E-85 fuel #1709610
12/11/14 09:52 PM
12/11/14 09:52 PM
Texas
Steve Reynolds Offline OP
Texas
We have an RB440, originally built by Nick Wilson, 12.5 compression, Edelbrock heads & a solid roller cam. We have been using 110 octane fuel, can E-85 be substituted, if so what changes need to be made?
I have already looked in past posts, maybe not far enough, thanks
Steve
Re: E-85 fuel [Re: Steve Reynolds] #1709611
12/11/14 09:56 PM
12/11/14 09:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Steve
Yes E-85 will work.. the carb will need to be worked
over.. when using E-85 you need 30% more fuel across
the board... and make sure the pump will pump at
least the 30% more
Re: E-85 fuel [Re: MR_P_BODY] #1709612
12/11/14 10:12 PM
12/11/14 10:12 PM
Texas
Texas
The Demon has had twin Holley blue pumps forever with no problems ever
Steve
Re: E-85 fuel [Re: Steve Reynolds] #1709613
12/11/14 11:17 PM
12/11/14 11:17 PM
JAX FLA
Curt Offline
Curt  Offline
JAX FLA
Need to make sure pumps, lines,regulators,diaphrams,tank,cell foam (if applies) are compatible.....
Curt
Oh yeah...THAT'S gonna leave a mark!
Re: E-85 fuel [Re: Steve Reynolds] #1709614
12/12/14 08:10 AM
12/12/14 08:10 AM
Norrland, Sweden
Swedcharger67 Offline
Norrland, Sweden
Get A/F ratio correct (Lambda about .80 to.90) and you will have more power than before...
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
Re: E-85 fuel [Re: Swedcharger67] #1709615
12/12/14 01:56 PM
12/12/14 01:56 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I considered this fuel then decided race gas(unleaded 101)is easier to tune, no special pumps, lines and carb mods needed. Two guys I know runnin it w/spray blew their stuff up. KISS method but of course that`s MY opinion...............
Re: E-85 fuel [Re: Thumperdart] #1709616
12/12/14 03:52 PM
12/12/14 03:52 PM
PA
ajcasini Offline
ajcasini  Offline
PA
Have been using e85 for around 8 years and have had no issues with engines being hurt etc. We did run into some issues with BarryGrant fuel pressure regulators eating the seat. Have run Aeromotive, holley, magna fuel and quick fuel products and have had no issues.
It is a great alternative race fuel. Requires a little more maintenance than gas but not nearly what you would do with methanol. The big advantages are cooler temps, cost and it makes more power.
Re: E-85 fuel [Re: ajcasini] #1709617
12/12/14 04:30 PM
12/12/14 04:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve heard great things too but I`m lazy so proven simplicity over a few hp which I can make up somewhere else.
Re: E-85 fuel [Re: Thumperdart] #1709618
12/12/14 05:16 PM
12/12/14 05:16 PM
PA
ajcasini Offline
ajcasini  Offline
PA
I made the change more for the cost savings over the race season. When I ran race fuel again the last couple years and to complete the season last year the fuel cost was around 1800$ runnign C12. That was 3 drums of fuel. Running E85 I would go through 4 drums a season at a cost of about 165 a drum for a total cost of 660$. For a racer thats a lot of extra tow money.
Re: E-85 fuel [Re: ajcasini] #1709619
12/12/14 05:31 PM
12/12/14 05:31 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Makes good sense which I slightly lack...........
Re: E-85 fuel [Re: Thumperdart] #1709620
12/13/14 07:34 AM
12/13/14 07:34 AM
sweden
sshemi Offline
sshemi  Offline
sweden
I have been running e85 for alot of years now and some time without useing e85 specific parts. I have NEVER emptied the fuel system for winter storage and have never had a problem. Well on one car i had a problem where i had used gasket goo on the stock pickup and the fuel dissolved(?) it so the float valves would stick.
Guess that would happen on gas too.
Re: E-85 fuel [Re: Thumperdart] #1709621
12/13/14 07:58 AM
12/13/14 07:58 AM
Norrland, Sweden
Norrland, Sweden
I considered this fuel then decided race gas(unleaded 101)is easier to tune...
The E85 is actually easier to tune because E85 is less sensitive to the absolutely correct A/F ratio, it will give max power over a bigger A/F ratio span than gasoline...and the octane is higher than 101 race gas...
Re: E-85 fuel [Re: Swedcharger67] #1709622
12/13/14 11:50 AM
12/13/14 11:50 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I like running it in the summer. Knocks the temp right out of the motor, and let's you hot lap easier. Also makes way better power than gas on those hot summer days.
Winter time can be a little tough starting, and warming up. Almost impossible without a lean out valve if it's really cold.
Keep your gas carb. Throw it on when it gets cold, and when real winter comes your fuel system is better off with gas sitting in it.
Re: E-85 fuel [Re: dthemi] #1709623
12/13/14 12:31 PM
12/13/14 12:31 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
Just wondering at what temps are uall have problems startups? I'v had no problem at 45 deg. temps Also I know keeping the fuel lid tight on the drums will help keep fuel fresh but do uall keep drums off the ground(on blocks)?
Not trying to jack this thread, but sense were on the subject.....Thax.
Re: E-85 fuel [Re: racerx] #1709624
12/13/14 12:42 PM
12/13/14 12:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On my car I had some issues starting at about 40*..
I kept my drums on the shop floor(heated concrete)
during the winter months.. sealed drums... I never
had any issues with the drums or fuel.. if it was
on a dirt floor in a pole barn I would have the drums
on wood (some 2X4s) just so the moisture didnt bother
the drums
Re: E-85 fuel [Re: Swedcharger67] #1709625
12/13/14 01:33 PM
12/13/14 01:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Sounds ok but no stations near by and I drive 2-3 miles and fill er up............SIMPLE. The VP-101 I use likes rich tunes as in 12.0-12.2 so far but was as high as 13.0 when I stomped the Vette.............
Re: E-85 fuel [Re: Thumperdart] #1709626
12/13/14 01:46 PM
12/13/14 01:46 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Cold starting is mostly cam related. The bigger the cam, the harder it starts in the cold, even with high static compression. Slow burning fuel with a ton of overlap.
Re: E-85 fuel [Re: Thumperdart] #1709627
12/13/14 01:57 PM
12/13/14 01:57 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
Hmmm..... what was it not enough fuel(leaning it out)?
Re: E-85 fuel [Re: racerx] #1709628
12/13/14 02:00 PM
12/13/14 02:00 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not sure what happened but obviously they were out of the tuning parameters cos it happened twice..........
Re: E-85 fuel [Re: Steve Reynolds] #1709629
12/13/14 10:48 PM
12/13/14 10:48 PM
NC
440Jim Offline
440Jim  Offline
NC
No problem, IMO.
I ran 13.5 with Indy heads, 0.042" quench, with E-85
