Arp head stud torque ????????????
#1708888
12/10/14 11:33 AM
12/10/14 11:33 AM
Posts: 1,235 TN
65racer
2009 IHRA World Champion
TN
Does anyone know right off hand what the studs are torqued on, I have lost my literature, and my "crs" is kicking in,,,,,,,,,,I know I could go to arp and download this info, but my old dinosaur computer will not open a pdf file, so I would appreciate any info,,,,,,thanks
Re: Arp head stud torque ????????????
[Re: 65racer]
#1708890
12/10/14 12:09 PM
12/10/14 12:09 PM
Posts: 7,506 Az
Crizila
Az
ARP calls for 105 on my small block. The objective with studs is to be able to run higher torque #'s than conventional head bolts for more clamping power. Studs are to be run in to the block finger tight only - and their suggested torque #'s are with their lube.
Fastest 300
[Re: Crizila]
#1708893
12/10/14 01:28 PM
12/10/14 01:28 PM
Posts: 1,235 TN
65racer
TN
Guess I should have said this is a stock iron headed engine,,,,,,,,,,,,
[Re: 65racer]
#1708894
12/10/14 01:30 PM
12/10/14 01:30 PM
Posts: 52,972 Romeo MI
MR_P_BODY
And you never said.. BB or SB
[Re: MR_P_BODY]
#1708896
12/10/14 03:54 PM
12/10/14 03:54 PM
Posts: 1,235 TN
65racer
TN
Big block ,,,,,,
[Re: 65racer]
#1708897
12/10/14 07:17 PM
12/10/14 07:17 PM
Posts: 7,506 Az
Crizila
Az
Big block ,,,,,,
Probably doesn't apply, but FWIW for a small block, stock head bolt torque is 90 lbs. Edelbrock aluminum heads recommend 95 lbs. I run eddys in a blower application with equivalent CR of 16.1 ( and more )at times. I run mine up to 105 ( believe that is an ARP recommendation ) with MLS gaskets.
Fastest 300
