Re: what's wrong with 59* sb's
[Re: fishy340]
#1708360
12/08/14 10:45 PM
12/08/14 10:45 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I would like too see your indy's and a new victor on the same flow bench to see who is king.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: fishy340]
#1708361
12/08/14 11:03 PM
12/08/14 11:03 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I see alot of complaining about 59* blocks and how the Victor head could be better utilized on a different block How many guys need more then 8000rpm w a 420+ ci motor ? The 59* stuff works fine for 98.9 % of what guys wanna do out there. This is what went in nascar and went 500laps in heat and at high rpm.. Just sayin
A pliers will loosen a nut too. Is it the best tool for the job ? No doubt , you can make a stout 59 degree small block. But at the point where these heads ( if the flow numbers bear out ) go to work is the point where the stock block becomes marginal. Will it work ? Probably. But rounding off the corners at that point gets pretty pricey.
[Re: fishy340]
#1708364
12/09/14 12:02 AM
12/09/14 12:02 AM
Posts: 3,396 Pa
Hot 340
Pa
Their are of course limitations but how many push to that limit ? The head choice is limited but not like before w9,victors and stuff like this came out. As far as a stock block goes FILL IT they are tuff sobs them 340's...:) Brad my indy were below 330cfm but it suprised me on the power it makes.
Totally agree. 59 will take more pounding than people think. Seems everyone talks about how weak the stock blocks are. ...but I hear of very few being broke because of power.
[Re: fishy340]
#1708365
12/09/14 12:04 AM
12/09/14 12:04 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Put em on a magnum block, they are stronger than any stock LA blocks ever were and there is 550-600 hp 340 blocks surviving It would not live up to the heads potential but it beats full ported RPMs that seem to stop around 600 in serious effort engines. The victor would just be getting started. To help with the 59* lifter issue I prefer a higher ratio rocker to straighten the lifter/PR angle slightly and access flow faster. It is a small crutch for a *59 engine but the shallower valve angle is going to help also by tilting the top of the valve away from the intake. Of course my favorite option is to stuff a 4.25 crank in there to bring the RPM down.
[Re: 1967dartgt]
#1708369
12/09/14 12:34 AM
12/09/14 12:34 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Mine from Ryan went [Email]346@700[/Email] if I remeber. But like I said I would like to see them on the same bench at the same time.
I got a set of 360-1's they are the cnc 245's but the raised port vesion. Ryan did them and said they more around 255cc and I remember a set he did on here in the 365 @ .700" lift range. I also have a magnum block and T&D 1.7 shaft rockers. I have the MRL Performance offset lifters and spin mine to 8K with no issues.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: slammedR/T]
#1708370
12/09/14 12:44 AM
12/09/14 12:44 AM
Posts: 369 Indy
496 A-body
Indy
So you can run offset lifters on a 59 degree block? I inquired about this a while back and several chimed in and said the link bars would snap almost immediately.
[Re: 496 A-body]
#1708371
12/09/14 12:49 AM
12/09/14 12:49 AM
slammedR/T
the comps will snap the link bars because they can't handle the twist force from the lifter angle. The MRL's have a WAY! stronger link bar and they way they are linked together is stronger. I have run mine for awhile now till I had a sleeve failure(my factory block was sleeved in 04) and then a cracked head(which is fixed now thank god). More time slips to come. Thought I had oil pressure issue with them but i figured out that problem.
[Re: SpareParts]
#1708373
12/09/14 02:03 AM
12/09/14 02:03 AM
Posts: 52,972 Romeo MI
MR_P_BODY
So who wants to get rid of some W9RP rocker arms? I've got some crap laying around to have some 59* fun!
I sold off all my W-9 stuff when I sold my W-9 engine.. all I have now is W2s and W-5s on stock LA blocks till I start my gen3
[Re: MR_P_BODY]
#1708374
12/09/14 02:05 AM
12/09/14 02:05 AM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
Thanks for the help! LOL
Do ya know of any? Maybe you got some lunch box items from Mopar?? Lol
[Re: 1967dartgt]
#1708377
12/09/14 01:41 PM
12/09/14 01:41 PM
Posts: 1,534 bronx n.y
one bad fish
bronx n.y
i would like to see a pair on a stock block and sit next to me lol
[Re: D-50]
#1708380
12/10/14 12:47 AM
12/10/14 12:47 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
What degree are SB Chevy's? Just curious.
Mopar to the bone!!!
[Re: 72Swinger]
#1708381
12/10/14 12:55 AM
12/10/14 12:55 AM
1967dartgt
Hilltown Pa
Sorry wrong post, I believe they are 48*
[Re: 1967dartgt]
#1708382
12/10/14 12:57 AM
12/10/14 12:57 AM
72Swinger
Nebraska
^^^That is the stock valve angle yes, was wondering what their lifter angle is? Isnt that the difference between the 48* and 59* R blocks??
[Re: 72Swinger]
#1708383
12/10/14 02:02 AM
12/10/14 02:02 AM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
Heads are sb chevy 23*,ford sb 20*,and mopar sb 18* that's stock.
