) #1710268
12/14/14 01:05 AM
12/14/14 01:05 AM
Northern NJ
67440dodge Offline OP
Northern NJ
Got a short deck big block on the stand. It came out of a 71 Challenger R/T, and according to the seller, it was original to the car. Build date on the block is June 7, 1971. Block has been decked so numbers on the pad are illegible. No VIN stamping is legible on the pad either.
Pistons are .060 over for a 383 (Speed Pro L2315F). Checked the bore, and it comes out to 4.310.
Stroke comes out to 3.38, so it appears to be a 383.
Here's where the fun comes in.
Casting number is 3614230-5. Block has the stiffening ribs for a 400, and the hump on the bellhousing mount for a 400. So for all intents and purposes, it's a 400 block. It even has the thick main webs of the early casting 400's. But the cylinders are bored for 383, and there is no sign of any sleeving being done to get .060 over 383 pistons in a 400 block.
Anyone ever see a block like this?
Re: Mystery block (to me at least) [Re: 67440dodge] #1710269
12/14/14 01:25 AM
12/14/14 01:25 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
With that late of casting date it sounds like it's one of the last 383's made, OR it's a warranty block and they just used a 400 block and bored it to 383 specs, neat piece though
Re: Mystery block (to me at least) [Re: WO23Coronet] #1710270
12/14/14 01:36 AM
12/14/14 01:36 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This is not the first time this has come up , the fact that it doesn't have a VIN points to a replacement block, without paperwork to back it up np saying what is going on in there .
OP , what is the SPD of the car ?
Re: Mystery block (to me at least) [Re: JohnRR] #1710271
12/14/14 02:05 AM
12/14/14 02:05 AM
Northern NJ
Northern NJ
Don't know.. the guy sold the car the same time he sold me the motor and moved south. It's been sitting under my bench for 8 months and just started to check it out.
Re: Mystery block (to me at least) [Re: 67440dodge] #1710272
12/14/14 02:36 AM
12/14/14 02:36 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
then it doesn't really matter I guess . It would have been a very late build car , like last week of production to get a 230 based 383 and only because there was no more 383 castings left to use. More than likely a warranty replacement block , couldn't have been the original or else the guy wouldn't have sold the car without it ???
Anyway at .060 it would need to be sonic checked before boring larger , at stock bore it would have been a nice block to build a 383 based race motor , assuming the bores were not core shifted bad , thick bores say rounder under power.
Re: Mystery block (to me at least) [Re: JohnRR] #1710273
12/14/14 02:59 AM
12/14/14 02:59 AM
Northern NJ
Northern NJ
He put a 440/6 in the car, and intended on selling the 383 with the car to keep them together. But whoever purchased it didn't want the 383, so I bought it from him.
It's more a curiousity thing, had never heard of a block with a lower displacement than what the casting number said it was..
Re: Mystery block (to me at least) [Re: 67440dodge] #1710274
12/15/14 01:42 PM
12/15/14 01:42 PM
dogdays Offline
dogdays  Offline
Mopar, never say never!
Sonic check it. You may be pleasantly surprised. When you do, report back because this topic has come up again and again.
There are Industrial 413s that have the same casting number as Industrial 426s.
R.
Re: Mystery block (to me at least) [Re: dogdays] #1710275
12/15/14 08:31 PM
12/15/14 08:31 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
A 400 block is standard at 4.32. It is not a warrenty block, no way would they go to the trouble to sleave it back to 4.31. A sonic check would tell how thick the walls are. My guess is its a industrial block(they are the best blocks for strength) that started out at 4.25 bore and can go to 4.375 like the 400.
Re: Mystery block (to me at least) [Re: cudaman1969] #1710276
12/15/14 09:29 PM
12/15/14 09:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
A 400 block is standard at 4.342 , that's nice and thick where it is , but if he wants to bore it out it would be best to have it sonic checked , I had a 230 block that needs 2 sleeves because of core shift to go out to 4.375
Re: Mystery block (to me at least) [Re: JohnRR] #1710277
12/16/14 01:56 AM
12/16/14 01:56 AM
Northern NJ
Northern NJ
The motor was freshly built when I bought it. Said he changed his mind after it as built and had a 440/6 done and put it in.
Wish I had a sonic tester, love to see how thick the walls really are.
Re: Mystery block (to me at least) [Re: 67440dodge] #1710278
12/16/14 02:12 AM
12/16/14 02:12 AM
Illinois
StrkrDart69 Offline
StrkrDart69  Offline
Illinois
Dont ask questions until you have done your homework.
Re: Mystery block (to me at least) [Re: StrkrDart69] #1710279
12/16/14 12:41 PM
12/16/14 12:41 PM
South Coast of Oregon
dweller Offline
dweller  Offline
Go back into your hole. Nothing wrong with the post or the discussion.
Re: Mystery block (to me at least) [Re: dweller] #1710280
12/16/14 05:40 PM
12/16/14 05:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Huh ??
Re: Mystery block (to me at least) [Re: 67440dodge] #1710281
12/16/14 05:43 PM
12/16/14 05:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What are the pistons , 2315 ? they will be about .015 in the hole , but the block appears to have been decked already , which is why that ID pad is blank.
The only downside to those pistons are the lack of valve reliefs .
I would just run it as it until something causes you to have to take it apart.
Re: Mystery block (to me at least) [Re: JohnRR] #1710282
12/16/14 10:12 PM
12/16/14 10:12 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Sorry for the mistake on bore size,thinking one thing typed another.
Re: Mystery block (to me at least) [Re: JohnRR] #1710283
12/17/14 02:10 AM
12/17/14 02:10 AM
Northern NJ
Northern NJ
yea.. 2315's are in it. The cam that came with it isn't too crazy (Comp XE-274), so no valve reliefs shouldn't be a problem.
Re: Mystery block (to me at least) [Re: 67440dodge] #1710284
12/17/14 02:33 AM
12/17/14 02:33 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Should be a good base engine, and closer to 400 cubes vs. 383. What heads are you using ?
Re: Mystery block (to me at least) [Re: JohnRR] #1710285
12/17/14 07:27 AM
12/17/14 07:27 AM
Northern NJ
Northern NJ
Plan right now is to go with 75CC Eddy's. The 452's that came with it are paperweights unfortunately.
Re: Mystery block (to me at least) [Re: 67440dodge] #1710286
12/17/14 12:56 PM
12/17/14 12:56 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Good choice , so many people blindly go with open chamber heads because they think they were good because they came on 6 pk engines ...
Re: Mystery block (to me at least) [Re: 67440dodge] #1710287
12/17/14 06:40 PM
12/17/14 06:40 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Does it have the thick main webs like 230 blocks are supposed to have? Can you show a pic?
