Page 1 of 6 1 2 3 4 5 6
How much to build 440? #1708433
12/09/14 09:50 AM
12/09/14 09:50 AM
M.A.
Fern Offline OP
Fern  Offline OP
M.A.
Have a 78, 440. All stock except for a set 0f 69- 906 heads and 770 holley avenger carb.
I am looking to see how much it would cost to get that motor to about 400HP.
Or is it better to just buy a crate motor.
This is just a street driven car/ daily driver. Not looking to go crazy, just get more power.
Re: How much to build 440? [Re: Fern] #1708434
12/09/14 10:54 AM
12/09/14 10:54 AM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
Pretty simple to get 400 HP out of your 440, should be no need for a crate engine. If the engine is fresh just put a good dual plane aluminum intake under your 770 carb, install some headers and good free flowing dual exhaust, good ignition system and you should be pretty close to 400 with maybe a little extra, good luck.
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: How much to build 440? [Re: RapidusMaximus] #1708435
12/09/14 12:01 PM
12/09/14 12:01 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'll also add call a cam grinder and have one made for your application. There are a few guys that make good cams for the low compression engines.
Coming soon!!!!
Re: How much to build 440? [Re: Mr.Yuck] #1708436
12/09/14 04:26 PM
12/09/14 04:26 PM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
$5,000.
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: How much to build 440? [Re: WyleECoyote] #1708437
12/09/14 04:31 PM
12/09/14 04:31 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
$5,000.
How's that? You can get a done 500hp unit for that. I'm guessing he already has the basics. Engine, heads, and such. If he's just looking for the upgrades, cam, intake headers... Those can be had for under $500
Re: How much to build 440? [Re: Mr.Yuck] #1708438
12/09/14 04:55 PM
12/09/14 04:55 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Do you want a rebuild or do you just want to mod what you have to 400 horsepower?
Re: How much to build 440? [Re: Fern] #1708439
12/09/14 05:20 PM
12/09/14 05:20 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The 78 440 will have the smogger low CR pistons. Your actual CR will be around 7.8:1. Now if the short block is in good shape, you can get 400hp out of it, but it will be less streetable than a comparable 440 with better compression.
Re: How much to build 440? [Re: Fern] #1708440
12/09/14 05:20 PM
12/09/14 05:20 PM
A certified culture free zone.
74RALLYE Offline
74RALLYE  Offline
$3500 with a little luck and you doing the assembly.
Re: How much to build 440? [Re: Fern] #1708441
12/09/14 05:54 PM
12/09/14 05:54 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
If your motor is sound i.e. not burning oil and quiet, a simple cam change and a set of headers should easily get 400 HP. Must find a good cam for a low comp motor though....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: How much to build 440? [Re: HemiRick] #1708442
12/09/14 06:21 PM
12/09/14 06:21 PM
M.A.
Fern Offline OP
Fern  Offline OP
M.A.
The motor was a replacement motor. It runs fine and only has about 3000 miles on it.
Is it worth rebuilding to get it up to 400 hp or just better to buy a crate motor?
I would like to get more compression, and better heads if thats a better route than mickey mouse the motor.
The comments are all over from simple $500 to $5000.
Re: How much to build 440? [Re: Fern] #1708443
12/09/14 06:50 PM
12/09/14 06:50 PM
Manitoba, Canada
Manitoba, Canada
I wouldn't be able to justify rebuilding if it's only got 3000 miles on it. If all else is running well there are better places to spend your money. I wouldn't even take a cylinder head off.
For a low CR build with stock heads I would find a used edelbrock CH4B intake. Good dual plane intake, and with stock heads IMO a better choice than an edelbrock performer RPM. Buy yourself a set of cheap summit headers, but spring for some decent gaskets. For a cam, I would take a look at hughes "whiplash" cam for 440. They ground that cam to make power while maximizing cylinder pressure in low compression 440's just like yours. Then do yourself a favor and do your torq converter. Don't leave a stock converter in there, buy something that will stall to 2800-3000rpm. This will help cover the bottom end torq that the smogger piston 440's are soft on. I haven't heard good things about the street avenger carbs but no real experience. Also you will NEED to recurve your distributor. If you're not going to recurve your distributor, you might as well not even unbolt the intake from that 440. Dialing in your spark advance will make or break a low CR 440. Also what's your rear end gear ratio?
