Re: How much to build 440?
[Re: Fern]
#1708434
12/09/14 10:54 AM
12/09/14 10:54 AM
Posts: 2,411 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
Pretty simple to get 400 HP out of your 440, should be no need for a crate engine. If the engine is fresh just put a good dual plane aluminum intake under your 770 carb, install some headers and good free flowing dual exhaust, good ignition system and you should be pretty close to 400 with maybe a little extra, good luck.
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: RapidusMaximus]
#1708435
12/09/14 12:01 PM
12/09/14 12:01 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I'll also add call a cam grinder and have one made for your application. There are a few guys that make good cams for the low compression engines.
[Re: WyleECoyote]
#1708437
12/09/14 04:31 PM
12/09/14 04:31 PM
Mr.Yuck
Brookeville, Md
$5,000.
How's that? You can get a done 500hp unit for that. I'm guessing he already has the basics. Engine, heads, and such. If he's just looking for the upgrades, cam, intake headers... Those can be had for under $500
[Re: Mr.Yuck]
#1708438
12/09/14 04:55 PM
12/09/14 04:55 PM
Posts: 5,162 CT
GTX MATT
CT
Do you want a rebuild or do you just want to mod what you have to 400 horsepower?
[Re: Fern]
#1708441
12/09/14 05:54 PM
12/09/14 05:54 PM
Posts: 4,848 Memphis
HemiRick
Memphis
If your motor is sound i.e. not burning oil and quiet, a simple cam change and a set of headers should easily get 400 HP. Must find a good cam for a low comp motor though....
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: Fern]
#1708444
12/09/14 06:56 PM
12/09/14 06:56 PM
Posts: 1,377 Tennessee
WyleECoyote
Tennessee
Why the focus on "400" horsepower? Its just a number. There are soooo many things to consider; that's why you're hearing $500 to $5,000. It all depends on what YOU want to do with the vehicle; not just that you want "400" horsepower. The whole thing has to be a plan; you have to match cam, intake, carb, stall converter, gear ratio, and tire size all to what you want out of the vehicles purpose. Is fuel mileage important? Is high rpm important? Is 75 mph for freeway driving important? So my point is there are many things you can do to a vehicle to make it perform and FEEL more powerful and like it has more horsepower, without really adding horsepower IN the engine. You shouldn't focus on wanting "400" horsepower as much as doing the things to make it perform "better" - for whatever it is you're looking for. Change your gear ratio. Add an intake manifold and carb. Add headers. Add a bigger cam. Change heads. If you want to change compression more than what you can do with heads and thin head gaskets, thats when your money will be falling out of your pocket. Like the poster above said "$3500 and you assemble." And why I said, "$5,000." Getting into an engine for a complete rebuild isn't cheap. I'm just offering some advice and points for you to think about. I'm not critiquing or judging you or anyone else's comments, just trying to help.
Wile E. Coyote Super Genius, Lover of FCA US LLC Products ************* 68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
[Re: RapidRobert]
#1708446
12/09/14 07:54 PM
12/09/14 07:54 PM
Posts: 8,940 Holly/MI
Dean_Kuzluzski
Holly/MI
I'll dare to say it......... get some closed chamber 516 heads, shave them .060, add the 1.74 exh. valve, invest in a cheap harbor freight die grinder, bowl port the heads with a few select stones, add a MP 284/484 cam, a used aluminum dual-plane (like a CH4B, Weiand or Perf. RPM), your carb, headers and an easy 400+ ponies with moooocho torque at 2400 rpm and up. Far & away less than a crate motor or $5000.
