Re: How level does the engine need to be
[Re: 64dartsb]
#1710163
12/13/14 05:46 PM
12/13/14 05:46 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
V-6 or 8 2 to 5 degrees should be fine. OEM's are 2 to as much as 7 degrees.I measure at the carb pad if it is level.Inline more and never 0 degrees as it will overly stress the crankshaft.
Leave the gun.......take the Cannoli's....Mike
[Re: 64dartsb]
#1710165
12/13/14 06:07 PM
12/13/14 06:07 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Carb pad is usually where you'd measure it.
Of course the floor has to be level too, or you compensate.
[Re: 64dartsb]
#1710166
12/13/14 06:27 PM
12/13/14 06:27 PM
RapidRobert
the carb (intake flange) is what you want "reasonably" level then with that set (mtr mts/and maybe trans mt) see what you have for ujoint angles & adj pinion/maybe trans mt as needed
[Re: mike s]
#1710167
12/13/14 09:21 PM
12/13/14 09:21 PM
Posts: 363 San Diego
64dartsb
San Diego
Ok cool thanks dudes j should be able to handle all that!
if your dreaming of your car then it's your dream car....
[Re: 64dartsb]
#1710168
12/13/14 09:40 PM
12/13/14 09:40 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
and, this should only matter on carb engines. once the fuel is vaporized through the intake runners, or shot at the intake valve on EFI, it won't matter. from tunnel rams with vertical runners, to slant sixes with horizontal runners...
Then, think about what happens when you drive up a steep grade or go rock crawling. I'd say how level the carb is, is not THAT critical, so long as it's level enough that fuel doesn't spill out the vents and the floats work properly.
**Photobucket sucks**
[Re: 64dartsb]
#1710171
12/13/14 10:58 PM
12/13/14 10:58 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Don't ask Mercedes! The G-wagen was designed around an inline 6 diesel. When Benz decided to drop a gas V8 in there things didn't fit right. It didn't seem to bother the "engineered like no other vehicle" crowd.