[Re: 1967dartgt]
#1708384
12/10/14 10:48 AM
12/10/14 10:48 AM
Posts: 1,784 PA
W5DART66
PA
Chevy is 45*lifter
[Re: SpareParts]
#1708386
12/11/14 12:51 AM
12/11/14 12:51 AM
tubtar
St. Paul , Mn.
The X block is a little insurance for the bottom end. As for the lifter angle , it will clearly work with good parts up to 8000 + rpms. But back when the X blocks were as good as it got , serious players moved the lifters around to address pushrod angle. And it was done for us with the advent of the 48 degree blocks. If 59 degree is what you have , go forth and sin no more. If I was starting from scratch ( like I did ) then the decision was clear. Honestly , it is not as easy now as it was five - six years ago when I embarked on my ordeal. I had my choice of R blocks then. It's definitely a little tougher now. My next deal will be a 59 degree 340 going in an '80 Volare wagon , but it isn't going to be as radical a build as my Dart so I think it will be just fine. But if I intend to make some real steam , the 59 degree stuff would not be my first choice.
[Re: slammedR/T]
#1708387
12/11/14 01:18 AM
12/11/14 01:18 AM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
What does your Dakota weigh, if you don't mind me asking??? Keith
[Re: Dunnuck Racing]
#1708388
12/11/14 01:53 AM
12/11/14 01:53 AM
slammedR/T
dakota is around 2765lbs. and 3190lbs. with my fat ass in it.
[Re: tubtar]
#1708389
12/11/14 01:54 AM
12/11/14 01:54 AM
slammedR/T
i was going to try the hard route of locating a good 48* R block, but now I think a Gen III hemi will be my next motor build.
[Re: tubtar]
#1708390
12/11/14 03:42 AM
12/11/14 03:42 AM
SpareParts
Janesville, WI
I guess it comes down to how you define "real steam" to me Yates' low 5's is pretty damn good. I'd be thrilled if my car ever went that quick and I don't care what the lifter angle is lol. I have one style and we're considering building a 59* version for little bro but really need W9RP rocker arms to make it happen
[Re: Leon441]
#1708394
12/11/14 05:12 PM
12/11/14 05:12 PM
HotRodDave
Kalispell Mt.
Look where the center main bearings are anchored to the side of the block near the pan rail. There is extra meat under the pan rail sort of like a TA block just not quite that drastic. Also after clearancing blocks to build stroker motors you can tell the material changed, I am no metallurgist by any means but it is a lot harder to grind. I tend to see less core shift in general (there may be some LA blocks better than bad magnums but they are more the exception than the norm as far as core shift). Last small detail that may add some strength is the extra mount bosses all over the out side, expecially the 02-03 blocks.
I like almost free roller cam set ups also... now I do know about the 89-92 360 block having a roller cam but they are harder to find as they only came in trucks and dodge was not selling a lot of trucks till 94. Also that block does not have the extra meat around the mains.
I am not going to claim they are like an X block or anything but for the price difference (almost none) they are definately worth using if you plan to push a stock block really hard.
I think the difference in bore size does not outweight the blocks other strengths. In a perfect world we would have R3 blocks from the JY at $100 a pop but we don't. Also those LA 360 blocks that could safely go 4.100 are very rare, most of them are lucky to have enough real meat to be safe at 4.030.
[Re: HotRodDave]
#1708395
12/11/14 06:38 PM
12/11/14 06:38 PM
slammedR/T
^^this^^
I know in the truck world there are A LOT! of 360 magnums punched out to .040" over and .060" over that are stroker motors with no problems. But as already stated going more than .030" over bore I would want a sonic test of the block first.
[Re: SpareParts]
#1708396
12/12/14 02:41 AM
12/12/14 02:41 AM
tubtar
St. Paul , Mn.
X block and 59 degree W-9's are capable for sure.......but hardly representative of the garden variety 59 degree stuff that is readily available. Not quite unobtanium , but definitely unique. Real steam starts around 600 h.p. for a small block in my opinion. And it can be easily done with a stock block and 59 degree pushrod angles. But there are better options out there. Why not take advantage of them ?
[Re: one bad fish]
#1708399
12/12/14 01:34 PM
12/12/14 01:34 PM
Triple Threat
Renton Washington
My 454" deal is siamese 59 degree R3. It badly needs a set of heads to make it run, I've had too many other things going on lately to make the switch.
[Re: one bad fish]
#1708400
12/12/14 02:45 PM
12/12/14 02:45 PM
slammedR/T
well ive had some good luck with 59 stuff cant complain
Me too but I'm leaning more towards Gen III hemi stuff everyday
[Re: Triple Threat]
#1708401
12/13/14 12:10 AM
12/13/14 12:10 AM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
Plenty of that stuff for sale, heck you could have bought Daryls heads and put them on "carry on" on the flight home! I would imagine with your CI that you could make a ton of power and have it all in by 7K rpm.
