67 GTX 4 speed differential question
#170948
12/19/08 06:13 PM
12/19/08 06:13 PM
Was it standard for a 67 GTX 440 4 speed to come with a Dana? If so, what where the common gears found in them?
Re: 67 GTX 4 speed differential question
[Re: ScottSmith_Harms]
#170950
12/19/08 06:22 PM
12/19/08 06:22 PM
Thanks, I thought so. Now I'm off to the parts wanted section.
#170953
12/19/08 07:04 PM
12/19/08 07:04 PM
Was the 18 spline trans standard too? This is my first pre '68 mopar
#170955
12/19/08 07:16 PM
12/19/08 07:16 PM
#170957
12/20/08 08:10 PM
12/20/08 08:10 PM
Posts: 3,407 S.E. Florida, USA
rrunner
S.E. Florida, USA
A buddy of mine has a 67 18 spline trans if you need one.
[Re: Silverbullet2]
#170959
12/21/08 10:49 AM
12/21/08 10:49 AM
Posts: 10,750 North Dakota
6PakBee
North Dakota
A '68 differential is about 1/2" wider than a '66-'67. So the "drain plug" approach is not the entire story, just one part.
#170963
12/22/08 03:53 PM
12/22/08 03:53 PM
Posts: 252 Minnesota
69Y2RT
Minnesota
I will have to pull it out of storage to get a pic of the pad. I will try to get one tonight.
I don't remember seeing any tags on the cover side, I will look for that too.
It suprised me too, when I picked the car up from the swamp it was in I found the trans laying in the mud about 100 feet from the car in pieces. I saw the vin pad and figgured it was a 68 trans. When I hit it with break cleaner I could see the number stamp. I looked it up to see what it was from I realized it was the original trans for the car.
1969 Coronet R/T Y2 Y2 P6X X9 V8X
1967 Satellite 383 4speed
#170964
12/24/08 06:17 PM
12/24/08 06:17 PM
Posts: 2,655 western PA
mopar4ya
western PA
The 1967 18 spline transmission will have the small front input bearing and retainer as well.
Dan
#170966
01/21/09 05:40 PM
01/21/09 05:40 PM
Posts: 5,445 So Cal
Sinitro
So Cal
Yes, 3:54 Standard
Also Chrysler had a supporting program for swapping out the Dana center pieces for different ratios @ the dealer level. In my 67 Mopar Hemi purchased new I had the dealer install a 4.10 instead of the factory-installed 3.54. I think the take-out 3.54 piece was then dropped off into their national parts system...
Just my $0.02...
#170967
02/13/09 09:24 PM
02/13/09 09:24 PM
6pak,
yea I know, but it will be a good place to start, if it has the plug it's pretty likely the original, but by no means definate without checking the BOM#.
What would the BOM# be for a '67 GTX? I can't seem to find anything prior to '68 calender year.
