Removing rear seat from early B 'vert #1709404
12/11/14 02:01 PM
12/11/14 02:01 PM
Moncton, New Brunswick
hemidart1 Offline OP
I am looking to paint the rear armrest panels on my '65 Belvedere convertible. I am guessing I have to take out the rear seat to get at the screws holding the panels on. Any trick to this?
thanks in advance.
Al.
1967 Hemi GTX
1969 Chrysler 300
Re: Removing rear seat from early B 'vert [Re: hemidart1] #1709405
12/11/14 02:09 PM
12/11/14 02:09 PM
USA
b54406barrel Offline
USA
Been a few years since I re-upholstered my '63. Lower seat on mine was the standard push back & lift. Think the back was two 1/4 or 5/16" bolts & then just slide up off the crossbrace.
Re: Removing rear seat from early B 'vert [Re: b54406barrel] #1709406
12/11/14 02:17 PM
12/11/14 02:17 PM
Andrewh Offline
Andrewh  Offline
it is the standard push back and lift.
the top of the seat has 2 bolts behind the bottom to remove, then if you look there are 2 hooks on the back of the top of the seat as well.
there were only 2 screws holding in each side panel as I recall. but it has been a while since I pulled mine. maybe 3. one was in near where to top rests when it is open.
Re: Removing rear seat from early B 'vert [Re: Andrewh] #1709407
12/11/14 02:37 PM
12/11/14 02:37 PM
thanks!
1967 Hemi GTX
1969 Chrysler 300
