Arp head stud torque ???????????? #1708888
12/10/14 11:33 AM
12/10/14 11:33 AM
TN
65racer Offline OP
2009 IHRA World Champion
65racer  Offline OP
TN
Does anyone know right off hand what the studs
are torqued on, I have lost my literature, and
my "crs" is kicking in,,,,,,,,,,I know I could go
to arp and download this info, but my old
dinosaur computer will not open a pdf file, so
I would appreciate any info,,,,,,thanks
Re: Arp head stud torque ???????????? [Re: 65racer] #1708889
12/10/14 11:50 AM
12/10/14 11:50 AM
CLARKSVILLE,TN.
DAYTONA540 Offline
DAYTONA540  Offline
CLARKSVILLE,TN.
70 ft. lb. in 25 lb increments. Hope this helps.
Re: Arp head stud torque ???????????? [Re: 65racer] #1708890
12/10/14 12:09 PM
12/10/14 12:09 PM
Az
Crizila Offline
Crizila  Offline
Az
ARP calls for 105 on my small block. The objective with studs is to be able to run higher torque #'s than conventional head bolts for more clamping power. Studs are to be run in to the block finger tight only - and their suggested torque #'s are with their lube.
Fastest 300
Re: Arp head stud torque ???????????? [Re: Crizila] #1708891
12/10/14 12:56 PM
12/10/14 12:56 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Check with the head manufactures recomended torque,some aluminium heads don't want to exceed 70/75# and others 80/85#.Most high torque specs are for iron heads.
Re: Arp head stud torque ???????????? [Re: B G Racing] #1708892
12/10/14 01:17 PM
12/10/14 01:17 PM
Az
Crizila Offline
Crizila  Offline
Az
Good to know ( and check ), although the paper work I got with my ARP studs did not discriminate between iron and aluminum heads. If you can't clamp with higher numbers than with regular head bolts, studs are kind of a waste - unless you take the heads off and on - often.
Fastest 300
Re: Arp head stud torque ???????????? [Re: Crizila] #1708893
12/10/14 01:28 PM
12/10/14 01:28 PM
TN
65racer Offline OP
65racer  Offline OP
TN
Guess I should have said this is a stock
iron headed engine,,,,,,,,,,,,
Re: Arp head stud torque ???????????? [Re: 65racer] #1708894
12/10/14 01:30 PM
12/10/14 01:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
And you never said.. BB or SB
Re: Arp head stud torque ???????????? [Re: MR_P_BODY] #1708895
12/10/14 01:49 PM
12/10/14 01:49 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
To clear up any confusion the stud it'self should never be torqued only the attaching nut.We usually turn the stud in till it bottoms out and turn it out at least 1/4 turn.We lube all the threads and both sides of the washers.The two common lubes for all threaded componants are 30#oil and molylube.Torque values with oil are higher than with molylube since there is less friction when using the moly.There are quite a few advantages to using studs than bolts.
Re: Arp head stud torque ???????????? [Re: MR_P_BODY] #1708896
12/10/14 03:54 PM
12/10/14 03:54 PM
TN
65racer Offline OP
65racer  Offline OP
TN
Big block ,,,,,,
Re: Arp head stud torque ???????????? [Re: 65racer] #1708897
12/10/14 07:17 PM
12/10/14 07:17 PM
Az
Crizila Offline
Crizila  Offline
Az
Big block ,,,,,,
Probably doesn't apply, but FWIW for a small block, stock head bolt torque is 90 lbs. Edelbrock aluminum heads recommend 95 lbs. I run eddys in a blower application with equivalent CR of 16.1 ( and more )at times. I run mine up to 105 ( believe that is an ARP recommendation ) with MLS gaskets.
Fastest 300
