ez wiring harness charging issues #1710196
12/13/14 08:28 PM
12/13/14 08:28 PM
NC
Tommy383 Offline OP
Tommy383  Offline OP
NC
Ez wiring harness issues on my 383 duster.
Fires right up, but not charging. I had the same problem on a 70rr a few years back, and it was solved by disconnecting a wire, but i do not remember which it was. Running alternator exciter wire to one fld post, and the other fld post is going to the voltage regulator.
Any help appreciated. Wanting to drive it tomorrow, but not if it isnt charging...
Re: ez wiring harness charging issues [Re: Tommy383] #1710197
12/14/14 01:52 AM
12/14/14 01:52 AM
Andrewh Offline
Andrewh  Offline
so just to be sure we are all talking the same thing.
you have 12 volts key on going to one field the other field is going to your vr.
you are using a 71 and up VR.
where is the big post off the alt going? where does it tie in?
have you tried running a line directly back to the battery?
Re: ez wiring harness charging issues [Re: Tommy383] #1710198
12/14/14 05:31 AM
12/14/14 05:31 AM
(1) need switched 12V to alt blue field terminal and (2) Same switched 12V (T'd from (1) to top blue wire terminal in reg triangle connector (3) continuity from alt green field wire terminal to reg green wire "side" terminal (4) functioning reg (5) reg grounded (6) alt/brushes working (7) alt batt terminal has continuity in/out bulkhead back to battery (rare that it ain't) (8) alt case has continuity to batt neg post (rare also)
Re: ez wiring harness charging issues [Re: RapidRobert] #1710199
12/14/14 01:08 PM
12/14/14 01:08 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
when i rewired my dart using a AAW highway 22 kit here is how i wired the charging system..
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: ez wiring harness charging issues [Re: abodyjoe] #1710200
12/14/14 11:58 PM
12/14/14 11:58 PM
NC
Tommy383 Offline OP
Tommy383  Offline OP
NC
Got it. The switched 12v wire on the harness was not getting any power. Got switched 12v to the regulator, and we are charging. Drove it for the first time today. Been a 5yr project.
Thanks for the input.