Re: How much to build 440? [Re: Fern] #1708444
12/09/14 06:56 PM
12/09/14 06:56 PM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
Why the focus on "400" horsepower?
Its just a number.
There are soooo many things to consider; that's why you're hearing $500 to $5,000.
It all depends on what YOU want to do with the vehicle; not just that you want "400" horsepower.
The whole thing has to be a plan; you have to match cam, intake, carb, stall converter, gear ratio, and tire size all to what you want out of the vehicles purpose.
Is fuel mileage important? Is high rpm important? Is 75 mph for freeway driving important?
So my point is there are many things you can do to a vehicle to make it perform and FEEL more powerful and like it has more horsepower, without really adding horsepower IN the engine. You shouldn't focus on wanting "400" horsepower as much as doing the things to make it perform "better" - for whatever it is you're looking for.
Change your gear ratio.
Add an intake manifold and carb.
Add headers.
Add a bigger cam.
Change heads.
If you want to change compression more than what you can do with heads and thin head gaskets, thats when your money will be falling out of your pocket. Like the poster above said "$3500 and you assemble." And why I said, "$5,000." Getting into an engine for a complete rebuild isn't cheap.
I'm just offering some advice and points for you to think about. I'm not critiquing or judging you or anyone else's comments, just trying to help.
Wile E. Coyote
Re: How much to build 440? [Re: Fern] #1708445
12/09/14 06:57 PM
12/09/14 06:57 PM
As said I would get a custom cam to build some psi, a good dual plane intake (performer RPM if you have hood clearance). dial in the dist subsystems in order. 68-70 or later HP ex manifolds (or headers if you can handle them) & mandrel bends/free flow (loud) muffs and non restrictive glasspacks alongside the leaf springs to get the noise back to acceptable. Then if that ain't enough then see about building another long block
Re: How much to build 440? [Re: RapidRobert] #1708446
12/09/14 07:54 PM
12/09/14 07:54 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I'll dare to say it.........
get some closed chamber 516 heads, shave them .060, add the 1.74 exh. valve, invest in a cheap harbor freight die grinder, bowl port the heads with a few select stones, add a MP 284/484 cam, a used aluminum dual-plane (like a CH4B, Weiand or Perf. RPM), your carb, headers and an easy 400+ ponies with moooocho torque at 2400 rpm and up.
Far & away less than a crate motor or $5000.
Re: How much to build 440? [Re: RapidRobert] #1708447
12/09/14 08:03 PM
12/09/14 08:03 PM
M.A.
Fern Offline OP
Fern  Offline OP
M.A.
Ok, the car is a 70 challenger with fast ratio steering, so not sure if headers will fit or not.
The car is a standard.
Rear gears are 3.55
The reason I said 400hp is just to clarify that I'm not looking for a stroker motor, just a point of reference. Mild build.
Since the motor is in great shape, I was hopeing to get better response.
Are the 906 heads a good option for this motor or would bolting on different heads make a big difference?
Re: How much to build 440? [Re: Fern] #1708448
12/09/14 08:31 PM
12/09/14 08:31 PM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
Re: How much to build 440? [Re: Fern] #1708449
12/09/14 08:39 PM
12/09/14 08:39 PM
AndyF Online content
AndyF  Online Content
If you have access to a compression gauge you can save yourself (and us) a lot of time. Write down what compression you have in all 8 cylinders and post that. If you can check the engine vacuum then even better.
If you have low cylinder compression then there are not any "cheap" fixes to get you to 400 hp. If you have decent compression then some bolt on parts probably get you there.
Re: How much to build 440? [Re: AndyF] #1708450
12/09/14 09:30 PM
12/09/14 09:30 PM
74RALLYE Offline
74RALLYE  Offline
3,000 miles, it's just broke in. A cam, intake and hedders would wake it up.
Re: How much to build 440? [Re: Fern] #1708451
12/09/14 10:18 PM
12/09/14 10:18 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Re: How much to build 440? [Re: Fern] #1708452
12/09/14 10:20 PM
12/09/14 10:20 PM
Idaho
LaRoy Engines Offline
Idaho
Maybe this will give you a few ideas. We invited the neighbors over for a 'dyno day' at the shop and made a few changes to a 7.5:1 compression 440 over about eight hours and made a dyno pull after each change. It wasn't designed to be a perfect combination, we started with stock 906 heads and used parts we had laying around.
Low compression 440 dyno test.
