b-5 blue dart #1709693
12/11/14 10:25 PM
12/11/14 10:25 PM
minnesota
P
president61 Offline OP
P
minnesota
next summer I'm having my dart painted b-5 blue base clear. I planned on painting the underneath and interior metal single stage. what should i use for the engine compartment and steel wheels, single stage or base clear. thanks for the input
Re: b-5 blue dart [Re: president61] #1709694
12/12/14 12:02 PM
12/12/14 12:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Wouldn't the shine between base clear and single stage look different thus making it easy to see a difference in the colors ?
Re: b-5 blue dart [Re: JohnRR] #1709695
12/12/14 12:15 PM
12/12/14 12:15 PM
Iowa
burdar Online work
Owen's Dad
burdar  Online Work
Owen's Dad
Iowa
The color will probably be OFF a little too. I don't see a problem with single stage on the bottom but use the same paint in the engine compartment and in the trunk that you are going to use on the body.
If you didn't already know, these cars were never completely painted body color on the bottom side. If that's the look you want that's OK. They didn't come that way though.
Re: b-5 blue dart [Re: burdar] #1709696
12/12/14 07:52 PM
12/12/14 07:52 PM
minnesota
P
P
minnesota
Ok thanks. I should use base clear on the steel rims too then?
Re: b-5 blue dart [Re: president61] #1709697
12/12/14 07:55 PM
12/12/14 07:55 PM
Iowa
burdar Online work
Owen's Dad
burdar  Online Work
Owen's Dad
Iowa
I would paint them base clear. I wouldn't want any chance of a color mismatch.
