Mega block torque sequence #170916
12/19/08 05:58 PM
12/19/08 05:58 PM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
What's the sequence.Do you do all the mains then the side bolts?And what do you torque the side bolts to with arp moly lube?
Re: Mega block torque sequence [Re: sc301v] #170917
12/19/08 08:55 PM
12/19/08 08:55 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
good ?
Re: Mega block torque sequence [Re: bonefish] #170918
12/19/08 09:09 PM
12/19/08 09:09 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
Get the side bolts started, and then torque all the main caps first. I torqued the side bolts to 35ft/lbs I believe.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Mega block torque sequence [Re: sc301v] #170919
12/20/08 10:56 AM
12/20/08 10:56 AM
SouthEast Michigan
P
PETE@BESTMACHINE Offline
P
SouthEast Michigan
We snug all fasteners frist,with stock main bolts 95 with 30w oil and side bolts 45 with 30w oil.Hope this helps.
Re: Mega block torque sequence [Re: PETE@BESTMACHINE] #170920
12/20/08 11:57 AM
12/20/08 11:57 AM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
I have studs..Forgot to mention that.
Re: Mega block torque sequence [Re: sc301v] #170921
12/20/08 03:35 PM
12/20/08 03:35 PM
Use the sequence and torque specs that came with the studs or call the stud manufacturer to get them, make sure on the lube to use with the torque numbers also . I do as already said on the side bolts, snug slightly all of them and then torque the main bolts first snf the side bolts on that cap, move to the next one. Do the thrust(center) main last after checking and setting the crankshaft play end
