Engine swaps for 72-80 trucks- max mileage *DELETED* #1708898
12/10/14 12:47 PM
12/10/14 12:47 PM
Canada
demon Offline OP
demon  Offline OP
Canada
Post deleted by demon
Re: Engine swaps for 72-80 trucks- max mileage [Re: demon] #1708899
12/10/14 01:22 PM
12/10/14 01:22 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
probably a stock gen 3 hemi or a 4BT cummins is your best bet for economy
Re: Engine swaps for 72-80 trucks- max mileage [Re: CTD5.9] #1708900
12/10/14 01:33 PM
12/10/14 01:33 PM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
What kind of mileage are you looking for?
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: Engine swaps for 72-80 trucks- max mileage [Re: dynotune440] #1708901
12/10/14 01:38 PM
12/10/14 01:38 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
My stock 92 318 magnum was a standout. Plenty of power and 25MPG Imperial. The Magnum swap is very easy to do as well. I think a turboed V6 Magnum would be even better.
Sheldon
Re: Engine swaps for 72-80 trucks- max mileage [Re: RUNCHARGER] #1708902
12/10/14 01:43 PM
12/10/14 01:43 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
A 318 magnum swap is probably the best bang for your buck. Reasonably low mileage 318 magnums can be found. But whether or not you keep the fuel injection, one thing you can really do to get the efficiency up is to take the engine apart and have the block decked to get the pistons up to zero deck, then run a .040 head gasket. Stock the pistons are just a little too far down in the hole and the head gaskets I think are a little too thick. Doing this will get the compression up a bit and set it up for quench. IMO worth it for the real wold efficiency and power gains.
Re: Engine swaps for 72-80 trucks- max mileage [Re: DaytonaTurbo] #1708903
12/10/14 01:58 PM
12/10/14 01:58 PM
dogdays Offline
dogdays  Offline
Or swap out the pistons for KB 167s. Using the MP thin gaskets you get the same results and take 90 grams off the piston.
I don't know about the rest of you, but I have found that milling heads and decking blocks is expensive compared to what one would think it cost. Maybe not a truing cut of a few thousandths, but when one starts taking off 0.040" or so the price soars.
R.
Re: Engine swaps for 72-80 trucks- max mileage [Re: dogdays] #1708904
12/10/14 02:06 PM
12/10/14 02:06 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
depending on your budget..
if it was enough to cover a diesel swap, Id got 4BT in a HEARTBEAT!
otherwise, a big block (383/400/400) built conservatively with good low end torque and 3.21 to 2.76 gears would be OK enough to get you into the high teen's..
There was a guy either here or on RCC, that had a 4BT in a 74-75 Ramcharger and claimed to get 30MPG Highway/25MPG City.
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Engine swaps for 72-80 trucks- max mileage [Re: shanker] #1708905
12/10/14 03:49 PM
12/10/14 03:49 PM
Guitar Jones Offline
4BT all the way.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Engine swaps for 72-80 trucks- max mileage [Re: shanker] #1708906
12/10/14 04:05 PM
12/10/14 04:05 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Assuming the motor is in good condition, one might think more MPG can be had through driver input, and vehicle usage then through mechanical modification. Then more MPG would likely come from transmission (OD) and axle gearing then through motor changes, and that gearing change has to be towards the most often truck usage. Changing gearing and motor functions for highway mileage is pretty useless if the truck spends its time in the city, and if that driving time is mostly done on short trips when the motor seldom reaches operating temperature, nothing much is going to help.
These mileage threads always turn into a pizzing match. Gene
Re: Engine swaps for 72-80 trucks- max mileage [Re: demon] #1708907
12/10/14 04:34 PM
12/10/14 04:34 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Another starting point for a mid 70's ramcharger would probably be a transmission/transfer case swap. A 518 and part time 4wd will probably get you a few MPG
Re: Engine swaps for 72-80 trucks- max mileage [Re: CTD5.9] #1708908
12/10/14 04:40 PM
12/10/14 04:40 PM
Manitoba, Canada
Manitoba, Canada
If the OP could snag a complete 92-95 ram or dakota that would be ideal. I would swap over the engine, trans, efi and diffs. I would not want a 70's full time 4wd for any kind of mpg.
Re: Engine swaps for 72-80 trucks- max mileage [Re: DaytonaTurbo] #1708909
12/10/14 06:10 PM
12/10/14 06:10 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
A 92-93 would work, 94+ would be a ton of work.
Re: Engine swaps for 72-80 trucks- max mileage [Re: CTD5.9] #1708910
12/10/14 06:26 PM
12/10/14 06:26 PM
Manitoba, Canada
Manitoba, Canada
As long as it's 95 and earlier it's doable. Once you hit 96 and the OBD-2, the wiring and ecu issues become a nightmare. The OBD-1 engine harnesses can be dissected realitively easily. And once you're done you will find the engine harness is remarkably self contained. I think I only had to connect two or three wires to the carbed engine harness to get the engine to run.
Re: Engine swaps for 72-80 trucks- max mileage [Re: DaytonaTurbo] #1708911
12/10/14 06:35 PM
12/10/14 06:35 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Sorry you are correct on the engine, I was thinking more along the lines of the transfer case + differentials. They switched to the coil over front and the drivers side drop in 94 which would make swapping them in a ton of work. I think an old transfer case would bolt up to the transmission though.
Re: Engine swaps for 72-80 trucks- max mileage [Re: CTD5.9] #1708912
12/11/14 12:00 PM
12/11/14 12:00 PM
Canada
demon Offline OP
demon  Offline OP
Canada
Another possibly I considered is a Jeep 4.0 liter 6.
The biggest difficulty in any swap is the transfer case. Anyone know Jeep transfer cases?
Re: Engine swaps for 72-80 trucks- max mileage [Re: demon] #1708913
12/11/14 12:56 PM
12/11/14 12:56 PM
Manitoba, Canada
Manitoba, Canada
Yeah they put the front driveshaft on the driver's side of the trans. I found this one out when I swapped a 318 magnum into my Jeep. Put the front driveshaft right where the 5.2 starter wanted to be!
Re: Engine swaps for 72-80 trucks- max mileage [Re: CTD5.9] #1708914
12/11/14 12:57 PM
12/11/14 12:57 PM
Manitoba, Canada
Manitoba, Canada
Ok I'm not as familiar with those. If a guy was to swap in the newer diffs with the the newer transfer case and trans how would that work?
Re: Engine swaps for 72-80 trucks- max mileage [Re: DaytonaTurbo] #1708915
12/11/14 03:18 PM
12/11/14 03:18 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
trans and transfer case would be fine, The front diff would need major frame work since they did away with the leafs. You could however find an older ford Dana 44 or 60 and put it in to work with the new transfer case.
Re: Engine swaps for 72-80 trucks- max mileage [Re: CTD5.9] #1708916
12/12/14 01:44 PM
12/12/14 01:44 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Not hard to Ad spring perches.
I dont think the 4.0 would do any better than a 318.
I think a Magnum 318/518 setup would be good. a 4bt would be Great too.
Re: Engine swaps for 72-80 trucks- max mileage [Re: demon] #1708917
12/12/14 03:43 PM
12/12/14 03:43 PM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
Thinking outside the box, what about the mercedes OM606 turbodiesel? Great mileage and very tuneable. They can be retrofit with a mechanical injection pump from the (i think) OM603. Its a car based engine so it would have more flexibility in RPM range than a 4bt as well as being much lighter.
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
