Steering column parts #1709575
12/11/14 09:28 PM
12/11/14 09:28 PM
Pennsylvania
Red 79 Offline OP
Red 79  Offline OP
Pennsylvania
Does anyone know where I can get Saginaw steering column parts. I am looking for the upper and lower bowls from a floor shift vehicle. I want to get rid of the holes left from removing the column shifter. It is a tilt saginaw from 79 D-100 with ignition on the column. Thanks
Re: Steering column parts [Re: Red 79] #1709576
12/11/14 10:28 PM
12/11/14 10:28 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Not sure if anyone reproduces the bowls or if they are still available from Dodge but I can tell you if I was looking for them I would fine a floor shift model and take the column out of it, plenty of floor shift Dodge trucks in the boneyards, at least down my way.
Careful, your character's showing!
Re: Steering column parts [Re: Red 79] #1709577
12/11/14 11:54 PM
12/11/14 11:54 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I thought the tilts (GM) were quite rare on floor shift(manual) tranny trucks.
Re: Steering column parts [Re: buildanother] #1709578
12/11/14 11:59 PM
12/11/14 11:59 PM
mopar346 Offline
mopar346  Offline
Maybe, maybe I'll have to look around for some now.
Re: Steering column parts [Re: mopar346] #1709579
12/12/14 03:57 PM
12/12/14 03:57 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
These columns were used in everything. I just rebuilt the one in my 5A because the inverted torx bolts loosened up and the tilt was flopping around.
I would check eBay. I was able to find all sorts of new parts and even shift bowls/outer casings.
